1. Mike1972
    Mike1972 Well-Known Member
    65
    148
    Jul 28, 2017
    Cardington
    Local Time:
    6:22 PM
    My nephew has a very nice looking valiant with a mild built 318. It starts easily and sounds really good. Problem is when you put it into drive or reverse it dies. Sometimes even if you 2 pedal it. We installed a new carb but still the same problem. Any ideas?
  2. Demonic
    Demonic Well-Known Member
    1,377
    1078
    Mar 21, 2015
    Maryland
    Local Time:
    6:22 PM
    Nice looking car. Do you have a vacuum gauge? What is the idle speed in park? Two feet on the pedals might be asking for trouble. I would get a kit and the specs for the old carb and rebuild it myself.
    • Like Like x 1
    • Mike1972
      65
      148
      Jul 28, 2017
      Cardington
      Local Time:
      6:22 PM
      It happens even with just foot on the brake. It adles about 1000 to 1200 rpm. No vacuums on the engine.
    • Mikes270dart
      Mikes270dart Well-Known Member
      340
      73
      Sep 26, 2010
      Toronto
      Local Time:
      5:22 PM
      2 carbs same problem, probably not the carb. Did it ever run, is this a new build? That idle is way to high. No vacuum, you got a huge vacuum leak
      • Agree Agree x 1
      • Mikes270dart
        340
        73
        Sep 26, 2010
        Toronto
        Local Time:
        5:22 PM
        Does it have power brakes? Could be in the booster. isolate the booster and then apply brakes. see if it still stalls
        • Agree Agree x 1
        • Mike1972
          65
          148
          Jul 28, 2017
          Cardington
          Local Time:
          6:22 PM
          Its isles great and drives great. Just really tough to get it into drive or reverse without it dying.
        • Mike1972
          65
          148
          Jul 28, 2017
          Cardington
          Local Time:
          6:22 PM
          Where would you suggest hooking up to check the vacuum?
        • Mikes270dart
          340
          73
          Sep 26, 2010
          Toronto
          Local Time:
          5:22 PM
          Check all hoses from the carb and the manifold for cracks. If the hoses are fine disconnect each hose and check for a change in engine sound. Make sure that all ports on the carb are being used or properly sealed. Can you get it to idle lower than 1200. It should be around 800, depending on how much cam is in the engine.
          • Like Like x 1
          • Dave 74 Dart
            Dave 74 Dart Well-Known Member
            418
            669
            Jan 24, 2019
            Southwestern Ontario
            Local Time:
            6:22 PM
            My son's 360 4 barrel dart had the exact same issue. Starts, idles, but put it in drive or reverse and it would die unless you feathered the pedal upto a decent speed. Reverse was much worse than drive. Ended up being the thin carb gasket, installed the thick one and all was great. Had to re-adjust the idle ect.
          • MOPAROFFICIAL
            MOPAROFFICIAL FABO Gold Member FABO Gold Member
            6,281
            5203
            Jun 1, 2016
            Beach
            Local Time:
            3:22 PM
            What are the camshaft spec's.
            Probably not enough initial timing at idle without having too much at full advance.
            You more than likely need to re curve the distributor and shorten the centrifical advance. It should be idling around 800 and 650-720 in gear, roughly speaking of course.
          • Garrett Ellison
            Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
            2,837
            2221
            Jan 1, 2018
            Southwest VA
            Local Time:
            6:22 PM
            Nice looking car, care to post an under hood pic?
          • AJ/FormS
            AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
            18,925
            6927
            Jan 19, 2014
            South-Central Manitoba,Canada, 900ftelevation
            Local Time:
            5:22 PM
            I'd say the transfer slot is too lean, but you'd have to have waaaaaaaaaay too much idle timing to get the idle that high with the throttle closed that far ........... unless the secondaries are not closing all the way.
            • Agree Agree x 1
            • krazykuda
              krazykuda Well-Known Member FABO Gold Member How-To Section Editor
              54,590
              19849
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              5:22 PM
              Find a low open port near the base of the carburetor... The high port on the pass side of the carb (about halfway up) is ported vacuum for the vacuum advance on the distributor...
            • krazykuda
              54,590
              19849
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              5:22 PM
              Have you adjusted the choke???
