318/904 flex plate ?
Totamdu
Member
Omaha
I'm doing a little part research for rebuilding my 318. It's at the machinist right now getting .040 over and zero decked. It's a 12/72 externally balanced block and I wanted to go to a balanced flex plate and zero balance stall converter in my 904.
I'm just having a hard time finding one for the 318. They all seem to be 340/360. The B&M 10235 for a 340/727 or the 10239 for the 360/904.
If anyone's got a 318/904 externally balanced with a balanced flex plate and neutral stall chiming in would be greatly appreciated.
Thanks
you need to talk to the machine shop...cause all 318s are internally balanced whether they cast or steel cranks....
so you will not find a b&m external flexplate for a 318.....just use the stock flexplate
I got it figured out, thanks guys.
To many old mopar guys in one room talking about fifty things. Don't feed the bears I guess.
