Oops, FABO doesn't like Photobucket. Load them directly to your post using the "upload photos" button
I was looking at the comp cams xe284h camshaft.
Running a few simulations of the the 220/226 Voodoo it produced more street torque than 3 CC cams with avg similar lift.
Comp cams classic 280480/480
Comp's 'replacement' 268/276; 264/264 (20-309-4, was called Magnum Muscle)
Comp's XE268. 477/480 This was the closest, making more power than the Voodoo starting around 3000 rpm, give or take some.
In terms of top end horsepower, all three above are in the same ballpark, and...
Which is why it makes sense to cc your heads, measure the cc in the hole or height above deck of your pistons, and think about the gearing you will want for the driving you'll be doing. Finally, take a good look at what your heads will do. Hard to find a shop with a bench but this thread will ballpark the situation.Wow lots of information to sort out
Ah - HA! Was wondering why my motor was clattering on start so much! Goes away quickly, but somewhat bothersome. Using a Comp cams XE275 HL - kinda rowdy for the street, but I like it! RTGo solids. Lately the Hydraulics are not staying pumped up. We are on are third set from comp. They said they are having a problem. We tried different preloads with no luck. If the car sits for a little it clatters bad when starting it. Three motors same thing . I grabbed a set of lifters out of a old purple shaft kit problem solved.
Great suggestion, and wise advice (learned the hard way - like most of us...)
Two additional suggestions
CC the heads while its apart. There's no reason to guess what the compression will be. I will never have an engine together again without knowing the actual head CC and piston above or below deck.
Stock heads aren't going to flow significantly more with the valves over .5" open.
I've used the street dominator intake and found it pretty decent single plane at lower rpms. It had a better rep than the Torker but I've not run them back to back. If you want to stay with single plane, I would try both. The Eddy RPM with a Holley 4150/60 will bring the air cleaner close to the hood. Check and double check clearance of stud and lid with clay or aluminum foil. A mild drop base will likely be needed.
Almost forgot to mention that the Air Gap required no matching to J or X heads - the LD4B and performer have much smaller runners (and one of them - I forget which - did not even have enough meat on the manifold to match to the larger ports - maybe both). Not sure on the LD4B for the 340 or the Performer Plus yet. Guess I better get off my butt and do more research!With an Eddy Air Gap and a 3 inch air cleaner I have just enough clearance to be comfortable closing the hood! This is on a 65 Barracuda. I am in the process of doing an article on manifold heights, but am still doin research. But - I will share this; The Air Gap is only about .240" taller than an LD4B, but is .640 taller than a performer 318/360 (all Eddies) Sure do like the way the engine gets RPMs with that Air Gap tho! (not the only mod to the motor by any stretch!)
