273 Carb upgrade
Fuel and Air Systems
  1. Michael Brisebois
    Michael Brisebois FABO Gold Member FABO Gold Member
    217
    102
    Nov 26, 2017
    Huntington, Ma
    Local Time:
    5:11 PM
    I Have a 66 Barracuda with the "ol reliable" 273 2bbl. I'd like to go to a 4bbl and NOT really do anything else to the engine.
    Not looking to race, or anything like that...just a little more pedal. Anyone care to share an opinion?
  2. grimreaper
    grimreaper Cross Member
    3,322
    565
    Jul 8, 2005
    Gillette, WY
    Local Time:
    3:11 PM
    What intake manifold do you plan to use?
  3. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    37,784
    20090
    Jan 18, 2006
    Iowa
    Local Time:
    4:11 PM
    Stock manifold and a 500- 600 Edelbrock works well. A Edelbrock LD4B manifold works well also.
    • Agree Agree x 3
    • Michael Brisebois
      217
      102
      Nov 26, 2017
      Huntington, Ma
      Local Time:
      5:11 PM
      Looking for a recommendation on that as well. I don't want to get into a cam, or head change
    • grimreaper
      3,322
      565
      Jul 8, 2005
      Gillette, WY
      Local Time:
      3:11 PM
      If you can find a fctory 273 4bbl manifold they work OK. As Toolmanmike said the Ld4B is a good choice too.
      • Like Like x 1
      • rumblefish360
        rumblefish360 so close yet so far away
        34,408
        6321
        Jun 21, 2005
        New York, on a Island
        Local Time:
        5:11 PM
        Just be careful of that early intake bolt angle. Being it is a 2 year run thing, aluminum intakes could be a pain to find. IDK
        ALSO! A 500 cfm Carter/Edelbrock would be very good on top. I myself would use the new AVS II 500 cfm unit.
        • Like Like x 1
        • Michael Brisebois
          217
          102
          Nov 26, 2017
          Huntington, Ma
          Local Time:
          5:11 PM
          Are you saying that a 1966 273 is different a later year 273/318/340/360?
        • toolmanmike
          37,784
          20090
          Jan 18, 2006
          Iowa
          Local Time:
          4:11 PM
          64 and 65 are smaller bolts at a different angle. 66 and newer are the same.
        • rumblefish360
          34,408
          6321
          Jun 21, 2005
          Local Time:
          5:11 PM
          Sorry, no. My bad if I misread.
          The first two years are different. ‘64 & ‘65.
          The attaching bolt hardware is smaller in diameter.
          It also is drilled at a different angle.
          There! I said it twice.
          For the owners of the first two years of the 273, Believe it or not, disregard at your own risk. I’ll just say “I told you so.”
        • rumblefish360
          34,408
          6321
          Jun 21, 2005
          Local Time:
          5:11 PM
          And now reading back, I did misread.
          Sorry, my bad!
        • 318willrun
          318willrun Stomper 4x4... we kept energizer in business
          8,273
          6551
          Sep 13, 2013
          I'm here
          Local Time:
          4:11 PM
          Weiand action plus would work well also, and are reasonably priced new or 2nd hand.
          • Agree Agree x 1
          • JBurch
            JBurch Well-Known Member
            1,674
            783
            Oct 17, 2009
            Owego, NY
            Local Time:
            5:11 PM
            In the realm of " a little more pedal and not looking to race " you have actually a lot of choices: you have 66-67 factory cast iron 4 bbl, LD4B Edelbrock, Edelbrock Performer, Holley Street Dominator, even the despised Edelbrock SP2P; they all amount to "more" intake than the 2 bbl on the engine now. The factory cast iron intake is kinda rare, most popular with the resto crowd which can drive it's price, the LD4B is a Holy Grail intake and sellers ask money for them, the Performer is common, people step over them looking for an LD4B which makes them; the Performer; affordable, the Holley Street Dominator is an aluminum up-graded version of the factory cast iron, would be more suitable with more up-grades to your engine, the SP2P is a wild card here, designed in the early days of smog control, ment to be a low rpm boost in torque and fuel economy, some people are almost willing to pay people to take them off their hands; I will probably be burned in effigy for mentioning it.
