273 rocker push rods
Small Block Mopar Engine
  1. bbab3
    bbab3 Well-Known Member
    175
    64
    Feb 4, 2007
    Local Time:
    3:19 PM
    I am in the process of finding the proper push rod length for my SB with 273 rockers and a hydraliclic cam. My question how far the stock adjuster need to protrude from the bottom of the rocker arm. Thanks
  2. Plymouth 65
    Plymouth 65 Floorable Deplorable
    1,300
    1222
    Jun 27, 2016
    Mich
    Local Time:
    6:19 PM
    Was the block decked or heads shaved? Adjustable rockers typically have 1-1.5 threads protruding out. 65'
    • Agree Agree x 1
    • bbab3
      175
      64
      Feb 4, 2007
      Local Time:
      3:19 PM
      It was decked and has Edelbrock heads and new a new cam. Tried a set of Melling mrp-157 7.234” push rod for the 340 t/a motor and they are almost touching the rockers.
    • Plymouth 65
      1,300
      1222
      Jun 27, 2016
      Mich
      Local Time:
      6:19 PM
      Get an adjustable pushrod length checker. Have Smith Brothers make you a set to your measurement. 65'
    • 4spdragtop
      4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
      30,382
      10948
      Aug 28, 2009
      Wasting time here
      Local Time:
      5:19 PM
      I'm no help but if you post pics will help me learn lol. Beautiful color choice on cuda by the way!:thumbsup:
    • 4spdragtop
      30,382
      10948
      Aug 28, 2009
      Wasting time here
      Local Time:
      5:19 PM
      I would also say that once you get pushrods, maybe think about a geometry kit? A member on here has them. I believe they're relatively inexpensive, and you've come this far??
      • Agree Agree x 1
      • bbab3
        175
        64
        Feb 4, 2007
        Local Time:
        3:19 PM
        I just made an adjustable push rod from a solid lifter push rod. Planning on checking each valve with the proper preload and averaging the lengths. Just want to have the correct starting point. I will take some pictures. Thanks for the compliment on the color.
        • Like Like x 1
        • krazykuda
          krazykuda Well-Known Member FABO Gold Member How-To Section Editor
          57,197
          22842
          Aug 20, 2007
          Orland Park, IL
          Local Time:
          5:19 PM
          • Like Like x 1
          • RustyRatRod
            RustyRatRod Lemmie see your b00bs. FABO Gold Member
            67,595
            41775
            Jun 7, 2010
            Georgia
            Local Time:
            6:19 PM
            Jake has a set in the for sale section now that should work for you.
            • Agree Agree x 1
            • bbab3
              175
              64
              Feb 4, 2007
              Local Time:
              3:19 PM
              Krazykuda thanks for the list of threads. I have read most of them previously and am planning on contacting oe pushrods when I have better idea of the length needed. RRR thanks for the lead on the crane push rods. they they have a "working length" of 7.185, the Melling mpr-157 are 7.234. The .049 difference may or may not be what i need. As you can see from the photo this is how close the cup is to the rocker after setting the adjuster to zero lash plus one turn as per Racer Browns instructions. Also the cam is a Racer Brown EH-20 dur. @50 i220 e220 lift i.450 e.450. The geometry looks correct with the 7.234 push rods,
              • Thanks! Thanks! x 1
              • toolmanmike
                toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                55,775
                42057
                Jan 18, 2006
                Iowa
                Local Time:
                5:19 PM
                I would want another thread or two showing on the pushrod side. Just sayin'
                • Agree Agree x 2
                • Plymouth 65
                  1,300
                  1222
                  Jun 27, 2016
                  Mich
                  Local Time:
                  6:19 PM
                  The pushrod cup edge appears to be too close to the rocker. May want to confirm the ball/cup diameters. 65'
                  • Agree Agree x 2
                  • bbab3
                    175
                    64
                    Feb 4, 2007
                    Local Time:
                    3:19 PM
                    The ball and cup diameters match up close to the factory solid lifter 7.500 rods. The 7.234 rods are just to long. Some would rub against the rocker and not achieve zero lash. From what I have found from searching different threads is that that the adjuster needs to be exposed any where from 1 to 2 threads or 1/4" to 9/32" to provide proper oiling to the push rod.
                    • Agree Agree x 1
                    • toolmanmike
                      55,775
                      42057
                      Jan 18, 2006
                      Iowa
                      Local Time:
                      5:19 PM
                      The 7.234 pushrods are a quarter inch shorter than the 7.500 ones
                    • oldkimmer
                      oldkimmer FABO Gold Member FABO Gold Member
                      17,612
                      5494
                      Nov 11, 2006
                      Kindersley, Saskatchewan,
                      Local Time:
                      5:19 PM
                      7.500 r 4 the non adjustable hyd lifters. They r ball and ball. Kim
                      • Like Like x 1
                      • krazykuda
                        57,197
                        22842
                        Aug 20, 2007
                        Orland Park, IL
                        Local Time:
                        5:19 PM
                        also check your rocker arms to make sure that they only contact the valve stem on the full stroke and not hit your valve spring retainers, we had to grind ours for some clearance...
