It's an enticing can of worms ain't it? That's the dilemma I am in the middle of right now.
360 crank in 318 block:
Pros:
Already have what I need except pistons.
NOT a 360.
No block clearancing needed.
Cons:
Need to turn mains to 318 size. $275 for that and grind/polish
rod journals in local shop.
Cut piston skirts for counterweight clearance. $150 local shop.
Cost:
$225 for pistons.
$275 crank work.
$150 piston work.
Total: $700 plus $150 to recondition rods, rings, bearings, block bore + hone, rebalance. Gonna guesstimate $1400 total.
Now, how much is a 4" stroker assembly that you still have to balance and clearance the block? Either way it ain't cheap. :banghead:
Not having a belly button engine? Priceless.......
