340 MANIFOLD VS MAGNUM MANIFOLD ?
Magnum Engine Swaps
  1. CRAMAR
    CRAMAR Well-Known Member
    84
    52
    Jul 6, 2006
    Fort Wayne
    Local Time:
    5:12 PM
    I am thinking about putting a 5.9 magnum where my 318 is.It's in a duster.Will the exhaust pipe fit the magnum manifolds or will i have to get new exhaust?
  2. mod5v
    mod5v Well-Known Member
    642
    111
    Feb 17, 2006
    fortworth
    Local Time:
    4:12 PM
    You will not be able to use the Mag manifold on driver side. It sets to low and will hit the steering box. you can use the passenger side. outlet position is changed so most likely you will have to change the head pipe.
    • Like Like x 1
    • Treblig
      Treblig Well-Known Member
      5,880
      3100
      Oct 5, 2013
      South Texas
      Local Time:
      4:12 PM
      The 96/97/98 jeep grand Cherokee V8 passenger side manifold will fit real nice and give you flow that is close to the 340 HP manifolds. On the driver's side use the 70s 340 driver, it will fit with P/S or anything else you might have on your engine.
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      46,952
      31247
      Jan 18, 2006
      Iowa
      Local Time:
      4:12 PM
      And TTI makes pipes to fit different manifold numbers. They may not work with your exhaust depending on what it is but could probably be modified.
    • YY1
      YY1 Well-Known Member
      6,660
      2417
      Oct 11, 2011
      FL
      Local Time:
      5:12 PM
      340 manifolds would be a great ting for someone to repro-
      they'd have a lot more customers than just people with 340's
      • Agree Agree x 3
      • toolmanmike
        46,952
        31247
        Jan 18, 2006
        Iowa
        Local Time:
        4:12 PM
        • Thanks! Thanks! x 1
        • YY1
          6,660
          2417
          Oct 11, 2011
          FL
          Local Time:
          5:12 PM
          How much are they?
        • tonysrt
          tonysrt FABO Gold Member FABO Gold Member
          622
          275
          Dec 25, 2016
          Northport, NY
          Local Time:
          5:12 PM
          I bought my repro 340 exhaust manifolds from Shaker and they were $600.
        • Treblig
          5,880
          3100
          Oct 5, 2013
          South Texas
          Local Time:
          4:12 PM
          360 magnum Jeep grand Cherokee passenger manifold - $60
          340 HP 70s driver's manifold $150 -$100
          • Like Like x 1
          • plumcrazy 101
            plumcrazy 101 Well-Known Member
            4,506
            13282
            Jan 4, 2009
            Tk'eml'ups
            Local Time:
            2:12 PM
            Just working now on putting a set of 68 to 70 340 manifolds on the EQ Magnum heads. There is a mismatch on the ports that have to be corrected. Not only are the center ports wider but the lower portion port on the exhaust will not seal on the exhaust flange on the heads. Time to make up some flange adapters or do some welding on the exhaust manifold.
          • tonysrt
            622
            275
            Dec 25, 2016
            Northport, NY
            Local Time:
            5:12 PM
            I was looking to do the same thing with the 360 EQ heads and the repro exhaust manifolds. Has anyone else experienced this problem and would the edelbrock heads be the better way to go eliminating this port mismatch? Maybe the Indy MA-X heads, but looking at their picture might be the same problem.
          • rumblefish360
            rumblefish360 So close, yet so far away FABO Gold Member
            37,474
            9157
            Jun 21, 2005
            New York, on a Island
            Local Time:
            5:12 PM
          • toolmanmike
            46,952
            31247
            Jan 18, 2006
            Iowa
            Local Time:
            4:12 PM
            Yes but available. I gave seen nice used ones go for just a bit less.
          • plumcrazy 101
            4,506
            13282
            Jan 4, 2009
            Tk'eml'ups
            Local Time:
            2:12 PM
            The Edelbrock LA heads will not accept the 68 to 70 Hi Po exhaust manifolds but I have not tried their Magnum head with the manifolds.
          • plumcrazy 101
            4,506
            13282
            Jan 4, 2009
            Tk'eml'ups
            Local Time:
            2:12 PM
            Shaker Hood still has these manifolds for $600.00
            I believe that Tom from Rocket Industries is looking after the business after Ben Snobar passed away.
          • rumblefish360
            37,474
            9157
            Jun 21, 2005
            Local Time:
            5:12 PM
          • Treblig
            5,880
            3100
            Oct 5, 2013
            South Texas
            Local Time:
            4:12 PM
            I've never tried to install 340/magnum manifolds on EQ heads but an adapter should work if it doesn't push the manifold too far out away from the engine causing interference????
          • plumcrazy 101
            4,506
            13282
            Jan 4, 2009
            Tk'eml'ups
            Local Time:
            2:12 PM
            Just making the plates up today out of 3/32 thick 2 1/2" flat bar.
            Going to try steel on cast iron with high temp silicone as the sealer.
          • Treblig
            5,880
            3100
            Oct 5, 2013
            South Texas
            Local Time:
            4:12 PM
            Steel on cast shouldn't be a problem....drag racers have been doing it for decades. I would use the EQ gaskets and the 340/magnum gasket on the respective surfaces....but that's just me. Silicone will give you a little more clearance, but you may not need the extra clearance???????
          • leblanc
            leblanc member 2883
            2,153
            315
            Jun 5, 2006
            Dieppe,NewBrunswick,Can.
            Local Time:
            6:12 PM
            If you boost power a bit 2.5'' exhaust might not be a bad idea too.
          • plumcrazy 101
            4,506
            13282
            Jan 4, 2009
            Tk'eml'ups
            Local Time:
            2:12 PM
            That was the plan to use the 340 heat shield gasket but have not made my mind up on the other side.
          • plumcrazy 101
            4,506
            13282
            Jan 4, 2009
            Tk'eml'ups
            Local Time:
            2:12 PM
            Complete 2 1/2" exhaust going in with a cross over pipe
          • leblanc
            leblanc member 2883
            2,153
            315
            Jun 5, 2006
            Local Time:
            6:12 PM
            :thumbsup:
