[SOLD] 273 Commando Pistons
Mopar Mechanical Parts For Sale
Thread Status:
  1. SSVDP
    SSVDP FABO Gold Member FABO Gold Member
    4,239
    3959
    Feb 6, 2009
    Clarksville, Tn
    Local Time:
    12:48 AM
    Contact Seller
    I have kept this set of 273 "Commando" pistons for a few years but it doesn't look like I will be using them so I figured I would offer them here for $120 plus shipping ( they should fit in a USPS medium flat rate box for $13.60).
    These pistons I were used on the Plymouth " Commando" & Dodge "Charger" 235 horse power high performance versions of the 273 V-eight engines with 10.5:1 compression ratio ( in reality probably not that high but higher than the two barrel version).
    There are four pistons which are part number "661" and all have a "C" stamped on the top; There are four pistons which are part number "658" and three have a "C" stamped on the top & one with a "D".
  2. DavidLee
    DavidLee Well-Known Member
    329
    71
    Aug 1, 2011
    Torrance, CA
    Local Time:
    9:48 PM
    standard bore?
  3. SSVDP
    4,239
    3959
    Feb 6, 2009
    Clarksville, Tn
    Local Time:
    12:48 AM
    I have not measured these so I suppose it's "standard bore".
    I think the "C" letters are piston sizes used during plant assembly.
  4. SSVDP
    4,239
    3959
    Feb 6, 2009
    Clarksville, Tn
    Local Time:
    12:48 AM
    Hey? What happened to my pics in first post?
    Here they are:
  5. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    25,898
    5342
    Aug 28, 2009
    Ontario
    Local Time:
    11:48 PM
    Can you measure bore? Also pin bore?
  6. SSVDP
    4,239
    3959
    Feb 6, 2009
    Clarksville, Tn
    Local Time:
    12:48 AM
    No, I have no way to measure these.
  7. barracudadave67
    barracudadave67 FABO Gold Member FABO Gold Member
    965
    310
    May 22, 2004
    Burlington, Wi.
    Local Time:
    11:48 PM
    Those look like stock pistons. If they were oversize they would be marked on top. Being as how they are not marked on top, probably means they are standard bore
    TThey would be good for rebuilding a nice original block.
    TThose are factory hipo pistons.
    • Agree Agree x 2
    • Like Like x 1
    • chryslerfat
      chryslerfat Well-Known Member
      11,708
      3110
      Aug 23, 2008
      Monroe,Michigan
      Local Time:
      12:48 AM
      They do look to be stock bore and from what I have read the original pistons were 10.5 compression and the aftermarket ones being made today are further in the cylinder bringing the compression down about to around 9
      • Agree Agree x 1
      Thread Status:
