318LA driver, mopar built Electronic distributor. anyone better than others ?
Mopar General Discussions
  1. rustytoolss
    rustytoolss Well-Known Member
    1,965
    64
    Sep 26, 2013
    Clinton, Ohio
    Local Time:
    12:09 PM
    Looking for a part # for a Chrysler electronic distributor (no after markets) for my 318 LA , mostly stock, small cam/ 4 brl street driven cruiser. Where any part numbers better for performance/mileage. Was thinking of getting one from rockauto (they list OEM part numbers).
    Did the 340/360 electronic distributors have better advance curves/weights/vacuum advance canisters ?
    Or were all of the electronic distributors all about the same?
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    46,465
    14292
    Oct 14, 2010
    Idaho
    Local Time:
    10:09 AM
    Earlier the better and high performance the better. You can look the specs up in the back of the factory manuals. Having said that, a typical parts store "rebuilt" is anybody's guess. On the other hand you can recurve them, and FBO has a recurve / limiter kit
    How to limit mechanical advance in a mopar distributor, tuning for street, strip or all out racing, cure that rich stinky idle, win races
    Many of the mechanical mechanisms are stamped as to advance. Remember tho, this is DISTRIBUTOR degrees, you multiply that figure x2 to get crank degrees
    Start with the 72 Plymouth shop manual from MyMopar page 8-139
    • Like Like x 1
    • toolmanmike
      toolmanmike FABO MODERATOR Staff Member FABO Gold Member
      55,802
      42081
      Jan 18, 2006
      Iowa
      Local Time:
      12:09 PM
      You need to talk to @halifaxhops. He know what's good and what's not.
      • Agree Agree x 3
      • Like Like x 1
      • str12-340
        str12-340 FABO Gold Member FABO Gold Member
        1,458
        856
        Dec 26, 2012
        Vashon, WA
        Local Time:
        10:09 AM
        following...
      • jos51700
        jos51700 Hemi Orange you glad it isn't a political avatar?
        5,481
        2183
        May 24, 2009
        Bel-Ray
        Local Time:
        12:09 PM
        The aftermarket doesn't give two craps. You'll have to tune it yourself, and this is a worthwhile endeavor.
        If you get one, first thing to do is stick an Allen wrench in the advance canister and make sure it's adjustable. Some aftermarket units lock this out but you NEED to adjust it
        • Agree Agree x 1
        • RustyRatRod
          RustyRatRod Lemmie see your b00bs. FABO Gold Member
          67,609
          41818
          Jun 7, 2010
          Georgia
          Local Time:
          1:09 PM
          I second that. I got one from Ray for my slant six and it runs out of this world.
          • Like Like x 1
          • Thanks! Thanks! x 1
          • halifaxhops
            halifaxhops It's going to get stupid around here! FABO Gold Member
            63,214
            32059
            Jan 20, 2014
            Hoppyworld
            Local Time:
            1:09 PM
            Thanks guys way to many variables here shoot me a message. Do agree with the above the parts stores are made to fit in at least a ten year spread, The stock MP are usually fast to full advance ……..
          • Kendog 170
            Kendog 170 Let the boy go !
            1,644
            1066
            Mar 10, 2016
            Tewksbury Ma.
            Local Time:
            1:09 PM
            I bought a Reman dizzy and did what Post 2 said.
            • Like Like x 1
            • 67Dart273
              46,465
              14292
              Oct 14, 2010
              Idaho
              Local Time:
              10:09 AM
              I don't understand your statement. Of course you have to adjust aftermarket ones, at least they are adjustable. None of the OEM ones are optimum, by the time breakerless came about, ALL of them had smog curves.
              Only breakerless that don't are the MP ones which can be considered "aftermarket."
            • H22A4
              H22A4 Does anyone read this?
              2,190
              1088
              Aug 4, 2006
              YVR
              Local Time:
              10:09 AM
              Not sure if Trailbeast still sells recurved (faster advance) distributors but I bought one from him a few years ago when I did my 4bbl upgrade and am happy with it.
            • Kendog 170
              1,644
              1066
              Mar 10, 2016
              Tewksbury Ma.
