318 heat riser open or close in picture
Mopar Exhaust Systems
  1. ming
    ming Active Member
    32
    30
    Jan 11, 2012
    new york
    Local Time:
    11:23 PM
    Can someone tell me the heat riser is on open or close position in the picture? 20190513_231950.jpg
  2. ming
    ming Active Member
    32
    30
    Jan 11, 2012
    new york
    Local Time:
    11:23 PM
    Trying to free it but don't know which direction to turn and don't want to break anything
  3. Tooljunkie
    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
    9,250
    7751
    Jul 22, 2017
    Manitoba
    Local Time:
    10:23 PM
    2 3/8” bolts and nuts and your answer is right there. Thats what i would do.likely its closed. Would think that it sat a long time and siezed, which would have happened when engine is cold.
    Another likely scenario is butterfly burned out of it. Not uncommon.
    • Like Like x 1
    • ming
      ming Active Member
      32
      30
      Jan 11, 2012
      new york
      Local Time:
      11:23 PM
      You're right, I should drop the pipe and see what's going on inside, just bought this in January engine start right up sound good after like 20 years but after engine warm it stumble when revving and make me look in to the heat riser
      • Disagree Disagree x 1
      • Dana67Dart
        Dana67Dart Like a fine wine, only getting better with age!
        2,091
        955
        Jul 16, 2017
        Northern Colorado
        Local Time:
        9:23 PM
        I have been working on one for 3 months now. From the position your photo was taken it is in the closed position. Rotate counter clock wise to open.
        Take note of how the hardware is attached
        I removed all hardware and soaked in penitrating oil 2 to 3 times a week. I also tapped on the end of the shafts couple tapes left couple of taps right. Use a brass drift or you will mushroom the metal shaft. Careful twisting on the split shaft it is easily damaged.
      • ming
        ming Active Member
        32
        30
        Jan 11, 2012
        new york
        Local Time:
        11:23 PM
        Saying I should drop the down pipe and see it's all there and soak it inside and out to try free it right
      • Dana67Dart
        2,091
        955
        Jul 16, 2017
        Northern Colorado
        Local Time:
        9:23 PM
        There is some product made to free it up. Don't know what it is called. I never tried localized heat. But I did get it freed up.
        It was much easier to work on, on the bench, but I'm sure you can get it, installed. Just go slow.
        Don't apply much pressure to the weight as the only thing preventing it from rotating on the shaft is a thin piece of metal
        • Like Like x 1
        • ming
          ming Active Member
          32
          30
          Jan 11, 2012
          new york
          Local Time:
          11:23 PM
          I'll do that, Thank you
        • Tooljunkie
          9,250
          7751
          Jul 22, 2017
          Manitoba
          Local Time:
          10:23 PM
          A thin slotted piece of metal.
          There used to be a solvent just for heat risers. It was very much like the old stinky liquid wrench.
          Ac/delco makes a similar penetrating fluid.
          • Like Like x 1
          • kursplat
            kursplat FABO Gold Member FABO Gold Member
            1,176
            362
            Aug 24, 2010
            so cal
            Local Time:
            8:23 PM
          • ming
            ming Active Member
            32
            30
            Jan 11, 2012
            new york
            Local Time:
            11:23 PM
            Doing this one for 2 days
            • Agree Agree x 1
            • RustyRatRod
              RustyRatRod 30 Degrees Outta Whack FABO Gold Member
              50,909
              17865
              Jun 7, 2010
              Georgia
              Local Time:
              11:23 PM
              Deep Creep made by Sea Foam is better than PBlaster. I never thought I would say that about PB, but it's true. And not just by a little bit, either.
            • ming
              ming Active Member
              32
              30
              Jan 11, 2012
              new york
              Local Time:
              11:23 PM
              Deep creep look like a good product and I'll get one from autozone tomorrow
            • kursplat
              1,176
              362
              Aug 24, 2010
              so cal
              Local Time:
              8:23 PM
              50/50 mix auto trans fluid and acetone
            • robert flippo
              robert flippo Well-Known Member
              149
              98
              May 9, 2018
              gibson station va
              Local Time:
              11:23 PM
              kursplat is right own with transmission fluid and acetone, got an 87 charger , had bolts that i put pb blaster/wd 40 and soaked for a week, still couldn't break the bolts loose, made the 50/50 mix, sprayed it on from a mr clean squirt bottle that i had emptied, let it set over night, next day , used a boxed end wrench and bolts came off, no problem, so it sold me on the acetone /tranny fluid mixture.
            • krazykuda
              krazykuda FABO Gold Member FABO Gold Member
              47,518
              12500
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              10:23 PM
              My x-ray vision has determined from the picture that the heat riser is stuck closed and you need to rotate it 90° to open it.... twocents.gif
            • ming
              ming Active Member
              32
              30
              Jan 11, 2012
              new york
              Local Time:
              11:23 PM
              But looking at the picture again the shaft
              Position could it be in open position?
              • ming
                ming Active Member
                32
                30
                Jan 11, 2012
                new york
                Local Time:
                11:23 PM
                OK guys, just drop the down plpe and there's no flaps left except the shaft,
                I should leave it along right?
                • Agree Agree x 2
                • ming
                  ming Active Member
                  32
                  30
                  Jan 11, 2012
                  new york
                  Local Time:
                  11:23 PM
                  Check and set the timing now run like a champ, is my first small block and never have a wrench for the rear distributor, thanks for all the info
                • Dana67Dart
                  2,091
                  955
                  Jul 16, 2017
                  Northern Colorado
                  Local Time:
                  9:23 PM
                  Hard to see in the photo but slot in shaft crossways to flow is open
