1. KB9GIB
    KB9GIB Well-Known Member
    175
    51
    Jul 25, 2014
    Anna illinois
    Local Time:
    3:24 AM
    Need some information putting my son’s 340 together do we want bearings with the (dole holes?) H-P-? Style bearings. I’m lost on the dole hole and the type of bearings as the H bearing are P bearing. Thanks for your help in advance. KB9GIB
  2. Shorty Medlock
    Shorty Medlock Roads Scholar
    93
    75
    May 9, 2020
    Wisconsin
    Local Time:
    3:24 AM
    H bearings are race bearings and are used on a crankshaft with a radiused crank journal. Yours will take a P series Cleveite bearing.
    Take a look at the King bearing line... the SI line is the standard bearing.
    Often you can find older Federal-Mogul bearings on Fleabay for a good price. They work fine, too.
    You really don't need a coated bearing or any fancy-schmansky parts.
    DODGE 5.9L/360 Mopar small block LA King Engine Bearings Rod Bearings
  3. perfacar
    perfacar Well-Known Member
    1,092
    285
    Mar 1, 2006
    renton,wa
    Local Time:
    1:24 AM
    clevite, cb481p rods, mains 1344p,
  4. KB9GIB
    175
    51
    Jul 25, 2014
    Anna illinois
    Local Time:
    3:24 AM
    Thanks for the information. KB9GIB
  5. Wyrmrider
    Wyrmrider Well-Known Member
    3,611
    1748
    Sep 5, 2016
    los angeles
    Local Time:
    1:24 AM
    you need early bearings with the smaller dia thrust
  6. Sterling
    Sterling Well-Known Member
    222
    121
    Sep 29, 2007
    Pottstown,Pa.
    Local Time:
    3:24 AM
    Bearings with holes for dowel pins are usually aluminum connecting rod engines
  7. Shorty Medlock
    93
    75
    May 9, 2020
    Wisconsin
    Local Time:
    3:24 AM
    What years were they changed Jim?
