273 Commando Piston Dome Volume
Small Block Mopar Engine
  1. Alpine White
    Alpine White Member
    17
    21
    Aug 5, 2018
    Australia
    Local Time:
    1:52 PM
    Hey Guys,
    I’ve recently purchased a new set of Rebuilders Choice 4bbl Commando Pistons and need the dome volume in cc’s to calculate my CR. I’ve contacted Rebuilders Choice but they are unable to provide the information but said they made them from factory 273 Commando Pistons.
    I’ve attached a photo of my one of my new pistons and a photo I found on the net of an original Commando piston.
    Any help would be greatly appreciated.
    Cheers guys
    Luke
  2. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    37,849
    20168
    Jan 18, 2006
    Iowa
    Local Time:
    10:52 PM
    I have no answer to your question but you are lucky. Egge's were the only piston available when I rebuilt my 273 10+ years ago. That info wasn't available for me either. I got a cc kit and measured with a piston installed.
  3. Plymouth 65
    Plymouth 65 Floorable Deplorable
    694
    490
    Jun 27, 2016
    Mich
    Local Time:
    11:52 PM
    Stock Commando pistons and heads were 10.5 to 1 compression ratio. 65'
  4. Alpine White
    Alpine White Member
    17
    21
    Aug 5, 2018
    Australia
    Local Time:
    1:52 PM
    I’ve been really lucky I think. Parts are very expensive here in Australia. I purchased a full engine rebuild kit out of the States for the price that I would have paid for pistons and rings here in Australia.
    I’ve been reading anywhere from 15-11.5cc’s for the Commando Pistons. I read a guy cc’d a set and they came in at 11.5 but just wanted to be certain.
    • Agree Agree x 1
    • toolmanmike
      37,849
      20168
      Jan 18, 2006
      Iowa
      Local Time:
      10:52 PM
      Yes but the op is looking for the dome volume so he can figure his ratio.
    • toolmanmike
      37,849
      20168
      Jan 18, 2006
      Iowa
      Local Time:
      10:52 PM
      I like the looks of these pistons but I would think it might be a good idea to smooth the tops to prevent detonation. Maybe @yellow rose, or @rumblefish360 can chime in with a recommendation. What say you @RustyRatRod, or @krazykuda ?
      • Agree Agree x 1
      • yellow rose
        yellow rose Doctor of Thinkology.
        16,097
        12529
        Jun 19, 2015
        Living on the razors edge
        Local Time:
        8:52 PM
        The only way I know to know for sure is to do the .500 downfill and then you'll know for sure what you have. I do have an old DC manual around here somewhere. I'll dig it out and see what I can find.
        • Like Like x 3
        • Agree Agree x 1
        • toolmanmike
          37,849
          20168
          Jan 18, 2006
          Iowa
          Local Time:
          10:52 PM
          That's the procedure I used.
          • Agree Agree x 1
          • krazykuda
            krazykuda FABO Gold Member FABO Gold Member
            47,318
            12293
            Aug 20, 2007
            Orland Park, IL
            Local Time:
            10:52 PM
            Use this procedure with the .500" down fill to find the true compression of your combo...
            How to Check Compression
            • Agree Agree x 1
            • Alpine White
              Alpine White Member
              17
              21
              Aug 5, 2018
              Australia
              Local Time:
              1:52 PM
              Thanks for the response guys, it’s appreciated. Does anyone know what cc’s the factory Commando pistons were? There is so much literature on the net in regards to practically everything else bar that.
            • toolmanmike
              37,849
              20168
              Jan 18, 2006
              Iowa
              Local Time:
              10:52 PM
              Hey Karl, please read post #6 then look at the rough cast on the tops of the new pistons.
            • toolmanmike
              37,849
              20168
              Jan 18, 2006
              Iowa
              Local Time:
              10:52 PM
              I really wish I would have checked before I took mine apart.
              • Agree Agree x 1
              • rumblefish360
                rumblefish360 so close yet so far away
                34,456
                6356
                Jun 21, 2005
                New York, on a Island
                Local Time:
                11:52 PM
                That is the weirdest piston top I have ever seen, like a kit, finish to suite the need.
                • Agree Agree x 1
                • toolmanmike
                  37,849
                  20168
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  10:52 PM
                  It sure looks sand cast. I would smooth them and then cc the chambers.
                • Wyrmrider
                  Wyrmrider Well-Known Member
                  1,233
                  455
                  Sep 5, 2016
                  los angeles
                  Local Time:
                  8:52 PM
                  we can walk you through the .500" downfill method if need be- oh I see a link but have not looked at it
                  closed chamber heads?
                  agree on polishing those piston heads
                  original piston would not have been coated in 65- what you got there?
                  you might want to od hone those pistons or even give them a light knurl on the thrust side, run a bottle brush or brake hone through the pin bores- anything to hold some oil- lightly
                  • Agree Agree x 1
                  • Alpine White
                    Alpine White Member
                    17
                    21
                    Aug 5, 2018
                    Australia
                    Local Time:
                    1:52 PM
                    My mechanic as pretty switched on so can work it out. RC said they made them from factory 273 Commando pistons so was curious as to what the factory specs were. I did read on a thread somewhere that a guy did cc the pistons I have and they came in at 11.5.
