273 Commando Air Cleaners and Valve Covers
Early A-Body Discussions
  1. Overdrive
    Overdrive Entropy User
    31
    2
    Oct 27, 2006
    Manitoba, Canada
    Local Time:
    6:37 PM
    Are there other air cleaner lids that are the same as the 273 commando air cleaners? I am trying to find one for my '65 Valiant, and the chrome Commando air cleaners are a little more money than I have to spend on one. Are there any differences (early to late 273 Commando). Also, would they flow enough for a 360? I'm trying to make my engine look like a 273.
    Also, are the Commando Valve covers the same as a regular 273 cover except for the aluminum trim?
  2. Jim Lusk
    Jim Lusk Well-Known Member
    5,163
    1512
    Mar 8, 2006
    Fresno, CA
    Local Time:
    4:37 PM
    The same air cleaner was used on some big blocks, but was painted black. There is no repop of the correct silk screened aluminum applique. There were also some with the nipple for the valve cover breather and some without. Every one I have owned had the nipple, but that's probably because I am in California.
    The valve covers are close, but they also had a special wire holder by the carb on the passenger side cover. 65 and 66 used the same covers. 67 was the first year of the grommet for the PCV valve.
  3. jahsh
    jahsh Well-Known Member
    135
    1
    Jun 20, 2004
    Sacramento, CA
    Local Time:
    12:37 AM
    I have also seen some early /6 motors with the same air cleaner.
    The thing I always have had issue with is that the air cleaner never seems to fit with a high rise manifold, so if you are building a stout 360, it could be difficult dealing with hood clearance.
    • Thanks! Thanks! x 1
    • Jim Lusk
      5,163
      1512
      Mar 8, 2006
      Fresno, CA
      Local Time:
      4:37 PM
      Yes, some slants had the same lid, but the base is obviously different.
    • 65Val
      65Val Average Length Member
      5,297
      1248
      Oct 14, 2005
      Victoria, BC, Canada, EH!
      Local Time:
      4:37 PM
      I have to agree with Jim on most of what he said. Yes, the same air cleaner,albeit, black instead of chrome came on some early big blocks. I had a '66 Charger 383 that had a black one. The slant 6 air cleaner used the same top cover, but the lower plate had the smaller opening for a one barrell carb. The nipple was used on C.A.P. cars.
      The 2 bbl valve covers had the spark plug wire holders "welded" to the valve cover itself and the Commando ones had them on the fins. If you were careful, you could remove the holders on the 2bbl ones,paint them wrinkle black and glue the aluminum fins on. Regarding the different years of Commando covers, they do differ from year to year.....
      1965 - "stove pipes" on top for PCV and breather;3 small wiring holders on
      the pass.side cover; plug wires used individual plastic grommets for
      retention in the fins
      1966 - stove pipes on top for PCV and breather;2 small and 1 large wire
      holder on pass side cover;individual grommets for wires
      1967 - 1 stove pipe for breather and rubber grommet for PCV;2 small and
      and 1 large wire holders on pass side;fins had slots between holes for
      using plastic double wire holders.
      Hope this helps...
    • cavemanmoron
      cavemanmoron Well-Known Member
      1,785
      4
      Dec 12, 2005
      fn32
      Local Time:
      7:37 PM
      If your going to use a newer carb, the air cleaner base won't fit.
      I had an old small "Universal" 10 inch {Or maybe it was 9 inch?}
      ai cleaner, and used the base from that.
      For the air filter, I drove the car to Advance Auto Parts store,
      and took the base, and top inside. I found a filter that fit,
      on the second try. {Fit some kind of Ford by the box description}
      My top, I bought on Ebay, it was from a Slant 6 engine;
      someone had had it chromed over the years past. :)
      [​IMG]
      • Like Like x 1
      • moparlee
        moparlee 64 Valiant
        1,404
        40
        Aug 18, 2004
        Joplin, Mo
        Local Time:
        6:37 PM
        1965 two barrell air cleaner top and bottom off a 65 satellite 273 pcvolk@comcast.net
        Not sure if this helps or not, but it's was in the forsale deal in Moparts.
        Lee
      • 65s
        65s Well-Known Member
        1,396
        27
        Dec 4, 2005
        Ottawa, Ontario
        Local Time:
        7:37 PM
        You can use any base plate (Mr.Gasket for example) with the chrome upper and just use a low profile air filter which will make the chrome upper drop down around your carburetor, thereby allowing hood clearance if you have an aftermarket carb or intake manifold that's a little too high.
        • Like Like x 1
        • dart4forte
          dart4forte FABO Gold Member FABO Gold Member
          4,928
          1452
          May 28, 2004
          Mesa, AZ
          Local Time:
          12:37 AM
          The 273 aircleaner is actually smaller in diameter than the big block aircleaners if you are talking about the re-bop unsilanced aircleanerl. The base is also smaller in diameter to fit the smaller AFB. If I'm not mistaken the aircleaner base on the D/Dart was modified to fit the Holley carb.
        • Jim Lusk
          5,163
          1512
          Mar 8, 2006
          Fresno, CA
          Local Time:
          4:37 PM
          No, we're not talking about the 68-69 unsilenced air cleaner. The black one was used on mid-60s big blocks (the 64 300K I had used that air cleaner since it was a base model with the 360hp single four barrel motor). The D/Dart used a completely different air cleaner of unknown origin.
