273 Rocker Arm modification jig for locking adjusters
Small Block Mopar Engine
  1. daves66valiant
    daves66valiant 68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
    3,112
    1099
    Nov 24, 2005
    SoCal
    Local Time:
    9:18 AM
    I made a quick jig today to flatten the casting surface on these 273 rockers for locking adjuster nuts. As you can see the original castings are way off
    Measured the rocker shaft and it was .87”. It just so happens a craftsman 5/8” deep socket is also .87”. Well I drilled a 7/8 in hole in some straight scraps and the socket fit snug. Then I squared everything up to the disc sander.
    I screwed in the adjuster nut and then flipped the locking nut. I referenced it to the flat surface of the sanding disc
    I set up a couple of fences to keep things squared up. Went through all 16 rockers in about 20 minutes carefully checking each locking nut. Pretty happy with this set up.
    • Like Like x 7
    • Thanks! Thanks! x 4
    • brian6pac
      brian6pac Well-Known Member
      3,658
      2167
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      12:18 PM
      I made a adapter for my lathe that cuts them perfectly flat.
    • pishta
      pishta I know I'm right....
      14,386
      4042
      Oct 13, 2004
      Tustin, CA
      Local Time:
      9:18 AM
      brilliant! Chuck a lifter in a 1" drill and reface it on a concave wet wheel. I saw a Sioux or Black & Decker valve grinder that had a lifter facer attachment on it. So cool.....
    • RustyRatRod
      RustyRatRod 30 Degrees Outta Whack FABO Gold Member
      51,146
      18182
      Jun 7, 2010
      Georgia
      Local Time:
      12:18 PM
      Nice job!
      • Thanks! Thanks! x 1
      • j par
        j par Well-hung Member
        13,563
        6250
        Jul 2, 2014
        Portland Oregon
        Local Time:
        9:18 AM
        I remember when triple-R told me I had to get a flat surface on mine and I just put mine in a vise and used a file and gently made them nice and flat by hand. But this looks a lot more precise.
        • rustycowll69
          rustycowll69 Well-Known Member
          1,834
          756
          Feb 19, 2016
          Pacific northwest
          Local Time:
          9:18 AM
          yeah, I got one of those attachment jigs on my Sioux valve refacer. It does a great job.
          I made an arbor for my lathe to face the top of the rocker arm threaded end. I sort of cut threads on to the end of like a 5/8" drill rod, and I chuck the other end of the rod up into a 3 or 4 jaw, then I just thread the rocker onto the threads, rocker top facing lathe tailstock, until it bottoms out, then face the rocker off until it cleans up. Super easy, super quick, and the facing is exactly 90 degrees to the thread centerline.
        • daves66valiant
          3,112
          1099
          Nov 24, 2005
          SoCal
          Local Time:
          9:18 AM
          Lathe would be nice to have. I’m running out of space already in my garage. Wifey has to have room for her car. Otherwise, I’d have more tools :)))
          I’m happy with how everything squared up. Simple jig for anyone who has a disc sander of any size. Mine happens to be a 12”. I’m sure it would work on a smaller disc sander as well
          • Like Like x 2
          • nm9stheham
            nm9stheham Well-Known Member
            10,681
            2872
            Dec 20, 2013
            Waynesboro, VA
            Local Time:
            12:18 PM
            A great example of how a lot of good things can be done with simple tools. Thanks for the pix!
            • Like Like x 1
            • Agree Agree x 1
            • '63GT
              '63GT Well-Known Member
              507
              404
              Jun 9, 2018
              Turlock, CA.
              Local Time:
              9:18 AM
              You're exactly right.. Too much emphasis is focused upon the 'tool', instead of the 'know how'.
              • Agree Agree x 1
              • Wyrmrider
                Wyrmrider Well-Known Member
                1,362
                518
                Sep 5, 2016
                los angeles
                Local Time:
                9:18 AM
                Reminds me of "adjusting" the lifter buttons on an E Jag on the grinder
                Great Idea and a must do
                the old rockers had interference jam adjusters which took a special tap PITA
              • crackedback
                crackedback FABO Gold Member FABO Gold Member
                18,126
                2305
                Aug 7, 2005
                92201
                Local Time:
                9:18 AM
                Nice piece of "Hillbilly Engineering"! Good job.
                • Agree Agree x 1
                • daves66valiant
                  3,112
                  1099
                  Nov 24, 2005
                  SoCal
                  Local Time:
                  9:18 AM
                  Okie style lol
                • gzig5
                  gzig5 FABO Gold Member FABO Gold Member
                  409
                  236
                  May 3, 2018
                  Mequon, WI
                  Local Time:
                  11:18 AM
                  If you don't have a disk or belt grinder, turn the fixture on its side and mount a grinding disk in the drill press. Will go a little slower due to less disk surface speed, but it will make it happen. Of course if you are a caveman, a file will be sufficient. :poke:
                • Jadaharabi
                  Jadaharabi FABO Gold Member FABO Gold Member
                  5,151
                  4875
                  Jan 8, 2016
                  Peoria, Illinois
                  Local Time:
                  11:18 AM
                  Just out of curiosity anybody have a way to resurface your hydraulic lifter faces?
                  • Mopar Sam
                    Mopar Sam Well Fed Member
                    218
                    97
                    Jul 18, 2008
                    Indiana
                    Local Time:
                    11:18 AM
                    Rustycowl, can you post a picture of this?
                  • rustycowll69
                    1,834
                    756
                    Feb 19, 2016
                    Pacific northwest
                    Local Time:
                    9:18 AM
                    I don't know how to post a picture on here.
                  • Mopar Sam
                    218
                    97
                    Jul 18, 2008
                    Indiana
                    Local Time:
                    11:18 AM
                    OK,I don't either.
                  • DesertRat
                    DesertRat FABO Gold Member FABO Gold Member
                    2,617
                    1533
                    Jan 22, 2005
                    Moses Lake, Washington
                    Local Time:
                    9:18 AM
                    I am going to use this method to prep mine for the new Smith Brothers adjusters I have on the way.
                    • Like Like x 1
                    • pishta
                      14,386
                      4042
                      Oct 13, 2004
                      Tustin, CA
                      Local Time:
                      9:18 AM
                      see post #3
                      • Like Like x 1
                      • toolmanmike
                        toolmanmike FABO Staff Staff Member FABO Gold Member
                        38,591
                        20894
                        Jan 18, 2006
                        Iowa
                        Local Time:
                        11:18 AM
                        Click on "Upload photos" next to "post reply" . There should be a option to your photo file. Find your photo and click on it. It should load on your screen. Then click "post reply".
                      • toolmanmike
                        38,591
                        20894
                        Jan 18, 2006
                        Iowa
                        Local Time:
                        11:18 AM
                        Sometimes I wish I had an old valve/seat grinder.
                        • Agree Agree x 2
