340 Piston and Valve Question
Small Block Mopar Engine
  1. Scubakuda19
    Scubakuda19 FABO Gold Member FABO Gold Member
    132
    64
    Mar 15, 2020
    Buffalo, NY
    Local Time:
    7:20 PM
    Hello, I have a 340 .030 over and the deck was milled .010 and the pistons are now .025 above deck. Does this present a issue for piston integrity? I'm running a set of factory "0" heads with 2.02 and 1.60 valves, what would be the recommended head gasket to achieve proper clearances? Thanks in advance for any help.
    • Like Like x 1
    • 4spdragtop
      4spdragtop FABO Gold Member FABO Gold Member
      29,340
      9641
      Aug 28, 2009
      Wasting time here
      Local Time:
      6:20 PM
      I would imagine rocker setup would come into play? Cam lift also? I'm still learning... thus the question marks lol
    • yellow rose
      yellow rose Master Of Insanity
      23,842
      19847
      Jun 19, 2015
      Walking a crooked mile
      Local Time:
      4:20 PM
      That’s better than most are. They SHOULD be above the deck. Gasket thickness will be determined by what compression ratio you need or want.
      The only way to know for sure what the CR is is to do a 1/2 down fill, CC the heads. And then don’t let me do the math! You need to measure everything and not guess.
      • Agree Agree x 2
      • Scubakuda19
        132
        64
        Mar 15, 2020
        Buffalo, NY
        Local Time:
        7:20 PM
        Thanks. I just got the heads back from the machine shop and they CC'd at 66. I know the pistons from the factory were .014 out of the hole and the deck was milled .010 so theres the .025 out. May I ask procedure for 1/2 down fill? I believe that the pistons are 10.5 to 1 but that will be determined exactly by the gasket thickness? Thanks
        • Like Like x 1
        • RustyRatRod
          RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
          63,272
          35925
          Jun 7, 2010
          Georgia
          Local Time:
          7:20 PM
          You'd have to have a good bit of duration to have trouble with piston to valve clearance.
          • Agree Agree x 3
          • yellow rose
            23,842
            19847
            Jun 19, 2015
            Local Time:
            4:20 PM
            And a pretty slow lobe with that duration.
          • Scubakuda19
            132
            64
            Mar 15, 2020
            Buffalo, NY
            Local Time:
            7:20 PM
            Cam 284-484 it's not too radical. I appreciate the input, this is my first build and learning everyday. Thanks
          • RustyRatRod
            63,272
            35925
            Jun 7, 2010
            Georgia
            Local Time:
            7:20 PM
            You're in fine shape.
            • Agree Agree x 2
            • Thanks! Thanks! x 1
            • Scubakuda19
              132
              64
              Mar 15, 2020
              Buffalo, NY
              Local Time:
              7:20 PM
              Thanks. The pistons extending out of the hole .025 doesnt compromise the piston in any way?
              • Agree Agree x 1
              • RustyRatRod
                63,272
                35925
                Jun 7, 2010
                Georgia
                Local Time:
                7:20 PM
                No. They were like that right from the factory.
                • yellow rose
                  23,842
                  19847
                  Jun 19, 2015
                  Local Time:
                  4:20 PM
                  It’s easier said than typed. But I’ll give it a shot.
                  Bore squared times the stroke length will give you the volume of any cylinder. So in your cascade it’s 4.070 times 4.070 times 12.87 (the number to convert cubic inches to CC’s) and take that number and multiply it by your stroke (or the thickness of the gasket or whatever the depth of the cylinder you are measuring is. And that number is the total volume of your cylinder.
                  4.070*4.070*12.87=213.19026*3.313=706.29933
                  That is IF you have a true flat top piston, with no valve reliefs and a zero deck.
                  Now you get the number 1 cylinder at absolute TDC and put your dial indicator on the piston and lower it .600 (hang with me as I know I said .500 but you can use any piston depth you want, as long as any dome is lower than the deck). Take some grease and seal use it to seal around the top of the piston. That’s why I said go an extra .100 deep. Once you get the grease in there (dial indicator is still on the piston) turn the crank clockwise (direction of rotation in the car just like it runs) until you are at exactly .500 down. Use your clear plexiglass plate with a hole in it and your graduated burrette and slowly fill the cylinder until it’s full and read how many CC’s it took to do that. That will tell you your exact dome or dish volume, including valve notches. I can’t say what yours is. You have to measure it.
