215cc CNC Ported MOPAR 273-360 LA Set Up For HYD Roller 2.08 Int 1.60 Exh Valves | eBay
Return of the Air Woofers....??? lol
I'd bet they have a happy flowbench...
My ported W2’s are at 240@.400... you are correct sir!The 270 @ .400" is about 30cfm too much and swings the needle to the impossible side. J.Rob
I agree, even thee best ported production based stuff ive seen is not much over 250cfm@.400My ported W2’s are at 240@.400... you are correct sir!
Part of the problem is we have gone decades without a head like this... most of the latest and greatest havent shown to be all there ,yet....and so it's hard to give it a second thought or believe it.A guy over on Moparts posted his build in oz land with them>
they were the wolf 220heads
360 +.040
Bloomer 4.25 crank with 11.7 comp
98 Octane fuel
Air Wolf heads
Solid Roller Cam - 257 duration @ .050 .645 lift
1050 Quick Fuel 4150 Carb
Dyno'd at 625hp @ 6100 with peak 597ft/lbs of torque at 5100.
Torque was 580 from 4200
