273 stock , what mufflers for duals ?
Mopar Exhaust Systems
  1. SMOKEY
    SMOKEY Well-Known Member
    253
    20
    Sep 30, 2005
    florida
    Local Time:
    10:30 PM
    what size mufflers for a stock 273 ? thanks.
  2. SMOKEY
    253
    20
    Sep 30, 2005
    florida
    Local Time:
    10:30 PM
    got stock driver 273 auto, want to put duals on the old girl. what size pipe ? glass pack or turbo ? thank's SMOKEY.
  3. Dartsun
    Dartsun Mopar Dude
    2,161
    1956
    Feb 12, 2012
    Springfield Oregon
    Local Time:
    7:30 PM
    For my 273 I used dual 2” from the manifolds back. Have had turbo mufflers and also borla xr1 currently.
    turbo
    Borla
    • Like Like x 1
    • ir3333
      ir3333 Well-Known Member
      5,148
      1641
      Jun 1, 2008
      ontario,canada
      Local Time:
      9:30 PM
      what are you trying to achieve?
      • Like Like x 1
      • toolmanmike
        toolmanmike Moderator Staff Member FABO Gold Member
        63,513
        53625
        Jan 18, 2006
        Iowa
        Local Time:
        9:30 PM
        I merged both your threads. It should streamline things.
        The early A bodies are set up for single exhaust. The transmission crossmember is only notched out on the drivers side. You can have a exhaust shop bend a pipe to go under the passenger side or you can modify the crossmember to accept a pipe. There are threads here that talk about that. The stock single v8 exhaust is either the 2 barrel version or the Charger/Commando 4 barrel set up. I bought the Accurate LTD system. Not cheap but I wanted correctness for my 66.
        • Like Like x 1
        • grimreaper
          grimreaper Cross Member
          3,412
          905
          Jul 8, 2005
          Gillette, WY
          Local Time:
          8:30 PM
          XLERATOR® STAINLESS STEEL PERFORMANCE MUFFLERS | AP Exhaust Technologies
          A friend of mine in Houston has these AP mufflers (XS1255) on his 65 Dart 273 with 2-1/4 duals to the rear bumper and it sounds amazing. Nice deep, throaty roar but not real loud either. No annoying noise inside the car either. And the price was very reasonable for him. Wish I could get a recording but the owner hates phones and such so I know he won't record it for us.
          BTW your inbox is full.
        • toolmanmike
          63,513
          53625
          Jan 18, 2006
          Iowa
          Local Time:
          9:30 PM
          Nice sound, what cam?
          • Thanks! Thanks! x 1
          • Dana67Dart
            Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
            8,285
            5802
            Jul 16, 2017
            Northern Colorado
            Local Time:
            8:30 PM
          • Dartsun
            Dartsun Mopar Dude
            2,161
            1956
            Feb 12, 2012
            Springfield Oregon
            Local Time:
            7:30 PM
            It has the stock 66 high compression cam that was sent out to Oregon cam grinders. On my rebuild sheet I got from my friend just says RV lol. .030 rebuild.
            • 65Valiant_NC
              65Valiant_NC Well-Known Member
              105
              119
              Nov 21, 2018
              Clayton, NC
              Local Time:
              10:30 PM
              Agree with grimreaper. I used these on my Valiant when I had the 273 Commando in it. Great sound!
              • Like Like x 1
              • VOETOM
                VOETOM Well-Known Member
                988
                468
                Jul 27, 2008
                KC, MO area
                Local Time:
                9:30 PM
                Smokey, we tested several of the non stainless steel XLERATOR mufflers and if they still have them, the 18" long body version is perfect for the A bodies and is much quieter and to me, better sounding than the 14" ones. They used a different perforated tube pattern in the 18" long ones. They are every nice mufflers.
                I think 2.25" is the smallest they make and sell.
                I still have one cutaway of the shorter ones if you'd like to see it later. I can take some pictures of it and share them.
                • Like Like x 1
                • rumblefish360
                  rumblefish360 I have escaped the evil Empire State! FABO Gold Member
                  42,268
                  14433
                  Jun 21, 2005
                  Florida
                  Local Time:
                  10:30 PM
                  VEOTOM made an excellent point. Are you looking for a quite ride? I honestly didn’t like the sound from some the above videos. Some of them were good, others not so much. If your looking for a silent exhaust note...
                  The longer the case the more silencing ability the muffler has. On my ‘03 Dakota, I used a Walker sound X/FX. It is as quite as the stock unit. This is not a high performance muffler. Just a quite one. And it is long.
                • SMOKEY
                  253
                  20
                  Sep 30, 2005
                  florida
                  Local Time:
                  10:30 PM
                  Thank's for all the help. SMOKEY.
                • VOETOM
                  988
                  468
                  Jul 27, 2008
                  KC, MO area
                  Local Time:
                  9:30 PM
                  Ok, here is a bit of muffler testing experience. The first image is a cutaway of a 3" in and out, 14" long case XLERATOR. It is a very aggressive sounding muffler on a big engined car. Note it has fiberglass material, is straight through, and has stainless steel wrapping the center tube. As you look into it, you see a partially perforated core. In other words, part of the tube is basically a straight pipe leaving nowhere for the sound to go but out.
                • VOETOM
                  988
                  468
                  Jul 27, 2008
                  KC, MO area
                  Local Time:
                  9:30 PM
                  Here you can see I am rolling the stainless steel back to show the size of the perforations in the tube. I also have an image of the stainless steel sock that is used to wrap the center tube. it acts like filter and prevents the fiberglass from blowing out and it also does some sound energy absorption although not a lot.
                  this pattern is one that makes a muffler that often has an aggressive and crackly tone.
                • 65goldcuda
                  65goldcuda @65_Cuda w/408/727/Dana 60
                  234
                  55
                  Mar 1, 2014
                  Houston
                  Local Time:
                  9:30 PM
                  If you are looking for something really cool and innovative check out these guys. William at DR GAS is a friend of mine. He sponsored me on the show circuit last year. http://www.drgas.com/ he also has a page on Facebook, and here is a video of what my car sounds like with his setup.
                • VOETOM
                  988
                  468
                  Jul 27, 2008
                  KC, MO area
                  Local Time:
                  9:30 PM
                  Now, here is perforated core that is used in the 18" long versions we tested and it is also similar to the ones used in Dynomax Ultra Flo mufflers, and others. This pattern is amazing in that it works so well for sound control, tone, and air flow. Obviously a straight through piece of pipes flows more and indeed, the one used in the 14" muffler will flow more air but the difference is only a few per cent in a typical offset center muffler, like A bodies use.
                  This perforated pattern, when combined with the stainless steel sock and the glass fiber packing, makes a nice, smooth sounding muffler without much crackly noise and the length of 18" lowers the over-all sound level and lowers the tendency of resonating, on some cars. A 273 will be easy to tame down and an 18" muffler with this pattern is a great choice. XLERATORS used to use this, and likely still do, and they are one of the few, other than MagnaFlow, that has an 18" muffler.
                • VOETOM
                  988
                  468
                  Jul 27, 2008
                  KC, MO area
                  Local Time:
                  9:30 PM
                  At one time XLERATORS were only made down to 2.25" I think but I need to look again.