                  I have a .187 dome on mine, and I know my numbers so I’ll post the, here so you can see how the math works.
                  My cylinder volume is exactly 695.92543 which is less than yours because my bore is a skosh smaller. That’s why you measure. Sooooo, now we need to know what the volume is at .500 down. Same math.
                  4.04*4.04*12.87=*.500=105.02949 and again, that’s with a flat top and no valve notches. My .500 downfill was exactly 99 CC’s, which means my dome displaces exactly 6.02949 CC’s. Damn this takes some typing.
                  Ok, now we have a cylinder volume, and a 1/2 down fill volume so we know exactly what the piston dome (in my case dome...could be a flat top with valve notches or a dish) but we ain’t done yet, unless you have a .0000 deck height. You don’t. Neither do I. But the math is the same. I’m out of the hole a measured .040 so it’s:
                  4.04*4.04*12.87=210.05899* 040=8.4023596 CC’s and that gets added to the dome volume. So that 14.431849 CC total dome volume. And were not done yet. You need to figure the gasket volume. For me that’s 4.185*4.185*12.87=225.40807*.036=8.1146905 CC’s because my gasket has a 4.185 bore and is .036 thick. Hope this is making sense. And my head is 71 CC’s. Now we are down to simple math.
                  To find your actual compression ratio the math is:
                  Cylinder volume at Bottom Dead Center divided by cylinder volume at Top Dead Center! Simple huh? That means we need to add up the actual cylinder volume, plus the head CC, plus the gasket. So...
                  695.92543+71+8.1146905=775.04012 CC’s. That is my actual total cylinder volume at BDC. Now we add up the volume at TDC, which is 71+8.1149605=79.11469 BUT WAIT...we need account for the dome volume and the positive deck height because that displaces volume at TDC. So that means 79.11469-8.1146905=71CC’s. Ok we are now down to the short strokes.
                  Volume at BDC is 775.04012 and the volume at TDC is 71. Therefore:
                  775.04012/71=awe crap...going by my memory I missed something. Hang on...gotta find my note book.
                  Ok, let start over with my actual numbers.
                  71+8.1146905-8.4023596-6.02949=64.682841 and that is the volume at TDC. Good thing I have my notes here or I’d be screwed. So...now it’s the total of volume at BDC which is:
                  64.682841+696.422=761.10484 and that’s the total of the volume at BDC. So...now it’s:
                  761.10485/64.682841=11.767619 actual, measured compression ratio. I’m doing that on pump gas and iron heads, so my butt may be sucking buttermilk but I think I can do it. So...the math above was:
                  Head CC plus gasket volume minus dome volume minus positive deck height for the actual volume at TDC and...
                  volume at TDC (64.682841) plus the swept volume (696.422) of the cylinder and that gives you your total volume at BDC and you simply divide the BDC volume by the TDC volume and that’s it.
                  FWIW it’s much easier to do it than to type and read it. Damn, hope I didn’t confuse you. In reality, it the measuring of a few volumes, doing some simple math and you’re done.
                  YR
                  • Like Like x 4
                  • rumblefish360
                    rumblefish360 So close, yet so far away FABO Gold Member
                    38,705
                    10305
                    Jun 21, 2005
                    New York, on a Island
                    Local Time:
                    7:20 PM
                    I just checked piston to valve clearance on my 340 with the replacement KB slugs (@10.51 measured) with a .017 positive deck dome height & a .546 lift cam and there is enough room for a truck to drive through.
                    Now that I know this, ha ha ha, the next lift used will be much more!
                    • Like Like x 1
                    • Agree Agree x 1
                    • Garrett Ellison
                      Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
                      2,805
                      2193
                      Jan 1, 2018
                      Southwest VA
                      Local Time:
                      7:20 PM
                      A light piston modification to improve piston to valve clearance. It's just beveling the sharp edge from the valve relief trough. Probably not necessary in your case but not a bad idea if you decide to go larger later on. Do you know how much the heads have been milled on that?
