340 exhaust manifolds
Magnum Engine Swaps
  1. ed1946
    ed1946 FABO Gold Member FABO Gold Member
    134
    41
    Apr 24, 2019
    garrison, ky
    Local Time:
    2:55 PM
    Which set of 340 exhaust manifolds work best for the magnum swap. There appears to be several versions of these manifolds. Does the drivers side one that exits right top rear the best. A pic of what you used would help.
  2. 72Dart6pack
    72Dart6pack Well-Known Member
    3,463
    2862
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    2:55 PM
    What are you putting it in? A John Deere tractor? Question is too vague.
    • Like Like x 2
    • ed1946
      134
      41
      Apr 24, 2019
      garrison, ky
      Local Time:
      2:55 PM
      72 dart
    • pishta
      pishta I know I'm right....
      16,502
      6188
      Oct 13, 2004
      Tustin, CA
      Local Time:
      11:55 AM
      • Like Like x 2
      • ed1946
        134
        41
        Apr 24, 2019
        garrison, ky
        Local Time:
        2:55 PM
        would these work for installing 360 magnum in 72 dart, has power steering
        these are off 318
      • pishta
        16,502
        6188
        Oct 13, 2004
        Tustin, CA
        Local Time:
        11:55 AM
        ports will be too small and may not even seal with 360 gaskets. Use 318 gaskets but your leaving power on the table. Id go with Magnum logs, they are inexpensive, sized right and flow well. custom head pipes...or get them off the truck youll pull them from. Its a start.
      • 512Stroker
        512Stroker We are all here because we are not all there.
        1,075
        754
        May 30, 2016
        Freedom, MO
        Local Time:
        1:55 PM
        I have a couple sets if you need them.
        I dont know if they are the "best" but they will work and they are cheap$
        • Agree Agree x 1
        • ed1946
          134
          41
          Apr 24, 2019
          garrison, ky
          Local Time:
          2:55 PM
          sent message via conversation
        • RustyRatRod
          RustyRatRod Weenie idiot loser. FABO Gold Member
          58,517
          28941
          Jun 7, 2010
          Georgia
          Local Time:
          2:55 PM
          @Treblig can probably help you decide. I tagged him so maybe he'll get in here.
        • Treblig
          Treblig Well-Known Member
          5,871
          3095
          Oct 5, 2013
          South Texas
          Local Time:
          1:55 PM
          The best flowing combination would be a 70s 340 driver's manifold and a Jeep Grand Cherokee (96/97/98) passenger's side manifold. This would give you the best flow for the lowest price. You can find a Cherokee manifold here:
          Car-Part.com--Used Auto Parts Market
          You can have it list manifolds by price or distance.
          • Like Like x 1
          • ed1946
            134
            41
            Apr 24, 2019
            garrison, ky
            Local Time:
            2:55 PM
            Thanks for all the help. Have bought a set off 512Stroker, on to the next hunt.
            • Like Like x 1
            • ed1946
              134
              41
              Apr 24, 2019
              garrison, ky
              Local Time:
              2:55 PM
            • ed1946
              134
              41
              Apr 24, 2019
              garrison, ky
              Local Time:
              2:55 PM
              received today, look good, thanks elmer
              • Like Like x 1
              • DionR
                DionR Well-Known Member
                1,940
                205
                May 7, 2008
                Spokane, WA
                Local Time:
                11:55 AM
                Be aware that the 340 manifold port can be too large for the Magnum head. I have the MP R/T heads on my motor with 340 manifold both sides and I have to run an adapter plate between them to have a chance for them to seal.
                The reality is, I think the Magnum uses a 318 exhaust port size, or at the least is smaller then the 340/360 ports. They don't drop down on the bottom as much.
                Part of the issue is whether the Magnum head has extra material below the port. Mine doesn't and the manifold opening starts almost exactly where the material on the head ends. This leaves a small window at the bottom of the port where there is no crush on the gasket.
                5.9magnum questions
              • Treblig
                5,871
                3095
                Oct 5, 2013
                South Texas
                Local Time:
                1:55 PM
                I have found that the magnum port matches the 340 exhaust manifold. The 96/97/98 318/360 Jeep Grand Cherokee exhaust ports are the same as the 340 exhaust ports.....no difference. The only smaller exhaust ports are the early 273/318 engine heads. treblig
                • Like Like x 1
                • Agree Agree x 1
                • Disagree Disagree x 1
                • ed1946
                  134
                  41
                  Apr 24, 2019
                  garrison, ky
                  Local Time:
                  2:55 PM
                  I will ck when I get ready to work on motor
                • bobscuda67
                  bobscuda67 Well-Known Member
                  1,881
                  152
                  Aug 27, 2005
                  Michigan
                  Local Time:
                  2:55 PM
                  The Magnum port is shorter in height than the 340 LA port and will leak out of the bottom. I had to make adapters to go from Magnum heads to the 340 exhaust manifolds.
                  Check out post 14.
                • ed1946
                  134
                  41
                  Apr 24, 2019
                  garrison, ky
                  Local Time:
                  2:55 PM
                  So what do adapters look like? I really don't have any equipment to make adapters. How about putting the 2 different gaskets, 340 and magnum, together behind 340 manifolds.
                  • Like Like x 1
                  • toolmanmike
                    toolmanmike FABO Staff Staff Member FABO Gold Member
                    46,852
                    31104
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    1:55 PM
                    Next time please start a wanted thread. Thanks
                  • DionR
                    1,940
                    205
                    May 7, 2008
                    Spokane, WA
                    Local Time:
                    11:55 AM
                    My adapters are just 14 or 16 gauge plates with the inside shape matching the inside of the Magnum exhaust gasket, and the outside matching the 340 manifold. Then I sandwiched them between a Magnum gasket on the head side and a 340 gasket on the other side.
                    In my case, they have been a little problematic, too. I expect that at some point I will just spring for a set of Doug's headers and get rid of them. I had to re-gasket them once and the second time around they didn't seal well. Could have been something I did wrong, or could be they don't want to seal more than once.
                    I have pictures of them installed, but I don't think I have any after I got them cut on a plasma table here at work.
                    Here is a screenshot of the AutoCAD file I used to get them cut. Started with a scan of both gaskets and traced what I needed and merged them together.
                  • ed1946
                    134
                    41
                    Apr 24, 2019
                    garrison, ky
                    Local Time:
                    2:55 PM
                    ok, thanks
                  • bobscuda67
                    1,881
                    152
                    Aug 27, 2005
                    Michigan
                    Local Time:
                    2:55 PM
                    That's what mine ended up looking like. Except I made mine by hand out of 16 gauge flat stock.
                    They have been on the engine for 9 years and no leaks.
                    • Like Like x 1
