318 - Magnum Engine Swap
Magnum Engine Swaps
  1. dICKj
    dICKj Well-Known Member
    84
    64
    Sep 25, 2018
    Kilgore, TX
    Local Time:
    9:21 AM
    In a 1974 Duster:
    1. Do I need special motor mounts to put a Magnum 360 in where a 318 came out?
    2. Will the Magnum bolt up to the original 904 auto transmission?
    3. What year did Magnums go from Carburetors to Fuel Injection?
    Thanks, DickJ
  2. dICKj
    84
    64
    Sep 25, 2018
    Kilgore, TX
    Local Time:
    9:21 AM
    Would a 360 LA be an easier swap? DickJ
  3. Magnum Valiant
    Magnum Valiant Well-Known Member
    80
    49
    Mar 14, 2020
    United States
    Local Time:
    10:21 AM
    Can only answer 3. All Magnum were fuel injection.
  4. 318willrun
    318willrun Utube channel 318willrun
    17,878
    20357
    Sep 13, 2013
    I'm here
    Local Time:
    9:21 AM
    • you can use the 318 mounts on a 360, but will need spacers for the one side where it bolts to the engine..
    • yes, the 360's will bolt to the original 904. You'll need the right flexplate or converter. If 5.9 magnum and later than '96, just use the flex plate it came with for balancing. One hole will need a little ovaling. If using a 318 Magnum, no worries.
    • All magnums were FI. In fact, all LA small blocks were TBI in the last few years. There are carb intakes that fit
    • You'll need a car 360 oil pan and pickup tube
    • Your 318 timing cover, water pump and pulleys fit the magnums. You'll need the correct harmonic balancer for the 5.9
    • Agree Agree x 1
    • dICKj
      84
      64
      Sep 25, 2018
      Kilgore, TX
      Local Time:
      9:21 AM
      Wont the oil pan and pickup off of 318 fit the LA 360?
    • missing linc
      missing linc Loose nut behind the wheel
      4,186
      7811
      Feb 17, 2019
      Southern Alberta Canada
      Local Time:
      8:21 AM
      No.
    • 318willrun
      17,878
      20357
      Sep 13, 2013
      I'm here
      Local Time:
      9:21 AM
      no
    • TT5.9mag
      TT5.9mag Two atmospheres are better than one
      1,725
      1697
      May 5, 2016
      So cal
      Local Time:
      7:21 AM
      Adding to what @318willrun said;
      If you plan to use the fuel injection you’ll have to notch the top of the bellhousing on the 904 to clear the crankshaft position sensor when you bolt it up.
      • Agree Agree x 1
      • 318willrun
        17,878
        20357
        Sep 13, 2013
        I'm here
        Local Time:
        9:21 AM
        Further more, the magnums don't have the provision on the cam snout for the fuel pump eccentric if you are going to run a mechanical pump. You can buy an adapting unit from Hughes for like 30 bucks, or if you cam swap you can use a roller cam with a long snout. Of course, if using an electric fuel pump, no worries.
      • dICKj
        84
        64
        Sep 25, 2018
        Kilgore, TX
        Local Time:
        9:21 AM
        No to fuel injection. lt sounds like a 360 LA is the easier way to go.
      • 67dartgtgo
        67dartgtgo FABO Gold Member FABO Gold Member
        1,460
        881
        Nov 9, 2012
        Mass
        Local Time:
        9:21 AM
        • Agree Agree x 4
