1. 65formula
    65formula Well-Known Member
    129
    27
    Mar 20, 2018
    Carson California
    Local Time:
    5:45 PM
    I found a fairly complete 273 commando with block cast number 2465330-3 and below left side head stamp number A2731022
  2. toolmanmike
    toolmanmike Moderator Staff Member FABO Gold Member
    62,391
    51599
    Jan 18, 2006
    Iowa
    Local Time:
    7:45 PM
    Before 1968 I believe, vin numbers weren't stamped on engines. That is a plain old 273 that could have came out of pretty much any A body. The engine has some value to the right person as well as the Commando components.
  3. 65formula
    129
    27
    Mar 20, 2018
    Carson California
    Local Time:
    5:45 PM
    Good to know...
    Thanks
  4. trapster
    trapster Well-Known Member
    2,672
    283
    Feb 19, 2009
    Central Florida
    Local Time:
    8:45 PM
    What is the casting date on the block ?
  5. 65formula
    129
    27
    Mar 20, 2018
    Carson California
    Local Time:
    5:45 PM
  6. trapster
    2,672
    283
    Feb 19, 2009
    Central Florida
    Local Time:
    8:45 PM
    other side i believe (passenger side)
  7. 65formula
    129
    27
    Mar 20, 2018
    Carson California
    Local Time:
    5:45 PM
    my bad..
    I just started working...
    I’ll take a pick in my break time..
    And post more pictures
  8. Cuda Al
    Cuda Al Well-Known Member
    1,550
    1811
    Oct 21, 2007
    Lompoc, CA
    Local Time:
    5:45 PM
    Also on the front of the block (near head on driver side) it may be stamped A-273, B-273, C-273 etc.
    Alan
  9. 65formula
    129
    27
    Mar 20, 2018
    Carson California
    Local Time:
    5:45 PM
    Yes that one is A2731022
  10. 65formula
    129
    27
    Mar 20, 2018
    Carson California
    Local Time:
    5:45 PM
  11. Cuda Al
    1,550
    1811
    Oct 21, 2007
    Lompoc, CA
    Local Time:
    5:45 PM
    65 Model year assembled 10-22-64
    Alan
  12. 65formula
    129
    27
    Mar 20, 2018
    Carson California
    Local Time:
    5:45 PM
    Thank you so much Alan...!!
  13. 65Val
    65Val Average Length Member
    5,249
    1257
    Oct 14, 2005
    Victoria, BC, Canada, EH!
    Local Time:
    5:45 PM
    To confirm it's an actual Commando, you'll have to check to see if it has the 10.5:1 hi-comp pistons, etc, that all true Commando's came with.
    • Agree Agree x 1
    • Cuda Al
      1,550
      1811
      Oct 21, 2007
      Lompoc, CA
      Local Time:
      5:45 PM
      Correct, the blocks, cranks, rods, heads are all the same.
      Commando = Pistons, cam, intake, (valve covers, carb, distributor, air cleaner...)
      Alan
    • 65formula
      129
      27
      Mar 20, 2018
      Carson California
      Local Time:
      5:45 PM
      So it’s actually a commando then..?
      Cause that’s what it has right now
    • 65Val
      5,249
      1257
      Oct 14, 2005
      Local Time:
      5:45 PM
      Appears to be an aftermarket intake on it, but the real test is having the "domed" hi-comp pistons, dual point dizzy, slightly hotter cam, etc, etc. I see in your other thread "31" under "AB", so I believe that indicates the car came with a Commando engine.
    • 65formula
      129
      27
      Mar 20, 2018
      Carson California
      Local Time:
      5:45 PM
      Yes
    • 65Val
      5,249
      1257
      Oct 14, 2005
      Local Time:
      5:45 PM
      Also appears to have been changed over to the more modern dual braking system. The original would have been a single pot master cylinder. Good feature!
    • 65formula
      129
      27
      Mar 20, 2018
      Carson California
      Local Time:
      5:45 PM
      Actually no..
      The power disc brakes was a dealer option...
      On the tag under the letter “C” has the number 5 which is power brakes option
    • 65formula
      129
      27
      Mar 20, 2018
      Carson California
      Local Time:
      5:45 PM
    • 65Val
      5,249
      1257
      Oct 14, 2005
      Local Time:
      5:45 PM
      You can have power disc's, but you'll still have the single master cylinder.
      Kinda hard to read that, but I still maintain the dual system master cylinder was not available 'til '67...just the single pot unit up to then...
      Early Valiant Barracuda Club - dual master cylinder
      • Agree Agree x 2
      • 65formula
        129
        27
        Mar 20, 2018
        Carson California
        Local Time:
        5:45 PM
      • KosmicKuda
        KosmicKuda FABO Gold Member FABO Gold Member
        2,216
        952
        Jan 15, 2011
        N Ohio
        Local Time:
        8:45 PM
        If you have a snall enough boroscope, you could look through a spark plug hole to see if the piston is domed.
      • 65formula
        129
        27
        Mar 20, 2018
        Carson California
        Local Time:
        5:45 PM
        I’m 100% sure is domed..
        One of the heads is off..
        I’ll take pictures so I can show you guys..
      • pishta
        pishta I know I'm right....
        21,386
        10776
        Oct 13, 2004
        Tustin, CA
        Local Time:
        5:45 PM
        disk brake option would have the extended reservoir donut on the MC.
