[WANTED] 273 4 barrel intake 64
Cars and Mopar Parts Wanted
  1. 1964Dart273
    1964Dart273 New Member
    4
    2
    Oct 16, 2019
    Molalla Oregon
    Local Time:
    6:45 AM
    Contact Seller
    Looking to upgrade to bigger intake and carb on my 1964 273 Dart. I understand they can be difficult to find. Preferably aluminum, but would consider stock. Thank you. Phone number removed by staff.
  2. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    42,939
    25986
    Jan 18, 2006
    Iowa
    Local Time:
    8:45 AM
    Stock cast 65 4 barrel manifold is casting number# 2465726. (no 4 barrel 273's in 64) Edelbrock made a D4B which is aluminum and harder to find than the stock cast manifold. The 64 and 65 273's had a smaller attaching bolt and at a different angle than the 66 on up small block manifolds. The newer manifold bolt holes can be modified to work if you choose.
    Any small block manifold will fit. All 66 and newer manifolds will have to be modified. Ones specifically made for the 273/318 will have the correct port size.
    By the way, Welcome to FABO. Love your 64. I was looking for one when I found my 66 15 years ago.
  3. 1964Dart273
    4
    2
    Oct 16, 2019
    Molalla Oregon
    Local Time:
    6:45 AM
    Understood. Is there anyone who still manufacturers a manifold that can be modified? If so do you know the part #? Been looking for a D4B for a few weeks now. Thanks. I have learned so much on this site.
    Thank you! Worked on it all summer to get it on the road. My wife and 3 daughters love that car, me as well. Its my daily driver. I sincerely appreciate all the help!
    • Like Like x 2
    • Dartsun
      Dartsun Member
      834
      457
      Feb 12, 2012
      Springfield Oregon
      Local Time:
      6:45 AM
      I’ve got a cast iron intake and a D4B. The D4B is in decent shape I bought it off here and ended up using a LD4B instead with 66 heads. I’m in Springfield Oregon.
      • Like Like x 1
      • 1964Dart273
        4
        2
        Oct 16, 2019
        Molalla Oregon
        Local Time:
        6:45 AM
        How can i contact you? It wouldn't let me post my phone number...
      • Dartsun
        Dartsun Member
        834
        457
        Feb 12, 2012
        Springfield Oregon
        Local Time:
        6:45 AM
        Goto start a conversation I can get you my number thru there
      • 1964Dart273
        4
        2
        Oct 16, 2019
        Molalla Oregon
        Local Time:
        6:45 AM
        I sent my info. My number is also in the photo i posted above on the sign.
      • Moparlouie
        Moparlouie Well-Known Member
        258
        24
        Nov 29, 2012
        CT
        Local Time:
        8:45 AM
        I have a 4bbl but the choke bowl has been modified, cut out for a holley I believe.
