Howdy! to make a long story short, i've been trying to get my 72 Duster roadworthy as well as teach myself how to do everything as I go, and I got it to crank, and idle(ish) but it was rough, noticed the coil was arcing, swapped it back to a factory one and it smoothed out some more but it was still way off and idling high, and if i lowered the idle, it would kind of just lean out and die So I tried richening the mixture a bit and now it doesn't idle on its own and I can't start the car and jump over to the front to keep it alive by hand by myself. SO.
Is there a way to practically "bench set" my carb on the car?
I basically need it to be generally in the ball park so I can go through and set the timing and let it get warm to set valve lash etc. Just waiting to get it into that elusive "smooth as a sewing machine" slant territory.
Also any general tips are appreciated since its basically me, myself, and I with the internet figuring this stuff out or if you're in North GA, just come wrench with me.