            Carburetor choices, something in the range of 450 to 600 CFM
            You didn't say if standard or auto trans, if auto you will need kick down linkage
            Good luck!!
            • Agree Agree x 1
            • toolmanmike
              37,784
              20090
              Jan 18, 2006
              Iowa
              Local Time:
              4:11 PM
              There you have it!
            • Michael Brisebois
              217
              102
              Nov 26, 2017
              Huntington, Ma
              Local Time:
              5:11 PM
              It's a 4 speed,
              I was leaning towards a 500cfm. Too much cfm in the past left me with a bog from the start off. I had a 69 340 many years ago and put on a variety of carbs on it, but kept coming back to the Carter 600 or 650 ( not sure now which it was)
            • Dartsun
              Dartsun Well-Known Member
              596
              217
              Feb 12, 2012
              Springfield Oregon
              Local Time:
              2:11 PM
              I’d recommend a 500cfm. I had a 600 edelbrock on my 65 273 2 barrel engine and was To much, cast iron intake. Dustin
            • dart4forte
              dart4forte FABO Gold Member FABO Gold Member
              4,207
              615
              May 28, 2004
              Mesa, AZ
              Local Time:
              10:11 PM
              LD4B Edelbrock, Carter Competition 9636, 625 CFM, Electronic ignition. That will put some scoot into that fish. Later mods, 920 heads, you can install a .028 headgasket and get the CR up to 9 to 1, Isky style E4 camshaft, Comp Cams has a grind. Of course, the 273 needs some gears to get into the powerband quickly. Good start are some 3.23s
              This was one of my 273 projects from years ago
              • Like Like x 1
              • Thanks! Thanks! x 1
              • rumblefish360
                34,408
                6321
                Jun 21, 2005
                Local Time:
                5:11 PM
                Edit to the otherwise great description above would be;
                The Holley Street Dominator is a very low single plane intake much like the early 273’s.
                The Edel. Performer is very much like the factory cast iron intake. As such, it will perform just as well.
                The sp2p is a intake designed for mileage and torque increases. Not smog.
              • toolmanmike
                37,784
                20090
                Jan 18, 2006
                Iowa
                Local Time:
                4:11 PM
                I like the way you think.
                273 Build
                • Like Like x 1
                • dart4forte
                  4,207
                  615
                  May 28, 2004
                  Mesa, AZ
                  Local Time:
                  10:11 PM
                  I wouldn't even consider a SP2P
                  • Agree Agree x 2
                  • rumblefish360
                    34,408
                    6321
                    Jun 21, 2005
                    Local Time:
                    5:11 PM
                    Not unless I’m looking to do better than 25mpg’s!
                  • JBurch
                    1,674
                    783
                    Oct 17, 2009
                    Owego, NY
                    Local Time:
                    5:11 PM
                    I threw that out there even though people hate it based mostly on the fact that the OP stated he wanted "a little more pedal" and wasn't looking to dive any further into his engine other than carb and intake swap. Stock 2 bbl 273 is gonna be all done by about 4500 rpm, about the same place an SP2P is gonna lay down, seemed to me that, that was a good balance, it can be had cheep, it's just the nitch it was designed for.
                    The OP can do what ever he wishes to do, what ever his wallet will let him......it is/was just an idea along the lines of what the OP asked for....
                  • dart4forte
                    4,207
                    615
                    May 28, 2004
                    Mesa, AZ
                    Local Time:
                    10:11 PM
                    Point taken....
                  • Slantsix64
                    Slantsix64 Well-Known Member
                    1,308
                    298
                    May 11, 2014
                    SGV
                    Local Time:
                    4:11 PM
                    I got great mileage with a 500 cfm eddy lb4d on a 273 . Great intake for a 273 or a 318
                  • toolmanmike
                    37,784
                    20090
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    4:11 PM
                    I have a stock cast 273 on mine with a 600 Edelbrock. I got 18 mpg on a 4 hour trip last weekend. I would like to put on a SP2P or a LD4B for a drivability and mileage test.
