Kaptain K
Member
I have a 68' 318 that is bored.040" over. My question is can I put a set of 340 J heads with 2.02" valves on this setup? I'm worried about cylinder wall clearance.
Check it just in case but it shouldn't be an issue.I have a 68' 318 that is bored.040" over. My question is can I put a set of 340 J heads with 2.02" valves on this setup? I'm worried about cylinder wall clearance.
This may be a naive question, but how do I check that?Check it just in case but it shouldn't be an issue.
Means nothing if you don't measure them.They've been shaved .010" already
Yep, .010 is a nice clean up cut to straighten things out. Not meant to decrease the chambers. We did a skim cut then .030 on my 273 heads to get the chambers down to minimum. Then you add a composite head gasket (.028) over the stock steel shim and you loose about .020 of that. So I only ended up with a .010 over stock specs. The 340 heads have a large chamber for the 4.040 bore and an open chamber to boot. Ahhh, we could go on and on about compression loss but the larger valves and ports will make up for that, yadda, yadda, yadda!Means nothing if you don't measure them.
They're 72 cc stock.. 4 cc bigger.. so .010 ,from stock, would be 70cc. 2cc bigger than the 318 head.. then the gasket issue..
But hey, bolt them on and roll if ya want..
There are other factors that contribute to increasing or decreasing chamber volume, like the valve job. If you max the seat.. AKA .040 smaller than the actual valve diameter.. then narrow it to .045...the valve sinks. More flow, but increases chamber volume...as does grinding the valves seat face.Yep, .010 is a nice clean up cut to straighten things out. Not meant to decrease the chambers. We did a skim cut then .030 on my 273 heads to get the chambers down to minimum. Then you add a composite head gasket (.028) over the stock steel shim and you loose about .020 of that. So I only ended up with a .010 over stock specs. The 340 heads have a large chamber for the 4.040 bore and an open chamber to boot. Ahhh, we could go on and on about compression loss but the larger valves and ports will make up for that, yadda, yadda, yadda!
