1. Joel Chapman
    Joel Chapman Well-Known Member
    210
    26
    Jul 28, 2019
    Mountain Home, ID/ Hughson, CA
    Local Time:
    11:51 AM
    Hey every one it looks like I am going to be doing a 318 to a 360 swap in my 71 Dart Swinger. I saw somewhere on here that I would need a new flex plate because of going from internally balanced engine to an external one. Is there anything else that I need to consider/buy when doing this swap?
  2. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    16,552
    5340
    Jan 16, 2005
    las vegas
    Local Time:
    6:51 PM
    driver side motor mounts are different....harmonic balancer needs to be for a LA 360 externally balanced
    yes....in the rear...either the flexplate needs to be for externally balanced LA 360 or the converter needs weights on it....One or the other....
    • Thanks! Thanks! x 1
    • Joel Chapman
      210
      26
      Jul 28, 2019
      Local Time:
      11:51 AM
      Do I just need to get a new mount for the K-member and that would solve that problem?
    • George Jets
      George Jets 1967 Dart 2 Door FABO Gold Member
      5,573
      7643
      Jan 18, 2019
      Farmington MN
      Local Time:
      8:51 PM
      Ask @moparmat2000 ^^^^^
      He was just explaining this driver's side 360 to 318 k frame mount setup to another member just 15 minutes ago.
      He has great pictures to explain what you need to do.
      • 70aarcuda
        16,552
        5340
        Jan 16, 2005
        las vegas
        Local Time:
        6:51 PM
        the bracket that bolts to the engine is not the same......they are getting hard to find and expensive....
        or you can make one ...modify the old one...
        • George Jets
          5,573
          7643
          Jan 18, 2019
          Farmington MN
          Local Time:
          8:51 PM
          • moparmat2000
            moparmat2000 FABO Gold Member FABO Gold Member
            20,129
            9445
            May 13, 2010
            Grand Tetons
            Local Time:
            8:51 PM
            Thanks. I'm kinda done explaining it. Pix will have to suffice.
            • Joel Chapman
              210
              26
              Jul 28, 2019
              Local Time:
              11:51 AM
              I didnt mention that the 360 I am swapping too is an LA 360 not a magnum, still the same issue with the motor mount?
              • Agree Agree x 1
              • Joel Chapman
                210
                26
                Jul 28, 2019
                Local Time:
                11:51 AM
                Ive already bookmarked that post so no need to worry bout having to explain again! I do appreciate it though!
              • moparmat2000
                20,129
                9445
                May 13, 2010
                Grand Tetons
                Local Time:
                8:51 PM
                LA, or Magnum the block ears are the same for both engines
                • moparmat2000
                  20,129
                  9445
                  May 13, 2010
                  Grand Tetons
                  Local Time:
                  8:51 PM
                  318 LA and 318 magnum same on drivers side
                  360 LA and 360 magnum same on drivers side
                  318/360 LA and Magnum same on passenger side.
                  • Thanks! Thanks! x 2
                  • Stephen Mulkey
                    Stephen Mulkey FABO Gold Member FABO Gold Member
                    838
                    610
                    Nov 29, 2016
                    California
                    Local Time:
                    6:51 PM
                    I believe you will also need a oil pan for the 360 in the above, possibly a pickup tube.
                  • cudamark
                    cudamark FABO Gold Member FABO Gold Member
                    9,097
                    1528
                    Mar 14, 2009
                    San Diego
                    Local Time:
                    6:51 PM
                    If you're going from a 2bbl to 4bbl, there are kickdown and throttle cable differences too.
                    • Like Like x 1
                    • Agree Agree x 1
                    • George Jets
                      5,573
                      7643
                      Jan 18, 2019
                      Farmington MN
                      Local Time:
                      8:51 PM
                      Yes ^^^ and you got to have the 4bbl, that is more than half the fun opening up the secondaries on demand.
                      360 pictured here ^^^ with the Weiand 8022 Aluminum 4 bbl Intake.
                      Edelbrock 1406 600 cfm Electric Choke is a good fit for the 318s/360s, bolt on and go.
                      The 360s just pull a little more of the same volume.
                      Need this Edelbrock Mopar bracket to to work with the 4 barrel carb and the mopar kickdown linkage.
                      And here is a shortcut to get a 4bbl on to your 2 bbl intake manifolds, for those that like shortcuts. Factory 2 bbl manifolds are still the Dual Plane manifolds on the 360s.
                      Run Nice
                      Not to mention your cooling system may need a 7 blade clutch fan and shroud to help cool the more powerful 360.
                    • dICKj
                      dICKj Well-Known Member
                      91
                      68
                      Sep 25, 2018
                      Kilgore, TX
                      Local Time:
                      8:51 PM
                      Can’t l use the oil pan, pickup from the 318 that I’m taking out?
                    • moparmat2000
                      20,129
                      9445
                      May 13, 2010
                      Grand Tetons
                      Local Time:
                      8:51 PM
                      No. 360 is it's own animal when it comes to oil pans. 318/340 share the same pan
                      • Like Like x 1
                      • justinp61
                        justinp61 Well-Known Member
                        2,180
                        1750
                        May 15, 2009
                        Local Time:
                        8:51 PM
                        As mentioned you'll need the 340/360 drivers site motor mount, a 360 oil pan and a 360 flex plate. A milodon flex plate would probably be the easiest route.
                      • Rapid Robert
                        Rapid Robert Well-Known Member
                        1,221
                        193
                        Aug 6, 2006
                        Lincoln Nebraska
                        Local Time:
                        8:51 PM
                        I've used the B&M 10239 flexplate for this swap (keeping the internally balanced torque converter) & it works fine. there are 2 360 "center sump" pans that I am aware of (might be others), a 392 & the sump starts 4" back from a plumb line down from the front lip of the pan & an 876 pan & that dimention is 2" & the 392 will clear the rear edge of the kmember & the 876 may likely as well but no exp with it. the 876 pan requires the bottom curved pickup & the 392 pan requires the right angle (middle) one. disregard the top pickup. when the time comes I would compare the 318 one to those shown as you might be OK as is.
                      • cudamark
                        9,097
                        1528
                        Mar 14, 2009
                        San Diego
                        Local Time:
                        6:51 PM
                        The 876 pan is from a '74-8 C-body. The 392 is the correct pan for A, B, E, and F, bodies.
