318 backfired and now runs like it has a misfire
Discussion in 'Small Block Mopar Engine' started by Rave73, May 16, 2018.
  1. Rave73
    Rave73 New Member
    3
    0
    May 16, 2018
    Canada
    Local Time:
    9:15 AM
    Hey guys new to the group. I have a 68 Dart 270 that I swapped a 318 into from a 74 satellite.
    What happened was I had my timing too far advanced and before I realized my mistake I had done a full rev up with it like that and it back fired hard through the carb spitting solid black pieces out of the carb. Since then I dialed in the timing properly but it has always ran since like it is missing a cylinder. The carb has been completely taken off and looked over...all is good. I have also pulled all wires off while running and it's not showing any specific signs as to one cylinder worse than the other. I just ran some seafoam really helped clean out some carbon build up and just pulled off the valve covers to start checking top end compents. At this point I am at a loss of where to go to be honest other than scoping out the the cylinders through the plug holes and pull the push rods out and seeing if one got bent. Any suggestions??
    The only mods done to the 318 is Performer Intake, 600cfm holley, 360 heads from a 76 dart. The plugs are ngk r's(new) and i have a brand new set of wires, new ignition control module and ballast. Only old part left being the coil and distributor....now I do have a brand new distributor coming that is similar to the GM HEI coil on cap distributors to eliminate all electrical concerns.
  2. KosmicKuda
    KosmicKuda FABO Gold Member FABO Gold Member
    1,468
    322
    Jan 15, 2011
    N Ohio
    Local Time:
    9:15 AM
    Welcome to the camp.
    I'm not a Holley guy but I seem to recall that a backfire will blow out the power valve. Someone will probably chime in with more ideas.
    • Agree Agree x 2
    • Like Like x 1
    • oldskool979
      oldskool979 Well-Known Member
      83
      56
      Sep 15, 2017
      Cumming,GA
      View My Photos
      Local Time:
      9:15 AM
      I would pull all the plugs and run a compression ck as a first step. Any cylinder that is way off (15%) would be first place to look for bad push rod, collapsed lifter, broken spring, etc. If nothing shows up, then you can chase ignition issues. I would not install the new dist until you have done this.
      • Agree Agree x 1
      • RustyRatRod
        RustyRatRod Just another dumbass. FABO Gold Member
        47,461
        12470
        Jun 7, 2010
        Georgia
        View My Photos
        Local Time:
        9:15 AM
        Perfect answer^^^^^^ This is where to start.
        • Agree Agree x 4
        • Like Like x 1
        • 604B1duster
          604B1duster Well-Known Member
          916
          272
          Dec 30, 2007
          Local Time:
          8:15 AM
          Have someone slightly brake rev the car and hold the rpm where the engine is missing, then pull one plug wire off at a time until you find the one that has no effect on the engine. That’s your miss. Check the plug, wire, compression on that cylinder
        • Rave73
          Rave73 New Member
          3
          0
          May 16, 2018
          Canada
          Local Time:
          9:15 AM
          Awesome thanks guys! I'll keep you posted after I run the check!
        • tbritton
          tbritton Member
          9
          2
          Mar 20, 2018
          Colorado
          Local Time:
          7:15 AM
          All great answers. The black pieces lead me to believe you may have an EGR valve check to make sure the valve is close and didn't get a piece of carbon under it holding it open
          • Agree Agree x 2
          • toolmanmike
            toolmanmike FABO Staff Staff Member FABO Gold Member
            33,920
            15819
            Jan 18, 2006
            Iowa
            View My Photos
            Local Time:
            8:15 AM
            It belched black through the carb? I would guess carbon. A old trick I used to do. Warm the engine up to temp, open the throttle 1/4 to 1/3 of the way open, (2500 rpm or so) and trickle a pop can or bottle of water down the carb. TRICKLE
            is the key. You can use fuel injection cleaner as well. You may be surprised all the crap that blows out of the tail pipe.
            • Like Like x 1
            • Dartswinger70
              Dartswinger70 Well-Known Member
              1,230
              375
              Sep 20, 2005
              A train bound for nowhere
              View My Photos
              Local Time:
              9:15 AM
              Pop through the carb is an intake valve, and or timing. Spark happening while intake valve is open. How is the timing chain?
            • teringer
              teringer ase master hall of fame
              716
              111
              Feb 22, 2011
              kenly nc
              Local Time:
              8:15 AM
              idle the engine at 1000 rpms then pull each wire off one at a time if the engine is shaking the bad cylinder will smooth out when the wire is pulled.(intake valve not closing right ,carbon on seat ect) your looking for a drop of 50 rpms each cylinder with wire off this was referred to as a cylinder balance test back in the day, but if you have a compression tester that's where you start like all the other have said. DID YOU BLOW OF A VACUUM LINE WHEN IT BACKFIRED? DID YOU PUMP UP A LIFTER THAT WONT BLEED DOWN?
            • Tooljunkie
              Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
              7,151
              5642
              Jul 22, 2017
              Manitoba
              Local Time:
              8:15 AM
              Many answers.
              Most of them require no parts. Double check your firing order.
              Egr, pull it off and look for a chunk of carbon holding it open. They can leak and make engine run like a real pos...
              • Like Like x 1
              • Demonracer
                Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
                2,041
                222
                Jan 31, 2010
                Cleveland, Texas
                Local Time:
                8:15 AM
                Just about anytime you get a back fire on a Holley, it's time to change the power valve. I've only NOT had to change it on two occasions., & that's over about a 50 year period.
                • Agree Agree x 1
                • Rave73
                  Rave73 New Member
                  3
                  0
                  May 16, 2018
                  Canada
                  Local Time:
                  9:15 AM
                  Just wanted to thank everyone for their help! It actually ended up being the old distributor, once I replaced it with a ready to run allowing me to remove the ballast and control module it was perfect! Not to mention a new coil to boot!
                  Thanks again everyone!
                • MOPAROFFICIAL
                  MOPAROFFICIAL Well-Known Member
                  2,774
                  1750
                  Jun 1, 2016
                  breakwater
                  Local Time:
                  6:15 AM
                  LOL!
                • Bodyperson
                  Bodyperson A little sketchy
                  1,589
                  1240
                  Nov 26, 2015
                  Under The Big Sky
                  Local Time:
                  7:15 AM
                  LOL too. No way man, I'm sure it was a hanging valve.
