318 LA Thrust Demensions
Small Block Mopar Engine
  1. 1Badcolt
    1Badcolt Well-Known Member
    1,157
    354
    Mar 15, 2013
    Georgia
    Local Time:
    7:56 AM
    What is inside & outside demensions
    For thrust bearing on pre 74 blocks !!!
    And 74 and newer blocks if possible !!!!
  2. 1Badcolt
    1,157
    354
    Mar 15, 2013
    Georgia
    Local Time:
    7:56 AM
    I guess I need 74 and newer demensions also if possible .
  3. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    4,561
    3546
    Jun 1, 2016
    Between a tit and an armpit
    Local Time:
    4:56 AM
    The thrust surface increased, 360's did, you can use early in late but the not the other way around
  4. 1Badcolt
    1,157
    354
    Mar 15, 2013
    Georgia
    Local Time:
    7:56 AM
    So using an early model 318
    1968 model I can use a 340 steel crank casting # 2532457
  5. MOPAROFFICIAL
    4,561
    3546
    Jun 1, 2016
    Local Time:
    4:56 AM
    Yes.
    You can use a 273 crank, 340 crank , 318...they will all work when balanced/rebalanced.
    So the crank and block are pre 74, use pre 74 bearings.
  6. 1Badcolt
    1,157
    354
    Mar 15, 2013
    Georgia
    Local Time:
    7:56 AM
    Crank is a unique one
    Its a Chrysler 340 steel oem crank but it was Bob Gliddens but its 3.20 stroke and runs 2.0 Chebby rod journals.
  7. 1Badcolt
    1,157
    354
    Mar 15, 2013
    Georgia
    Local Time:
    7:56 AM
    Glidden only ran one year with Chrysler 1979
    Crank is dated 1977
    So basically post 74 on crank going in a 68 Model 318 block .
  8. MOPAROFFICIAL
    4,561
    3546
    Jun 1, 2016
    Local Time:
    4:56 AM
    Use the early 318 main bearing set, Chevy rod bearing set.
    Nice piece of history, have a blast with it. Whatever you ...do make sure you put it together right so it doesn't fly apart and destroy it.
    Modify the main bearings with a slot hole.
  9. 1Badcolt
    1,157
    354
    Mar 15, 2013
    Georgia
    Local Time:
    7:56 AM
    Elaborate on modification
  10. MOPAROFFICIAL
    4,561
    3546
    Jun 1, 2016
    Local Time:
    4:56 AM
    Codification?
    You need to use a thrust bearing that fits the block, if the thrust is small...then the machined seat it sits in won't accommodate the '74 'larger diameter' thrust bearing.It just wont fit and seat.
    With the exception of the thrust bearing either set fits either new or late block. So heres the other end .. it doesn't matter that the crank thrust surface is larger or smaller diameter/face than the bearing.
    • Thanks! Thanks! x 1
    • 1Badcolt
      1,157
      354
      Mar 15, 2013
      Georgia
      Local Time:
      7:56 AM
      Sorry didnt have my glasses on thanks for correcting my spelling !!
    • MOPAROFFICIAL
      4,561
      3546
      Jun 1, 2016
      Local Time:
      4:56 AM
      Lol No it's fine, I dont hear that word used often. Hope you have the info you need now and understand.
    • 1Badcolt
      1,157
      354
      Mar 15, 2013
      Georgia
      Local Time:
      7:56 AM
      Yes sir
      Thanks Chris.
      • Like Like x 1