                      [​IMG][​IMG]
                      • Like Like x 2
                      • nm9stheham
                        nm9stheham Well-Known Member
                        12,090
                        3935
                        Dec 20, 2013
                        Waynesboro, VA
                        Local Time:
                        7:20 PM
                        OP, set it sounds like you have open chambered heads. The pistons ought to stick up into the open area all around and have no clearance issues to the head. You can just put a piston at TDC, sticking out, and set the head on the block with no gasket; the head ought to set flush without hitting the piston. You can put a thin piece of clayon the piston head when yo do that and see what thickness you end up with.
                        Sounds like your heads may have been milled something like .030" based on your cc numbers. But even then the recess in the head will be something like .080" deep, and that, plus the head gasket thickness, will keep the pistons far away from the head.
                        Just curious: What .030" pistons do you have?
                        • Like Like x 1
                        • Agree Agree x 1
                        • =Max Wedge=
                          =Max Wedge= FABO Gold Member FABO Gold Member
                          254
                          56
                          Jan 17, 2014
                          Ohio
                          Local Time:
                          6:20 PM
                          OP, Are the pistons new? What brand or a part number would be great as well. Thanks.
                          • Scubakuda19
                            132
                            64
                            Mar 15, 2020
                            Buffalo, NY
                            Local Time:
                            7:20 PM
                            I'm sorry I put you threw all that, I'm not confused at all you did a fantastic job explaining., thank you.
                            • Like Like x 2
                            • Scubakuda19
                              132
                              64
                              Mar 15, 2020
                              Buffalo, NY
                              Local Time:
                              7:20 PM
                              I bought the shortblock full rebuilt. I was told they were 10.5 to 1 Ross pistons. The heads I bought last year and just had them re-done and didnt ask the machinist if they were or had been milled. I guess it would've been easier for me to build from scratch vs buying a short block that was already done and building backwards.
                            • Scubakuda19
                              132
                              64
                              Mar 15, 2020
                              Buffalo, NY
                              Local Time:
                              7:20 PM
                              Brand new, I was told 10.5 to 1 Ross pistons, I didnt see anything stamped on the pistons, I looked at the bottom sides and they have C45 looks like on the bottom side, I will double check this today. Thanks
                              • Like Like x 2
                              • Cudafever
                                Cudafever Well-Known Member
                                4,257
                                1492
                                Sep 27, 2009
                                Local Time:
                                5:20 PM
                                My 340 specced out to be 9.4:1 for a 10.5 piston.
                                You have more piston above deck and a few less cc on head volume..........so you may be closer to 10.1..........CC everything and know what you really have!
                                That requires deciding on the thickness of the head gasket as well.
                                • Agree Agree x 1
                                • oldkimmer
                                  oldkimmer FABO Gold Member FABO Gold Member
                                  16,110
                                  4662
                                  Nov 11, 2006
                                  Kindersley, Saskatchewan,
                                  Local Time:
                                  6:20 PM
                                  The factory engines came with a steel shim gasket. .022 compressed. I have ran the 284/484 cam many times and with pistons .045 out of the bore. With the steel shim gasket. Kim.
                                  • Like Like x 1
                                  • Garrett Ellison
                                    2,805
                                    2193
                                    Jan 1, 2018
                                    Southwest VA
                                    Local Time:
                                    7:20 PM
                                    • oldkimmer
                                      16,110
                                      4662
                                      Nov 11, 2006
                                      Local Time:
                                      6:20 PM
                                      Sweet. Kim
                                      • Like Like x 1
                                      • Scubakuda19
                                        132
                                        64
                                        Mar 15, 2020
                                        Buffalo, NY
                                        Local Time:
                                        7:20 PM
                                      • Scubakuda19
                                        132
                                        64
                                        Mar 15, 2020
                                        Buffalo, NY
                                        Local Time:
                                        7:20 PM
                                        Thank you!
                                      • 4spdragtop
                                        29,340
                                        9641
                                        Aug 28, 2009
                                        Wasting time here
                                        Local Time:
                                        6:20 PM
