273 crankshaft, 5.2 Magnum
Small Block Mopar Engine
  1. Maistrelli
    Maistrelli Active Member
    35
    8
    Jul 16, 2018
    Ohio
    Local Time:
    11:13 AM
    Can a 273 crank be used in a 5.2 Magnum engine? Magnum damper on 273 crank?
  2. nm9stheham
    nm9stheham Well-Known Member
    10,225
    2558
    Dec 20, 2013
    Waynesboro, VA
    Local Time:
    11:13 AM
    Balance has to be considered. I can't quite figure out if the crank balance is the same. Magnum 5.2L piston+pin+ring weights are very close to LA 318, but the Magnum rods may not be the same. I just don't have the rod data.
    What year of 273 crank?
  3. pishta
    pishta I know I'm right....
    13,924
    3624
    Oct 13, 2004
    Tustin, CA
    Local Time:
    8:13 AM
    magnum rods have a different width little end, narrower. So thats potentially less weight right there. Also lack of fuel pump eccentric on magnum crank.
  4. Demonracer
    Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
    2,030
    250
    Jan 31, 2010
    Cleveland, Texas
    Local Time:
    10:13 AM
    The fuel pump eccentric is on the camshaft, not the crankshaft.
    • Like Like x 1
    • Agree Agree x 1
    • Maistrelli
      35
      8
      Jul 16, 2018
      Ohio
      Local Time:
      11:13 AM
      1965
    • RustyRatRod
      RustyRatRod 30 Degrees Outta Whack FABO Gold Member
      48,561
      14505
      Jun 7, 2010
      Georgia
      Local Time:
      11:13 AM
      It should bolt in and go. All 318s were neutral balanced that I know of.
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • pishta
        13,924
        3624
        Oct 13, 2004
        Tustin, CA
        Local Time:
        8:13 AM
        Doh! Of course I knew that....WTH?
        • Like Like x 2
        • Plymouth 65
          Plymouth 65 Floorable Deplorable
          654
          446
          Jun 27, 2016
          Mich
          Local Time:
          11:13 AM
          The 1965 273 crankshaft has the small torque converter pilot diameter. Just so you're aware! 65'
          • Like Like x 1
          • Agree Agree x 1
          • nm9stheham
            10,225
            2558
            Dec 20, 2013
            Waynesboro, VA
            Local Time:
            11:13 AM
            Yes, that's a fit problem for the trannie. The OP would have to have the crank pilot hole turned out.
            I worked out the bobweights with the data I have. 273 and 5.2L are pretty close but it still may be off enough to be 10-20 grams off of balance..... or some of my data is a bit off.
            I think RRR is correct on both being neutral balanced for the dampers and TC/flex-plate/flywheel.
          • pishta
            13,924
            3624
            Oct 13, 2004
            Tustin, CA
            Local Time:
            8:13 AM
            I think 10-20g is within factory spec. Ive heard motors being much more out off the line.
          • toolmanmike
            toolmanmike FABO Staff Staff Member FABO Gold Member
            36,186
            18327
            Jan 18, 2006
            Iowa
            Local Time:
            10:13 AM
            If I was to mis match components I would have the machine shop properly balance the rotating assembly.
          • toolmanmike
            36,186
            18327
            Jan 18, 2006
            Iowa
            Local Time:
            10:13 AM
            What we need to know is why the OP wants to put a 273 crank in a Magnum.
          • 318willrun
            318willrun Stomper 4x4... we kept energizer in business
            7,596
            5530
            Sep 13, 2013
            I'm here
            Local Time:
            10:13 AM
            probably wanting a forged steel crank instead of cast
            • Agree Agree x 1
            • nm9stheham
              10,225
              2558
              Dec 20, 2013
              Waynesboro, VA
              Local Time:
              11:13 AM
              Well, the tolerance around a number may be that much, but what I am coming from is that the nominal numbers are that much off.
              BUT, the good news is that I just weighed some 2 BBL 273 rods & pistons and pins, and with the new data, the bobweight number is < 10 grams off from my 5.2L Magnum data. So this looks pretty decent for being balanced.
              Racing? No way. Going in the pickup to go out and cut firewood? A-OK
              I'm curious about that too.
              • Like Like x 1
              • toolmanmike
                36,186
                18327
                Jan 18, 2006
                Iowa
                Local Time:
                10:13 AM
                One thing you have to remember is how the rods are balanced. Not just total weight but end to end. 100_4954.JPG 100_4957.JPG 100_4956.JPG
              • nm9stheham
                10,225
                2558
                Dec 20, 2013
                Waynesboro, VA
                Local Time:
                11:13 AM
                Absolutely.... I don't work out bobweight info unless I have big and small end weight data too. I've gotten to where I just give my bobweight number and crank to the machinist.
              • RustyRatRod
                48,561
                14505
                Jun 7, 2010
                Georgia
                Local Time:
                11:13 AM
                Why is that pertinent? Might simply be what he has.......OR as has been said maybe he wants a steel crank. The why really doesn't change anything.
              • toolmanmike
                36,186
                18327
                Jan 18, 2006
                Iowa
                Local Time:
                10:13 AM
                Oh just curious. Sometimes people have crazy ideas. It's more like why would you need to?
                • Agree Agree x 1
                • RustyRatRod
                  48,561
                  14505
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  11:13 AM
                  Maybe he was gonna wear the rods as a necklace? LOL
                  • Like Like x 2
                  • Maistrelli
                    35
                    8
                    Jul 16, 2018
                    Ohio
                    Local Time:
                    11:13 AM
                    Using an A833, crankshaft has pilot bearing.
                  • Maistrelli
                    35
                    8
                    Jul 16, 2018
                    Ohio
                    Local Time:
                    11:13 AM
                    Because I have a good one and 5.2M crank needs ground.
                    • toolmanmike
                      36,186
                      18327
                      Jan 18, 2006
                      Iowa
                      Local Time:
                      10:13 AM
                      It might work but there will be other things that won't be right. Why take the risk. Just turn and polish the Magnum crank.
                    • Maistrelli
                      35
                      8
                      Jul 16, 2018
                      Ohio
                      Local Time:
                      11:13 AM
                      I plan to have it balanced, new O.S. pistons, flywheel, clutch, PP and damper.
                      • Like Like x 1
                      • Maistrelli
                        35
                        8
                        Jul 16, 2018
                        Ohio
                        Local Time:
                        11:13 AM
                        What's the average cost of -.020 rod & main journals? Anyone have crank ground lately? What others things won't be right?
                      • nm9stheham
                        10,225
                        2558
                        Dec 20, 2013
                        Waynesboro, VA
                        Local Time:
                        11:13 AM
                        Balancing is going to cost 2-3 times grinding a crank. If you are not racing, then changing pistons to oversize does not necessitate a re-balance. So haw hard are you going to be running this engine?
                        Just be aware: Since both the 273 and 5.2 are 'internal balance' engines, there is no need to balance the crank with the external parts. Each of those external parts are individually balanced.
                        $125-$150 as a guess on the regrind.
