[FOR SALE] 225 engine/ trans parts/ 74 Ducster will fit others
dovercrossing
Go Mountaineers
Salem, WV
here are a lot of parts bought to fit a 74 Duster will fit others not pictured is a comp cam, chrome valve cover ,fuel pump, Napa rear emergency brake cables, A body black carpet set, rocker panels, shock set front and rear. There is a picture of the cam specs, pistons are.30 over, valves are 1.70 and 1.44 rod and mains are .10 the mancini racing 904 rebuild kit has moisture spots on metal clutch discs would clean up with 1000 grit easily but consider that a free part $750.00 US firm, will ship you pay costs, Sorry if your from Canada you coming here after it, too much hassle to ship
