318 timing chain
Small Block Mopar Engine
  1. TheMattMobile
    TheMattMobile 74 Dart Swinger
    46
    0
    Mar 21, 2011
    Marysville, WA
    Local Time:
    7:55 AM
    Maybe I am stupid lol but I can't figure out how to pull my timing chain on my 318.
  2. jerry6
    jerry6 Banned
    2,439
    56
    Aug 29, 2010
    Mon
    Local Time:
    10:55 AM
    puller helps , you can make your own
  3. TheMattMobile
    46
    0
    Mar 21, 2011
    Marysville, WA
    Local Time:
    7:55 AM
    To pull the crank shaft sprocket?
  4. usdart
    usdart Well-Known Member
    248
    0
    Dec 28, 2005
    West Richland, Wa
    Local Time:
    9:55 AM
    Once you have the Dampner and cover off they just slide off. I used a little pry bar and pushed them off by moving them a little at a time and keeping them. Move one and then the other so they come off together.
  5. rumblefish360
    rumblefish360 I have escaped the evil Empire State! FABO Gold Member
    41,751
    13999
    Jun 21, 2005
    Florida
    Local Time:
    10:55 AM
    There ya go! John to the resccue. ;)
    I've had some tuffy parts. A screwdriver on each side and jerking the drivers in a scissor fashion hleped slide it ogg.
    A tap with a hammer to "Shock it" can help loosen it up. Don't wack it to hard now.
  6. Baxter61
    Baxter61 Well-Known Member
    1,124
    94
    Oct 4, 2006
    Oregon City, OR
    Local Time:
    7:55 AM
    guys, he didnt ask for a solution, he was just letting you know :finga:
  7. jobrated52
    jobrated52 Active Member
    32
    1
    Jun 30, 2006
    San Jose
    Local Time:
    7:55 AM
    Before banging/prying/pulling on anything, don't forget to remove the fuel pump eccentric...
  8. Mopar to ya
    Mopar to ya Well-Known Member
    3,033
    134
    May 17, 2011
    North Branch, Minnesota
    Local Time:
    9:55 AM
    My stock reply is, keep taking bolts out until the part you want falls off - how hard can it be? In this case, use a puller on the crank sprocket if you can't get it to slide off.
  9. TheMattMobile
    46
    0
    Mar 21, 2011
    Marysville, WA
    Local Time:
    7:55 AM
    I was trying that and couldn't get it... but I finally got it late last night... When all else fails, use a 2x4 and a chevy tool (Hammer) lol. I ran into another problem though, when torquing the main crankshaft bearings down, I broke one of the mounts... DAMN lol, now I am on the search for a replacement part.
  10. fishy68
    fishy68 Tyr Fryr's Inc.
    16,586
    967
    Jan 11, 2005
    Central, IL (Hooterville)
    Local Time:
    9:55 AM
    You broke a main cap?? Never saw that happen in 30 yrs. of wrenching. Must have had a object under it. You've created a huge problem there cause main caps are specific to the engine because they are align honed as a unit. You can't just slap a main cap from another engine on it and expect things to be straight.
  11. Oklacarcollecto
    Oklacarcollecto Life is an experiment
    17,036
    299
    Mar 13, 2009
    North Central Oklahoma
    Local Time:
    9:55 AM
    "Houston, We've Had a Problem" .....
  12. TheMattMobile
    46
    0
    Mar 21, 2011
    Marysville, WA
    Local Time:
    7:55 AM
    So I would have to take an entire crank from another engine?
  13. fishy68
    16,586
    967
    Jan 11, 2005
    Local Time:
    9:55 AM
    Not unless you broke the crank. If I understand what you wrote you are meaning you broke a main bearing cap. Is that correct? If so the cap goes with the block. When the block is bare the machine shop bolts all the main caps on and torques them down then align hones it as an assy. If you use a main cap off another engine you need to totally disassemble the engine and take it to a machine shop and have it align honed with the new cap or it won't be straight and will trash the bearings and crank pretty quick.
