[Found!] 340 Motor Mount Brackets
JeremyAB95
Ohio
I have 318 motor mounts, but I hear the driver's side on the 340 is different. If anything I need just the side that is different and not the pair. I only need the metal bracket part that attaches to the ears on the block because I already have the rubber biscuits that go between that and the k-member.
I have a set of 68 to 72 340 engine brackets 150+ the ride
As many washers as it takes? But I'm thinking
.375 of a inch. Don't hold me to that number.
I had time to add a ear from another mount & I have a welder. Just add washers & call it good.
