340 hp exhaust manifolds
Mopar Exhaust Systems
  1. Snake
    Snake Mopar Nut
    9,253
    255
    May 22, 2006
    Belleville Canada
    Local Time:
    11:55 AM
    To use the 340 hp manifolds,do i have to use the 90 degree oil filter,or is the straight on work.I ask because I am looking at a set of exhaust manifolds and the guy says i have to get the 90 degree oil adapter.Does not smell that good to me.This is for my 360 build.
  2. ValiantOne
    ValiantOne Well-Known Member
    1,080
    198
    Mar 20, 2008
    Communist Maryland
    Local Time:
    12:55 PM
    I had to. And I cannot see a way around it based on where the ps mannie routes.
  3. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    49,131
    15310
    Jun 7, 2010
    Georgia
    Local Time:
    12:55 PM
    The manifolds dont smell good? That's weird. I am pretty sure they do require the 90* filter adapter if they are the early 340 manifolds.
    • Agree Agree x 2
    • norton
      norton Doing the best that I can
      915
      132
      Jul 30, 2013
      Etobicoke, Ontario
      Local Time:
      12:55 PM
      Adaptor is required.
      • Agree Agree x 1
      • Snake
        Snake Mopar Nut
        9,253
        255
        May 22, 2006
        Belleville Canada
        Local Time:
        11:55 AM
        This is why i ask you all rock.
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        10,432
        1289
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        11:55 AM
        1968-70 need the adaptor. 71 up does not need it. Kim
        • Like Like x 1
        • Snake
          Snake Mopar Nut
          9,253
          255
          May 22, 2006
          Belleville Canada
          Local Time:
          11:55 AM
          Interesting Whats the difference 68-70 vs 71-86 a bodies? teach me.
        • Treblig
          Treblig FABO Gold Member FABO Gold Member
          5,244
          2246
          Oct 5, 2013
          South Texas
          Local Time:
          11:55 AM
          The 71 and up 340 passenger's manifold is designed completely different from the pre-71 manifold. It has a much smaller exit hole (1 7/8") as opposed the older ones (2 1/4"). The older ones are more rare and more expensive than the newer ones.
          treblig
          • Like Like x 1
          • norton
            915
            132
            Jul 30, 2013
            Etobicoke, Ontario
            Local Time:
            12:55 PM
            That's very strange because my 72 -340, numbers matching block has it.
          • 72SwingerJosh
            72SwingerJosh Well-Known Member
            644
            1332
            May 20, 2016
            Pennsylvania
            Local Time:
            12:55 PM
            My 72 swinger 340 clone needed it to. Used the 1973 340 manifolds.
          • 318willrun
            318willrun Stomper 4x4... we kept energizer in business
            7,865
            5909
            Sep 13, 2013
            I'm here
            Local Time:
            11:55 AM
            I have used the '73 manifolds on a small block duster and never needed a adaptor
          • 67/6barracuda
            67/6barracuda Well-Known Member
            330
            230
            Jun 24, 2013
            Sharpsburg, GA
            Local Time:
            11:55 AM
            I have a 73 340 drivers side and a magnum passenger side. No adapter and use the larger size oil filter. It worked out well.
          • oldkimmer
            10,432
            1289
            Nov 11, 2006
            Local Time:
            11:55 AM
            .......The 68-70 pass manifold exits to the rear on an angle right where the oil filter is.......the 71 up manifold exits straight down directly in the middle of the center 2 ports.........kim.....
            • Like Like x 1
            • Agree Agree x 1
            • H22A4
              H22A4 Well-Known Member
              1,537
              409
              Aug 4, 2006
              YVR
              Local Time:
              9:55 AM
              Are you running the manifold pair/set that Treblig sells? If so can you post some pictures of the passenger side manifold that shows where the downpipe is relative to the transmission dipstick?
            • abodyjoe
              abodyjoe Well-Known Member
              19,508
              3891
              May 22, 2004
              Berlin,N.J. 08009
              Local Time:
              12:55 PM
              here are the early manifolds and yes you need the 90* adapter with them..
              [​IMG]
              • Like Like x 1
              • Agree Agree x 1
              • 67/6barracuda
                330
                230
                Jun 24, 2013
                Sharpsburg, GA
                Local Time:
                11:55 AM
                Yes, Treblig was a pleasure to do business with hes a straight forward guy and took the time to resource and research the proper exhaust manifolds to avoid the dreaded header headaches. I also had him weld up a drivers side elbow to get around the torsion bar. In the picture hopefully you can see the dip stick placement. I also shown the bigger oil filter on there as well. No need for a filter re-locator with the magnum passenger side exhaust. trans dip stick.jpg oil filter.jpg .
                • Thanks! Thanks! x 1
                • 273
                  273 Well-Known Member
                  2,836
                  638
                  May 14, 2012
                  Ontario
                  Local Time:
                  12:55 PM
                  Buying them for looks or performance?
                  There's like a 3 hp difference between 360/340 manifolds.
                • Treblig
                  5,244
                  2246
                  Oct 5, 2013
                  South Texas
                  Local Time:
                  11:55 AM
                  Here are some pics of the 71 and up 340 passenger's manifold. Looks like these can be used without the oil filter adapter as well. I have many of these as you can see. Been planning on advertising them but haven't had time?? I have a few more besides these.
                  treblig
                • ScampMike
                  ScampMike Despicable Damn Yankee FABO Gold Member
                  34,091
                  8857
                  Oct 26, 2015
                  all Mopar driveway
                  Local Time:
                  12:55 PM
                  you got any pics of the manifolds this guy is trying to sell you? the 340 pieces (like abodyjoe is showing in post 15) are (from what I know) quite rare and can be expensive.. can I ask you how much he wants for them?
                • ScampMike
                  34,091
                  8857
                  Oct 26, 2015
                  all Mopar driveway
                  Local Time:
                  12:55 PM
                  you could also just use a filter relocation kit
                • Treblig
                  5,244
                  2246
                  Oct 5, 2013
                  South Texas
                  Local Time:
                  11:55 AM
                  I have one driver's side 60's 340 manifold but it's promised to member "rockramcharger". I haven't heard back from him in quite a few weeks but he has sent me a deposit on a set of 340/360 manifolds.:
                  treblig
                • ScampMike
                  34,091
                  8857
                  Oct 26, 2015
                  all Mopar driveway
                  Local Time:
                  12:55 PM
                  :thumbsup: - um... I was asking Snake about the ones he is thinking of buying... but thanks!! :lol:
                • Snake
                  Snake Mopar Nut
                  9,253
                  255
                  May 22, 2006
                  Belleville Canada
                  Local Time:
                  11:55 AM
                  no pics Mike but i have seen them there the 68-70 HP the hard to get he want 450,with the 340 oil adapter.
                • abodyjoe
                  19,508
                  3891
                  May 22, 2004
                  Berlin,N.J. 08009
                  Local Time:
                  12:55 PM
                  not a bad price if they are in decent shape.
                  • Agree Agree x 1
                  • ScampMike
                    34,091
                    8857
                    Oct 26, 2015
                    all Mopar driveway
                    Local Time:
                    12:55 PM
                    do it - then, like I said, go with a remote filter system if you don't want to use the 90. Your buddy is correct, will need one or the other with those manifolds.
