1. ch1ll
    ch1ll FABO Gold Member FABO Gold Member
    1,077
    463
    Jun 12, 2009
    Belgium,wi
    Local Time:
    6:32 PM
    can anybody post pictures of a 340 k frame and point out the differences between it and a regular V8 k frame?
  2. moparmat2000
    moparmat2000 FABO Gold Member FABO Gold Member
    19,847
    8803
    May 13, 2010
    Grand Tetons
    Local Time:
    6:32 PM
    Welded beefed up tubes at the back end for the LCA pins, and an identification washer tack welded to the front for assembly line I.D.
    • Like Like x 1
    • ch1ll
      1,077
      463
      Jun 12, 2009
      Belgium,wi
      Local Time:
      6:32 PM
      got any pictures?
    • replicaracer43
      replicaracer43 Grumpy Old Man
      5,082
      4555
      Oct 10, 2008
      Local Time:
      6:32 PM
      No pictures, but its basically just some "U" shaped reinforcement metal welded around the lower control arm pivot holes in the k frame, and a washer welded to the front for identification
      • Agree Agree x 2
      • Like Like x 1
      • moparmat2000
        19,847
        8803
        May 13, 2010
        Grand Tetons
        Local Time:
        6:32 PM
        Not really that much stronger than the normal K frame you would be better off bolting it on the car and seam welding it all the way around
        • Like Like x 1
        • 72bluNblu
          72bluNblu FABO Gold Member FABO Gold Member
          11,715
          6488
          Nov 28, 2008
          NorCal
          Local Time:
          4:32 PM
          There's a few threads with pictures of the 340 K frames. The reinforcements were minimal and usually pretty poorly done. They started in '70 and ran through '72 for sure, seems like '73 had them as well but they stopped before '74.
          The difference is literally a washer (that does nothing) and a couple of half moon washer shapes welded to the LCA pivot tube holes. You could do a better job of reinforcing the LCA pivot tubes with a couple of heavy duty washers from the hardware store welded on with a Harbor Freight MIG welder, even if you don't really know how to weld. Nothing else was different about the K's, and some of the factory welds on that stuff were atrocious.
          This is the washer, used to ID the K's
          These are the LCA pivot "reinforcements". And the "reinforcement" term is used very loosely.
          More info here
          340 K Member ??
          • Like Like x 2
          • hosehead
            hosehead Well-Known Member
            1,186
            933
            Dec 4, 2008
            Grand Lake o the Cherokees
            Local Time:
            4:32 PM
            I was putting the freshly powder coated k frame in my 70 340 swinger yesterday and was amazed how sloppy the welds are.....
            • Agree Agree x 1
            • replicaracer43
              5,082
              4555
              Oct 10, 2008
              Local Time:
              6:32 PM
              I always sandblast and reweld all the seems, plus add steering box gussets anytime I do one, even if it's not a race car
              • Like Like x 2
              • Agree Agree x 2
              • ch1ll
                1,077
                463
                Jun 12, 2009
                Belgium,wi
                Local Time:
                6:32 PM
                I would like to thank everyone who contributed to this thread, you have all helped me ID the V8 K frame that I just bought.