                        • Like Like x 1
                        • krazykuda
                          57,197
                          22842
                          Aug 20, 2007
                          Orland Park, IL
                          Local Time:
                          5:19 PM
                          You have different adjusting studs... I prefer the adjusting studs with lock nuts so they don't loosen up... They will last longer before needing to adjust valve lash than the non lock nut studs... But that can also affect the push rod length as they are longer, so decide on the adjusting studs, then figure out the push rod length... There should be about 1 1/2 threads below the rocker arm when the push rod is in and adjusted properly...
                          • 4spdragtop
                            30,382
                            10948
                            Aug 28, 2009
                            Wasting time here
                            Local Time:
                            5:19 PM
                            This is perfect example why I like pics. So many variables that can add up to cause issues. Tons of experience on fabo that spot problems in a pic. And like I mentioned pics help me learn lol.
                            You can see in tmm's pic how his adjuster sits in the rocker.
                            Lots of good advice here.
                            • Like Like x 1
                            • bbab3
                              175
                              64
                              Feb 4, 2007
                              Local Time:
                              3:19 PM
                              Well I measure each rocker and came up with an oal of 7.266 average, or a cup to ball length of 7.108.
                              Krazykuda, you mentioned using the nut locking style of adjusters. how much do the affect push rod length?
                            • krazykuda
                              57,197
                              22842
                              Aug 20, 2007
                              Orland Park, IL
                              Local Time:
                              5:19 PM
                              It depends on the design of the push rod stud... Some have 'more ball' than others... (That's what she said.... :D )
                              It's the distance from the tip of the ball to the start of the threads that you need to watch...
                              Our pushrod ended up to be 7.064", see post #37 here and it also has pics so you can see the adjusting studs and nuts with the proper adjustment and 1 1/2 threads below the rocker arm...
                              Pushrod for hydraulic cam and 273 rocker arms
                              I would estimate that the locking nut studs are about .050" - .060" longer than the 'regular' stud without a lock nut, and going from the difference between your measurements and ours...
                              • Like Like x 1
                              • Rocket
                                Rocket FABO Gold Member FABO Gold Member
                                2,078
                                308
                                Apr 22, 2005
                                Manchester, CT
                                Local Time:
                                11:19 PM
                                You may also want to check the clearance of the cup to rocker through the rockers opening and closing cycle to be sure you have no clearance issues between the cup and rocker body.
                              • gm1236
                                gm1236 Well-Known Member
                                157
                                64
                                Aug 3, 2013
                                Massachusetts
                                Local Time:
                                6:19 PM
                                If you use the locking nut studs your going to have problems with them on a stock rocker. The top of the rocker where the stud goes through needs to be machined flat or the lock nuts will keep losing up. Crane studs with the Allen head is a good one to use if you go that route. If you want to stick with the iron rockers I would buy a complete set of new ones, with the locking nuts. Isky used to make them, as well as crane, how about comp? If this is a stock motor the 273 ones as is will work fine. I ran a combination of Isky and crane’s in a stock eliminator motor for years. I just took that motor out, they still look good.
                                The pushrod lenght doesn’t change your geometry in these motors, the rocker shaft to valve tip height does. About 2 threads out of the bottom of the rocker is what you want. It will give you the adjustment you need. If you have any questions pm me.
                              • Bodyperson
                                Bodyperson Pedal to the metal
                                5,885
                                8235
                                Nov 26, 2015
                                NW MONTANA
                                Local Time:
                                4:19 PM
                                Wouldn't a ball and ball pushrod with a socket adjuster benefit pushrod angle here?
                                • Like Like x 1
                                • Bodyperson
                                  5,885
                                  8235
                                  Nov 26, 2015
                                  NW MONTANA
                                  Local Time:
                                  4:19 PM
                                  Oh ya it's all coming back to me now. I read about it somewhere (most likely here) where you also offset drill the rocker for a bigger adjuster and move the pushrod too.
                                • bbab3
                                  175
                                  64
                                  Feb 4, 2007
                                  Local Time:
                                  3:19 PM
                                  I talked to the owners son of OE Pushrods this morning (really nice guy) and began my order for new pushrods. Thanks, Krazykuda.
                                  Rocket, I checked the cups and springs for clearance when gauging the pushrod lengths. Pre-grinding the rockers for springs helped. The pushrod cups look good with the adjusters set at the proper position of 1 1/2 to 2 threads exposed.
                                  gm1236, The 273 rockers that I have look like they have very little wear to them. I talked to Jim from Racer Brown about using them with the factory adjusters. He felt the same as you that they should be fine with his ef-20 cam. I was a little skeptical about them since I once owned a '71 340-6 Cuda that had the lock-nut adjusters. I thought they made a change for a reason.
                                  Thanks both of you for the help.
