255 60 15 1968 barracuda
Tires and Wheels (Mopar Hubcaps Too)
  1. Slantsix64
    Slantsix64 Well-Known Member
    2,469
    921
    May 11, 2014
    SGV
    Local Time:
    1:45 PM
    whats up guys getting some new rims for my brothers 68 barracuda it has a 8.75 small bolt pattern rear end. Were going with 255 60 15 on a 7 inch rim would i need 15x7 with 4.5 backspace want it to look like a tucked what do you guys think?
  2. 68 Tuna Fish
    68 Tuna Fish Member
    14
    14
    Jun 19, 2019
    Titletown, WI
    Local Time:
    1:45 PM
    I just put 15x7 rims w/4-1/4" backspace on my '68. I have 245/60 tires on with no spacers. They tuck in nicely in the wheelwells but are only about 5/8" away from the springs. You might want to check your clearance on the inside.
    • Agree Agree x 1
    • Slantsix64
      2,469
      921
      May 11, 2014
      SGV
      Local Time:
      1:45 PM
      thanks for the reply, do you have big bolt pattern axles of the 5 on 4?
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      10,698
      5133
      Nov 28, 2008
      NorCal
      Local Time:
      11:45 AM
      With SBP axles I think a 15x7 with 4.25” of backspace would be the ticket, 4.5” would put you right on the springs. If you had BBP axles then 4.5” would work, BBP axles move the axle flange further out.
    • 68 Tuna Fish
      68 Tuna Fish Member
      14
      14
      Jun 19, 2019
      Titletown, WI
      Local Time:
      1:45 PM
      I have the 5 on 4 small bolt pattern. Let me know if 255's work. I was considering using them but was worried about clearance.
    • 68 Tuna Fish
      68 Tuna Fish Member
      14
      14
      Jun 19, 2019
      Titletown, WI
      Local Time:
      1:45 PM
      Sorry to ask a dumb question but what does SBP & BBP refer to? I assume they have something to do with the rear axle assembly.
      • Like Like x 1
      • Slantsix64
        2,469
        921
        May 11, 2014
        SGV
        Local Time:
        1:45 PM
        No question is dumb, SBP (small bolt pattern 5 on 4 1963-1972)
        BBP (big bolt pattern 5 on 4.5 1973 and up)
      • 72bluNblu
        10,698
        5133
        Nov 28, 2008
        NorCal
        Local Time:
        11:45 AM
        Yup, what he said for the most part. SBP refers to the 5x4” pattern, BBP refers to the 5x4.5” bolt pattern.
        The year split is a little less clear cut. ‘63 to ‘72 all production A-bodies were SBP, both disks and drums.
        In ‘73, all of the front disk brake A-bodies went BBP. But cars that had front wheel drums stayed SBP. All of the V8’s got disks, so, SBP was just /6 cars. And some option packages upgraded the /6 cars to disks. In ‘76 they all went disk and the SBP went away.
        To add more confusion, in ‘73 the upper control arms changed as well to use the larger ball joint already used on all the other models. Even the 10” SBP drum cars got the large ball joints, so the 73+ drum spindles are different. They also had larger wheel bearings than the earlier drum cars.
      • 68 Tuna Fish
        68 Tuna Fish Member
        14
        14
        Jun 19, 2019
        Titletown, WI
        Local Time:
        1:45 PM
        Thanx for the history. The small bolt pattern sure limits the choice of aftermarket wheels. I'm sticking with factory Rallyes but did consider Torque Thrusts at one time.
      • 72bluNblu
        10,698
        5133
        Nov 28, 2008
        NorCal
        Local Time:
        11:45 AM
        Yup, it sure does limit your choices. If you want to stay with factory reproduction wheels it’s not too bad, but anything other than that and you only have a couple choices.
        And then there’s brake hardware. It’s not bad right now, but there were a few years when some of the SBP brake parts weren’t available. A-bodies were the only ones that had it, so it’s a limited market. The BBP brake stuff was used on most of the RWD cars all the way up to the late eighties/early 90’s, so, there’s millions of cars that need those parts.
      • Slantsix64
        2,469
        921
        May 11, 2014
        SGV
        Local Time:
        1:45 PM
        Just had them mounted! they fit like a glove!
        • Like Like x 1
        • Slantsix64
          2,469
          921
          May 11, 2014
          SGV
          Local Time:
          1:45 PM
          i just got the front tires 225 60 15 going on a 6.5 or 6inch rim with 4.25 back space? sounds like it will work what you think @72bluNblu
        • 68 Tuna Fish
          68 Tuna Fish Member
          14
          14
          Jun 19, 2019
          Titletown, WI
          Local Time:
          1:45 PM
          Couldn't say. I've got stock 14's with 235/60 tires on the front of mine. How much clearance do you have with the 255's?
        • 72bluNblu
          10,698
          5133
          Nov 28, 2008
          NorCal
          Local Time:
          11:45 AM
          Either one should work. I’ve always used them on a 15x7” with 4.25” of backspace but they’ll fit on a 6” rim too.
          • Like Like x 1
