Here ya go
67-69 fastback is it's own trunklid. Coupe and vert share the same lid
67-68 fenders interchange except for afore mentioned light hole
69 fender is it's own animal because of changes in headlight bucket area for the 69 specific grilles headlight rings
All the rear quarter outer skins are the same up to the top character line. Above that they are specific to coupe, vert, fastback.
All front and rear valances interchange all 3 years.
Vert body structure is pretty specific for vert top and wheel houses, but all 3 use the same trunk floor, main floor, inner fenders, firewall, framerails, rockers, cowl inner and outer, rad support, torsion bar crossmember, shock crossmember, trunk drops etc.
Fastback and coupe share same inner and outer rear wheel houses. These inner and outer wheel houses also fit 70-72 demon, 73-76 dart sport, 70-76 duster
67-69 barracuda are 108" wheelbase and use the same main floorpan and rockers as a duster/demon/dart sport.
67-69 barracuda doors interchange with minor sheetmetal differences. Verts have door wedges to hold the doors tight at the back when closed (main door glass is different all 3 body types. Coupe, vert, fastback)
67 door has chromed countersink screws holding the vent wing frame in. Can be seen on the painted upper part. Vent flap on front hinge area of the door, vent flap and grille on lower aft painted part of the door.
68 door is the same as 67 except the chromed countersunk screw is missing. There is a stamped hole and a plastic plug over the hole. Vent screw is behind the hole.
69 door the front vent flap in the hinge area is gone, aft lower vent flap is gone, and the door lock button is moved forward about 10" . Base model 69s do not have the wide window sill stainless steel trim so theres no holes.
Dash frames. 67 is a 1 year only with the glovebox hinges and door. Shaft type radio opening, chrome trimmed ignition key hole. No vin tag mounting holes
68 has lower dash pads, and is drilled for them. Has same glovebox hinge setup from 68-76. 1 year only slide out ashtray. Radio hole redesigned for thumbwheel roller radio. Holes for vin tag
69 dash is like 68, but lower pad holes are gone, and back to a 67 style ashtray.