        • Overdrive
          31
          2
          Oct 27, 2006
          Manitoba, Canada
          Local Time:
          6:37 PM
          Height might be a problem for me. I was hoping to use a Thermoquad on a Mopar Performance M1 single plane. That will likely put me into the hood. I am tossing around the idea of using a repro '65 Hemi S/S scoop, so cutting my not so nice hood is an option if I just need an extra inch or two. As for lids, I have 3 or 4 '65 slant six tops I can use! I thought they looked similar! I wasn't sure if they were the same or not. I could perhaps section one to make it lower. As for a base, I don't know. Perhaps some sort of drop base that can fit over the gi-normous thermoquad?
        • 65dartman
          65dartman Active Member
          29
          0
          Nov 14, 2005
          Colorado
          Local Time:
          5:37 PM
          I am using all the Hipo 273 stuff on my 360 in my 65, just find an aftermarket base for the air cleaner just as some of the other people mentioned. Works fine! I'd post a pic, but I haven't figured that part out yet! :sad:
        • dart4forte
          4,928
          1452
          May 28, 2004
          Mesa, AZ
          Local Time:
          12:37 AM
          My assumption is wrong, yes the aircleaner is pretty much the same as the black claeaners used in the mid 60's. The D/Dart however used the 273 aircleaner with a modified base. I say that because we a have a local fella here in town that owns an original D/Dart
        • Overdrive
          31
          2
          Oct 27, 2006
          Manitoba, Canada
          Local Time:
          6:37 PM
          So, the filter element for the HP 273 should be the same as a slant six then, assuming the lid is the same? The listings i found for slant six application show it as being 8" O.D., 6.47" I.D. 3.00" tall. Do these dimensions sound right? Oh, and only flowing 90 CFM... that for sure is no good for any performance engine!
          Anybody recall what filter part # to use for a 273HP air filter?
        • '64 Cuda
          '64 Cuda Well-Known Member
          3,662
          7
          Jan 19, 2006
          South East South Dakota
          Local Time:
          6:37 PM
          I remember long ago we put a 273 Commando chrome air cleaner top on my moms '65 slant six. It fit the element perfectly but was larger in diameter so it allowed air in more easily around the bottom. Gave the engine that "WAAAAAAAA..." sound when accelerating, like when you turn an air cleaner lid upsid down. Eliminated the "silencing" of the air cleaner design. I'm sure it flowed more than 90 cfm that way.
          :burnout:
        • cavemanmoron
          1,785
          4
          Dec 12, 2005
          fn32
          Local Time:
          7:37 PM
          Nope the element is not the same,
          from what I recall.
          If I recall correctly; to use the Edelbrock carb, vs a 1965 era AFB,
          I used a 9 inch universal base. $19.99 for the whole air cleaner,
          i threw away the rest.
          4 bbl 273;
          Part Number: CA162 Fram
          2bbl 273;
          Part No. CA160 Fram
          Slant 6 225/ 170
          Part No. CA146 Fram
          The Slant 6 lid might be useable,
          with a 4bbl base. They are all small.
        • Overdrive
          31
          2
          Oct 27, 2006
          Manitoba, Canada
          Local Time:
          6:37 PM
          Does anybody have measurements of a 273 4BBl lid vs. a 225 slant six lid? (diameter, height, diameter of the "rings" on the top side, etc). I think that would get me pointed in the right direction.
        • dart4forte
          4,928
          1452
          May 28, 2004
          Mesa, AZ
          Local Time:
          12:37 AM
          I think I have a small diameter base if you need one
        • Overdrive
          31
          2
          Oct 27, 2006
          Manitoba, Canada
          Local Time:
          6:37 PM
          is it a 4bbl base? I might be interested, unfortunately, I was planning on using a thermoquad, so it may not work. I'll measure my slant six lid today and see what its dimensions are.
        • dart4forte
          4,928
          1452
          May 28, 2004
          Mesa, AZ
          Local Time:
          12:37 AM
          I'll have to take a look
        • Overdrive
          31
          2
          Oct 27, 2006
          Manitoba, Canada
          Local Time:
          6:37 PM
          I found a used Fram CA160 filter laying in the trash and tried it in my slant six lid. (I think it was a CA160... came from a '67 Polara with a 318). It seems to fit the registers good. there's around 1/4 inch clearance all the way around... kinda tight, no? If that's the same as a 273 4bbl, then that means the lids should be the same then (there are two locating grooves on the lid... an inner one for the TINY slant six filter... and an outer one about 3/4 inch or so out from the inner one). Anyhow, trying it on a thermoquad, it's going to be tight... can't really fit a drop base with a filter that small. But the TQ needs a base with a hole 5 1/8 inches in diameter.
        • Overdrive
          31
          2
          Oct 27, 2006
          Manitoba, Canada
          Local Time:
          6:37 PM
          I finally measured my slant six lid. 11" diameter on the outside edge.
        • ddartdude
          ddartdude Well-Known Member
          643
          268
          Jan 1, 2007
          Port St. Lucie, Florida
          Local Time:
          6:37 PM
          The D/Dart air cleaner is of unknown origin. It measures 14 in diameter and is 4 5/8 high. It's nothing like the chrome one that's on the 273 Commando engine. It's more like the big block air cleaner but with a smaller center for the wing nut.
          I've attached a picture of one.
        • moparlee
          moparlee 64 Valiant
          1,404
          40
          Aug 18, 2004
          Joplin, Mo
          Local Time:
          6:37 PM
          DDartDude,
          That's neat to know.
          Lee
        • Overdrive
          31
          2
          Oct 27, 2006
          Manitoba, Canada
          Local Time:
          6:37 PM
          D/Dart stuff is always interesting to see... I wonder what the original application for that lid was? It's got to be from some common application. I might just have to use an aftermarket air cleaner. We'll see. I'm getting my intake manifold next week, so I'll be able to try and measure.
