318 engine brackets for left side water pump outlet
Small Block Mopar Engine
Thread Status:
  1. 34 chrysler ca
    34 chrysler ca Member
    9
    0
    Oct 27, 2017
    verona
    Local Time:
    12:22 AM
    I acquired an early 318 engine with the water pump outlet on the driver's side and a points distributor. Having a difficult time finding accessory brackets (ac,alt,ps). Also would like a recommendation on what to use to convert a points distributor to a mopar electronic ignition conversion. Thanks
  2. Lelo Dart
    Lelo Dart *
    1,343
    325
    Oct 10, 2012
    Knob Noster MO.
    Local Time:
    11:22 PM
  3. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    48,682
    16689
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    12:22 AM
    Got pics of the needed brackets have some 318 ones from a 87 w150 no idea what they are for. Dist conversion is really easy, harness, ECU and a dizzy. Just make sure the dizzy has a curve the same or close to what is in there now. I have the specs if needed.
    • Like Like x 1
    • memike
      memike Super Moderator Staff Member FABO Gold Member
      48,869
      8897
      Jan 8, 2006
      on the hill
      Local Time:
      11:22 PM
      Look at a truck/Ramcharger enging for parts, I do believe the water pumps are the same, 318/360
    • Tooljunkie
      Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
      8,191
      6711
      Jul 22, 2017
      Manitoba
      Local Time:
      11:22 PM
      Didnt know there was a water pump that had an inlet that points left. Would make fitting a rad i like (cheap and all aluminum)much easier. But it might create issues with other things.
    • 34 chrysler ca
      9
      0
      Oct 27, 2017
      verona
      Local Time:
      12:22 AM
    • 34 chrysler ca
      9
      0
      Oct 27, 2017
      verona
      Local Time:
      12:22 AM
      thanks, now I have a choice between the new electronic distributor or converting to the protronix. what are the pros and cons?
    • 34 chrysler ca
      9
      0
      Oct 27, 2017
      verona
      Local Time:
      12:22 AM
      Would the water pump outlet be on the left hand side. The specks on curve would help; can you send some photos of the brackets ?
    • Lelo Dart
      Lelo Dart *
      1,343
      325
      Oct 10, 2012
      Knob Noster MO.
      Local Time:
      11:22 PM
      A lot of people have done well with the Pertronix. I went with the electronic conversion. I think the Pertronix might be easier and cost less (in the end). I can sure take apart a distributor with a quickness now.
    • 72Dart6pack
      72Dart6pack Harder Better Faster Stronger.
      2,825
      1859
      Feb 1, 2016
      Roseville Michigan
      Local Time:
      12:22 AM
      Left meaning passenger side? By proper definition left is the driver side. Everything is referenced from the driver's seat. Let's see how many red flags this answer gets. Let the games begin.
    • halifaxhops
      48,682
      16689
      Jan 20, 2014
      CENTRURAL, PA
      Local Time:
      12:22 AM
      LOL how many damit clips got launched?
    • halifaxhops
      48,682
      16689
      Jan 20, 2014
      CENTRURAL, PA
      Local Time:
      12:22 AM
      That's why the Left hand studs are on the right also!
    • furrystump
      furrystump Well-Known Member
      612
      342
      Nov 13, 2004
      Local Time:
      4:22 AM
      Small blocks have a drivers side and a passenger side inlet for water pumps. I believe 69 back is drivers side and 70 up is passenger side. Both will bolt to any small block, however if you have a 70 up motor and run a 69 or older pump the inlet hides the timing marks. You can barely see them or just make your own on the passenger side. I know 1968 318 came with a bolt on timing tab that you can bolt on newer motors and use. You have to use timing tape and remark to balancer.
    • furrystump
      612
      342
      Nov 13, 2004
      Local Time:
      4:22 AM
      This is a 360 with a 1968 pump.
    • 34 chrysler ca
      9
      0
      Oct 27, 2017
      verona
      Local Time:
      12:22 AM
      Yes, my engine looks very similar; water pump on driver's side even is red in color. Hose fittings on the intake are similar but have a 2 bbl which will be replaced. Question, where can I find mounting brackets for a/c, p/s and alt?
    • whitepunkonnitro
      whitepunkonnitro FABO Gold Member FABO Gold Member
      14,804
      925
      Dec 6, 2011
      Murfreesboro Tn
      Local Time:
      11:22 PM
      Beware swapping water pumps from early late style.
      Everything around them is different.
      The early pump is shorter, so none of the pulleys, brackets or accessories will interchange.
    • 34 chrysler ca
      9
      0
      Oct 27, 2017
      verona
      Local Time:
      12:22 AM
      I plan on replacing the water pump with the same as i have; are they still available.
    • 34 chrysler ca
      9
      0
      Oct 27, 2017
      verona
      Local Time:
      12:22 AM
      Looked at the engine today and marking on the block are as follows, passenger side casting 2.17.67 D^ M
      block driver's side front 318 6-6
      intake manifold 2-7 67. any idea.
    • GTGrinly
      GTGrinly Well-Known Member
      1,533
      18
      Jun 2, 2006
      Central PA
      Local Time:
      11:22 PM
      I'm in the process of sorting my brackets and do believe I have extra of the power steering pump (still attached to the pump) and alternator, I'll check later today and let you know.
    • halifaxhops
      48,682
      16689
      Jan 20, 2014
      CENTRURAL, PA
      Local Time:
      12:22 AM
      I have a bunch of brackets from a 87 318 need pics of what you need.
    • GTGrinly
      1,533
      18
      Jun 2, 2006
      Central PA
      Local Time:
      11:22 PM
      15100001720351313842666.jpg 15100002699761400582997.jpg I have these, alternator and power steering off an early 70's 318, don't have anything for air and don't know if it alters these brackets.
    • furrystump
      612
      342
      Nov 13, 2004
      Local Time:
      4:22 AM
      Just bought another drivers inlet water pump from advance auto. $55 new pump.
    • 34 chrysler ca
      9
      0
      Oct 27, 2017
      verona
      Local Time:
      12:22 AM
    • 34 chrysler ca
      9
      0
      Oct 27, 2017
      verona
      Local Time:
      12:22 AM
      I an interested in those brackets if they are from an engine with the water pump inlet on the driver's side.
    • Joeychgo
      Joeychgo FABO Administrator Staff Member
      3,928
      1724
      Apr 24, 2005
      Chicago, Illinois
      Local Time:
      11:22 PM
      We have a Wanted To Buy forum -- please use it.
    Thread Status:
