Rmoore
Which 727 will fit behind a 331 Hemi? Big block or Small Block ?
Neither as is. The bell housing bolt pattern is the same as the small block, but the dowel pins are in different locations, so an adapter plate is required. I have an A833 OD 4 speed bolted to my 331. I got my kit from Hot Heads.
How's that Bobcat project going?
Come to Kona, take a brake. HahaIt's at a standstill right this minute. It's so hot here everything kinda is. I need another me. One that can work in the hot.
