318 exhaust manifold help.
Mopar Exhaust Systems
  1. pyrojim
    pyrojim Well-Known Member
    1,166
    290
    Feb 4, 2013
    Chesterton, Indiana
    Local Time:
    4:40 PM
    Can someone identify these for me please? I think they're out I'd a 78 Volare. Also, are they supposed to have heat shieds?? Going into a 66 dart. Can I lose the butterfly valves??
    Thanks.
    Jim
  2. 70DartMike
    70DartMike Too many projects
    7,612
    318
    Jul 17, 2007
    Vancouver Island, Canada
    Local Time:
    2:40 PM
    • Like Like x 1
    • rumblefish360
      rumblefish360 So close, yet so far away FABO Gold Member
      37,474
      9157
      Jun 21, 2005
      New York, on a Island
      Local Time:
      5:40 PM
      You can loose the butterfly valve if you want just by drilling out the pin fulcrum point. A da. Of JB Weld will do.
      • Like Like x 1
      • 66fs
        66fs Well-Known Member
        4,383
        1195
        Sep 9, 2009
        Greenwood, South Carolina
        Local Time:
        5:40 PM
        Looks like a set of 64-66 A body manifolds by the numbers. I take out the butterfly, shaft and all, and tap the manifold for bolts. It will warm up slower but it can never stick shut. Maybe a bit more flow. Pre smog, no shields.
      • 66plyValiant
        66plyValiant Well-Known Member
        2,714
        23
        Mar 7, 2010
        windsor NS
        Local Time:
        4:40 PM
        if there from a volare they will not clear the steering in an early A, been there
        dakota ones sort of clear if you do some light trimming
      • pyrojim
        1,166
        290
        Feb 4, 2013
        Chesterton, Indiana
        Local Time:
        4:40 PM
        Thanks, that's good info. I got this as a basket case, it's a 66 dart originally 273, but came with the 318 out of a 78 volare or aspen??
      • 66fs
        4,383
        1195
        Sep 9, 2009
        Local Time:
        5:40 PM
        That may be it, but used the 66 exhaust manifolds. They are the only ones that fit nice.
      • 66plyValiant
        2,714
        23
        Mar 7, 2010
        windsor NS
        Local Time:
        4:40 PM
        be there as well, 66 manifolds on the later 318 leak like crazy, same ports for exhaust, but all 70s engines have air ports below exhaust for pollution (even if they didn't have pollution pumps they had the ports)
      • pyrojim
        1,166
        290
        Feb 4, 2013
        Chesterton, Indiana
        Local Time:
        4:40 PM
        I should have stated he had 360 heads and the exhaust manifolds have been ported to match.
      • 4spdragtop
        4spdragtop Well-Known Member
        28,410
        8253
        Aug 28, 2009
        Wasting time here
        Local Time:
        4:40 PM
        If you wanna get rid of the heat shields, I may be interested?? Dad has 67 273 cuda, his orig shields are rough. As abv posters said, I know 2465847 is for 273 for sure...Id have to chk manual on the other, but makes sense they are orig to the car.
      • pyrojim
        1,166
        290
        Feb 4, 2013
        Chesterton, Indiana
        Local Time:
        4:40 PM
        But unfortunately, the engine isn't. And, I guess I didn't get the shields?
        Sorry