              Local Time:
              1:09 PM
              • Agree Agree x 1
              • str12-340
                1,458
                856
                Dec 26, 2012
                Vashon, WA
                Local Time:
                10:09 AM
                According to Ehrenberg the ones to avoid are MP distributors made from 2000 to 2011, during that time they subbed the work out to Accel who redesigned a good thing and ruined it. From the pictures in the story, they are identifiable by the gold colored center shaft and innards, which are completely different from the old MP and later MP dizzys. (see current issue of Mopar Action - December 2020). evidently the spark scatter on the Accel distributors is out of hand...
              • MoparLeo
                MoparLeo NRA PATRON LEVEL LIFE MEMBER FABO Gold Member
                608
                374
                Feb 10, 2016
                Moreno Valley, Cal. So. Cal.
                Local Time:
                10:09 AM
                Auto parts stores do not sell year/model specific part numbers. Normal street driving you are unlikely to notice little if any difference. Oem units worked fine for many years with very little maintenance or problems. You can get good distributors from Mancini, or really Mopar parts supplier for little money. Don't need anything trick for a street car. Good wiring, good grounds, good cap, rotor, wires, plugs. good coil. When you start going for " high performance" stuff and veer from stock you start to chase your tail. I doubt you are very interested in your 60 foot times...
                • Like Like x 1
                • rustytoolss
                  1,965
                  64
                  Sep 26, 2013
                  Clinton, Ohio
                  Local Time:
                  12:09 PM
                  No 60ft times for me these days, that was long ago. Your reply makes sense to me/ sound like a plan.
                • jos51700
                  5,481
                  2183
                  May 24, 2009
                  Bel-Ray
                  Local Time:
                  12:09 PM
                  I'm saying that the adjustment in the vacuum advance canister is locked out on some of the aftermarket/OEM replacement distributors. On factory distributors, you adjusted the vacuum advance rate in this way
                • 67Dart273
                  46,465
                  14292
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  10:09 AM
                  Ah I thought you were talking about mechanical. Non-adjustable parts store vacuum cans started a LONG time ago LOL
                • rustytoolss
                  1,965
                  64
                  Sep 26, 2013
                  Clinton, Ohio
                  Local Time:
                  12:09 PM
                  What about using the "old" mopar performance electronic distributor 3690430 (small block), for a street driven daily cruiser ? Might know of one that I may be able to get...maybe ??
                • halifaxhops
                  63,214
                  32059
                  Jan 20, 2014
                  Hoppyworld
                  Local Time:
                  1:09 PM
                  They are the better ones basically a mallory adjustable mechanical advance. As for the rest of the MP ones they go full mech advance in a hurry, great for the track though.
                • rustytoolss
                  1,965
                  64
                  Sep 26, 2013
                  Clinton, Ohio
                  Local Time:
                  12:09 PM
                  OK, I did get one from a buddy. Can I put stronger springs in it , to slow down the fast advance ?
                • Bill Crowell
                  Bill Crowell FABO Gold Member FABO Gold Member
                  999
                  548
                  Oct 16, 2007
                  Diamond Springs, CA
                  Local Time:
                  10:09 AM
                  I'm following the thread and making popcorn! Very interesting. I have at least a couple of those "bad" MP distributors in my 4 Mopars. I'd better check out that mechanical advance rate.
                • rustytoolss
                  1,965
                  64
                  Sep 26, 2013
                  Clinton, Ohio
                  Local Time:
                  12:09 PM
                  What is the distributor tag number on the "bad MP distributors" ? They have a gold/copper center shaft right ?
                • halifaxhops
                  63,214
                  32059
                  Jan 20, 2014
                  Hoppyworld
                  Local Time:
                  1:09 PM
                  Yes can if you can find them, might take a while to get the curve right though. Every engine is different. You have to figure out what you want and then tailor it to that.
                • halifaxhops
                  63,214
                  32059
                  Jan 20, 2014
                  Hoppyworld
                  Local Time:
                  1:09 PM
                  They are not BAD per say they are just a reg Mopar distributors with a fast Mechanical curve.
                • RustyRatRod
                  67,609
                  41818
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  1:09 PM
                  But they are also great for stock, low compression engines that need that hot ignition curve to pep them up. They can work wonders.
                  • halifaxhops
                    63,214
                    32059
                    Jan 20, 2014
                    Hoppyworld
                    Local Time:
                    1:09 PM
                    Yes they can but the OP is looking for a good all around Mr President. I think @Mattax has the MP charts scanned.