                    Yep, closed chamber heads. It’s a 1965 Australian built AP6 4PV factory V8 car. We missed out on the 4bbl Commando version here in Australia so am building it to as close a spec as I can. I have an Edelbrock LD4B, Edelbrock 500cfm 4bbl Thunder Series carby, and have had my cam reground to a similar grind, bit more duration. Components are going away to be balanced this week then a dummy assembly to chase around 10.2-1. I’ll attach a photo of the car and a photo of the cam specs.
                    • Like Like x 1
                    • perfacar
                      perfacar Well-Known Member
                      1,015
                      206
                      Mar 1, 2006
                      renton,wa
                      Local Time:
                      8:52 PM
                      the dome volume is 16 cc. this is from TRW and ross and other dealers. NHRA specs show the dome volume. it's in engine specs on their website.
                      • Thanks! Thanks! x 1
                      • Agree Agree x 1
                      • Alpine White
                        Alpine White Member
                        17
                        21
                        Aug 5, 2018
                        Australia
                        Local Time:
                        1:52 PM
                        Really? Wow that’s a lot more than the 11.5cc I read elsewhere. Will have to measure them up as that’s a lot of variance.
                        Cheers mate.
                        • Like Like x 1
                        • krazykuda
                          47,318
                          12293
                          Aug 20, 2007
                          Orland Park, IL
                          Local Time:
                          10:52 PM
                          If you run the book numbers for the compression, they do not work out with the advertised compression... That's why I came up with the method to check your combination vs going by book numbers...
                          • Agree Agree x 1
                          • krazykuda
                            47,318
                            12293
                            Aug 20, 2007
                            Orland Park, IL
                            Local Time:
                            10:52 PM
                            Doing a clean up cut on the top of the pistons will help a little, but I do not think that it is absolutely critical... I don't see much sharp edges that can become hot spots... That little bit of 'porosity' shouldn't hurt it...
                            • Agree Agree x 1
                            • krazykuda
                              47,318
                              12293
                              Aug 20, 2007
                              Orland Park, IL
                              Local Time:
                              10:52 PM
                              The Edelbrock LD4B is made for the 66 and later head bolt pattern.... The D4B is the one made for the early 64 & 65 heads with the unique 5/16" bolt pattern...
                              I would recommend using a set of 66 or 67 heads instead to be more compatible with the intake bolt pattern, or you could enlarge the intake bolt holes in the manifold so the bolts will go in properly... But if you want to keep the intake manifold virgin, then I would go with a set of 273/318 heads from 66 or later... 66 & 67 will have a little smaller combustion chambers to help keep the compression up.... The edelbrock intakes are getting harder to find and it may be easier to find compatible heads for the LD4B or you will have to modify the intake bolt holes to use the LD4B on the early 65 heads...
                              • Agree Agree x 2
                              • Alpine White
                                Alpine White Member
                                17
                                21
                                Aug 5, 2018
                                Australia
                                Local Time:
                                1:52 PM
                                Definitely no sharp bits, I’ll post a better photo.
                                • Like Like x 1
                                • Alpine White
                                  Alpine White Member
                                  17
                                  21
                                  Aug 5, 2018
                                  Australia
                                  Local Time:
                                  1:52 PM
                                  I’ve had 8 heads crack tested (4 x closed chamber & 4 x open chamber) and they’ve all come back cracked, either through the combustion chamber or around the two end bolt holes closest to the exhaust manifolds. I’ve just payed for a NOS set of closed chamber heads, which is what I was wanting anyway to chase the CR of the Commando. I know I’m going to have to alter the bolt angles on my LD4B but I’m ok with that, as you said these Edelbrock manifolds are getting hard to come by and these cracked heads have put a real dint in my budget. I appreciate you taking the time to reply to me, it’s really appreciated mate.
                                  • krazykuda
                                    47,318
                                    12293
                                    Aug 20, 2007
                                    Orland Park, IL
                                    Local Time:
                                    10:52 PM
                                    That sounds like a good way to go with what you have and modify the intake bolt holes to fit the older style heads...
                                    • Agree Agree x 1
                                    • Alpine White
                                      Alpine White Member
                                      17
                                      21
                                      Aug 5, 2018
                                      Australia
                                      Local Time:
                                      1:52 PM
                                      I’ve had my cam reground with this grind, should hopefully wake her up a little with the 500cfm Edelbrock on top of the LD4B.
                                      • Like Like x 1
