318 to 440 conversion 69 fastback
Discussion in 'Big Block A body Tech' started by peterOZ, Mar 12, 2018.
  1. peterOZ
    peterOZ Member
    5
    0
    May 9, 2016
    Sydney - Australia
    Local Time:
    2:50 PM
    Can someone please point me in the right direction if this mod has been already covered.
    Were can i buy parts needed to convert 318 fastback barracuda to 440.
    What else is needed to be replaced or modified to make it fit.
    Thanks.
  2. roccodart440
    roccodart440 Well-Known Member
    4,663
    3666
    Apr 19, 2010
    Local Time:
    12:50 AM
    first step is motor mounts.
    Schumacher or after market K member.
    • Agree Agree x 1
    • YY1
      YY1 Well-Known Member
      4,918
      739
      Oct 11, 2011
      FL
      Local Time:
      12:50 AM
      might want to check out bigblockdart.com
      • Agree Agree x 1
      • peterOZ
        peterOZ Member
        5
        0
        May 9, 2016
        Sydney - Australia
        Local Time:
        2:50 PM
        Thanks for those leads. Ill check them out.
      • frederick_76
        frederick_76 FABO Gold Member FABO Gold Member
        702
        151
        May 2, 2010
        Milton, Wa.
        View My Photos
        Local Time:
        9:50 PM
        Automatic or manual?
      • peterOZ
        peterOZ Member
        5
        0
        May 9, 2016
        Sydney - Australia
        Local Time:
        2:50 PM
        Auto.
        Could the conversion allow either 904 or 727 to be fitted ? If so , would floor need to be touched if fitting 727?
      • d1970
        d1970 TODAY IS A GOOD DAY TO HAVE A GOOD DAY
        355
        142
        Sep 29, 2015
        Ontario, Canada
        View My Photos
        Local Time:
        11:50 PM
        no 904 will bolt up to a BB motor, you will need a BB 727 transmission
      • JGC403
        JGC403 Well-Known Member
        966
        32
        Nov 22, 2010
        Baileyton, TN
        Local Time:
        10:50 PM
        Schumacher engine mounts
        Big Block 727 transmission
        correct radiator the inlets/outlets will probably be on different sides for the big block
      • peterOZ
        peterOZ Member
        5
        0
        May 9, 2016
        Sydney - Australia
        Local Time:
        2:50 PM
        Yes ! you are right. what was i thinking :)
      • peterOZ
        peterOZ Member
        5
        0
        May 9, 2016
        Sydney - Australia
        Local Time:
        2:50 PM
        Will i need to modify floor to fit the 727?
      • famous bob
        famous bob mopar misfit
        9,607
        2068
        Aug 14, 2011
        okla
        Local Time:
        11:50 PM
        iT WILL PROBABLY NEED THE FIREWALL TO FLOOR PINCH SEAM HAMMERED FLAT. I WELDED MINE SOLID FIRST.
        • Like Like x 1
        • RedFish
          RedFish Well-Known Member
          22,133
          1316
          Sep 5, 2007
          Local Time:
          11:50 PM
          • Thanks! Thanks! x 1
          • Jim Lusk
            Jim Lusk Well-Known Member
            3,781
            270
            Mar 8, 2006
            Fresno, CA
            View My Photos
            Local Time:
            9:50 PM
            No need to touch the floor or seam for a big block 727. Certain exhaust systems might fit better with the seam hammered flat.
            • Agree Agree x 1
