How important is going to a 1/2" oil pickup in a big block? Mine will be stock stroke 383, 10.5:1, in a 65 Coronet. 727 with around a 4K stall and 4.56 gears. Street car and MIGHT race it just to see what it'll do. I plan on running the Milodon 7 qt. pan and the Jegs windage tray. I will be using the MP high pressure and high volume oil pump. Most I'll ever spin it is probably 6500 and that would only be through the traps, which probably won't be much or IF at all.
