[SOLD] $30k 1971 Plymouth duster twister
dustya
mass
1971 Plymouth duster twister,furious fusia paint and black/white interior,408 stroker magnum engine based 360,530 hp and 500 tq have dyno sheet,904 trans,10 in converter 3200 stall3in drive shaft,3.73 quick performance center section and axles, all new only a year old also new shark tooth grill assembly and windshield and gaskets,all lens new,headliner replaced, new upper and lower control arm bushings,shocks,torsion bars,tires and rims,complete new brake system lines ,master , proportioning valve,rebuilt kelsey hayes calipers,new gas tank and lines,850 holley dp,all msd ignition,hooker headers,black widow race venom mufflers all above as mentioned replace or new asking $33k obo
Is the Engine a custom build or Crate motor?. What is the compression ratio, is it able to run on pump gas?. Do you know what parts were used in assembly, like cylinder heads, steel crank or cast, solid or hydraulic cam ect.?
27k lowered price but firm
