340 seems to be locked up
Small Block Mopar Engine
  1. dancinwulf
    dancinwulf Well-Known Member
    75
    7
    Apr 8, 2015
    Ketchum Idaho
    Local Time:
    10:49 AM
    I dropped a rebuilt 340 into my 70 Duster we turned it over by hand to bolt in the torque converter. Now that everything is together it seems to be locked up. Checked the starter relay and the starter they both seem to be functioning right then tried to move the flywheel by hand seems to be stuck. Could I have connected the 727 linkage wrong. Help please
  2. furrystump
    furrystump Well-Known Member
    1,005
    624
    Nov 13, 2004
    Local Time:
    5:49 PM
    So it turned over on the stand, but now in the car it won’t turn over?
  3. Dubob
    Dubob Well-Known Member
    1,242
    468
    Oct 28, 2011
    Ohio
    Local Time:
    12:49 PM
    Last it moved freely was while connecting torque converter. So that’s where I’d go back to. Flexplate installed properly, meaning front and rear. Proper bolts in torque converter to flex plate, if they are not correct the bolt head will catch on block. Was the converter properly seated onto trans shafts, this can be a bear because there are two sets of splines that are engaged. If the flex plate is installed properly then you should of had to pull converter forward to bolt it up if the converter was properly engaged to trans.
    • Agree Agree x 9
    • Like Like x 1
    • furrystump
      1,005
      624
      Nov 13, 2004
      Local Time:
      5:49 PM
      When you attached the converter was it sitting a good bit back in the transmission bell housing. Like 1/2”? So you had to turn it slightly and pull it forward so it would touch the flex plate. NOT using the bolts to move it forward?
      • Agree Agree x 2
      • yellow rose
        yellow rose Doctor of Thinkology.
        20,415
        16500
        Jun 19, 2015
        Living on the razors edge
        Local Time:
        9:49 AM
        STOP NOW. Most likely you don't have the converter all they way into the pump. Stop turning it as at this point you can damage the thrust main enough that it won't fail on fire up but 5000 miles from now the thrust will be shot.
        You can tell when the converter is all the way into the pump. Number one is the converter should be so far into the tranny that it looks like it will hit the case. Number two is you should have to pull the converter at least a 1/2 inch before it meets up with the flex plate.
        If those two thing didn't happen stop and make it happen.
        • Agree Agree x 6
        • Like Like x 1
        • yellow rose
          20,415
          16500
          Jun 19, 2015
          Local Time:
          9:49 AM
          Damn. Treed again. I am getting old.
          • Like Like x 2
          • furrystump
            1,005
            624
            Nov 13, 2004
            Local Time:
            5:49 PM
            DuBob beat us both!!!!
          • yellow rose
            20,415
            16500
            Jun 19, 2015
            Local Time:
            9:49 AM
            Well I really suck because I didn't see that one. Unreal. My wife says I'm getting old but I refuse to let her win that argument even though she aint wrong!
            • Like Like x 1
            • dancinwulf
              75
              7
              Apr 8, 2015
              Ketchum Idaho
              Local Time:
              10:49 AM
              Yes slid it on myself and then pulled it out to connect it to the flex plate so thats why I am stumped. will pull the cover off to see if any of the bolts are touching or anything I can see.
            • MoparMike1974
              MoparMike1974 FABO Gold Member FABO Gold Member
              1,917
              1258
              Jun 16, 2017
              Maryland
              Local Time:
              12:49 PM
              Did you try turning the crank from the front in both directions?
            • dancinwulf
              75
              7
              Apr 8, 2015
              Ketchum Idaho
              Local Time:
              10:49 AM
              Will try that tomorrow thanks
            • 408 swinger
              408 swinger FABO Gold Member FABO Gold Member
              1,449
              1205
              Nov 12, 2010
              Iowa
              Local Time:
              11:49 AM
              TAKE DUBOB'S ADVICE!!!! Another thing to look at, if this engine build is a complete unknown, converter snout to crank register issue. Meaning, old enough, non 340 crank, that has small hub register. That will prevent the snout from "pulling into" the crank.
              • Like Like x 2
              • 3406pk
                3406pk Well-Known Member
                841
                264
                May 11, 2006
                North Dakota
                Local Time:
                10:49 AM
                The correct bolts for convertor have thin heads for clearance. Also did you get all 4 bolts tightened & retightened. I got locked by that once. Tightened 3 bolts too much & 4th was sticking out then locked it.
                • Like Like x 2
                • Agree Agree x 1
                • superchargeddrt
                  superchargeddrt Well-Known Member
                  2,274
                  840
                  Aug 24, 2009
                  Pittsburgh, Pa.
                  Local Time:
                  12:49 PM
                  Make sure you used the correct flexplate to torque converter bolts. I bought what looked to be the correct bolts and as it turned out they were for flexplate to crankshaft and they threaded into the holes the heads were a little bit taller causing them to jam. Just something to check.
                • AJ/FormS
                  AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                  17,554
                  5950
                  Jan 19, 2014
                  South-Central Manitoba,Canada, 900ftelevation
                  Local Time:
                  11:49 AM
                  So no fluids in the engine yet? Specifically no coolant.
                • MoparMike1974
                  1,917
                  1258
                  Jun 16, 2017
                  Maryland
                  Local Time:
                  12:49 PM
                  I agree, if you use anything except the correct original bolts you will likely have interference issues. Thats why I said try turning the crank from the front both ways. This will tell you if a bolt head is holding it or if its a binding problem elsewhere.
                • rustycowll69
                  rustycowll69 Well-Known Member
                  2,098
                  935
                  Feb 19, 2016
                  Pacific northwest
                  Local Time:
                  9:49 AM
                  stock flex plate?
                • famous bob
                  famous bob mopar misfit FABO Gold Member
                  15,338
                  5518
                  Aug 14, 2011
                  okla
                  Local Time:
                  11:49 AM
                  I had this problem once , there was a (lost?) bolt that fell down in the trans. , under the convertor and wedged between the trans. and convertor teeth.
                  Talk about relief when I found it !!
                • 67Dart273
                  67Dart273 FABO Gold Member FABO Gold Member
                  41,726
                  9389
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  9:49 AM
                  ...........and if it turns out to be a converter problem into the trans, DO NOT run it before you pull the pump apart and inspect it
                • dancinwulf
                  75
                  7
                  Apr 8, 2015
                  Ketchum Idaho
                  Local Time:
                  10:49 AM
                  One of the bolts for the TQ did not get tightened down completely
                  • Like Like x 3
                  • dancinwulf
                    75
                    7
                    Apr 8, 2015
                    Ketchum Idaho
                    Local Time:
                    10:49 AM
                    Thanks for all the help
                    • Like Like x 2
                    • Thanks! Thanks! x 1
                    • yellow rose
                      20,415
                      16500
                      Jun 19, 2015
                      Local Time:
                      9:49 AM
                      Nice and easy and cheap.
                      • Agree Agree x 2
                      • Like Like x 1
                      • 4spdragtop
                        4spdragtop Well-Known Member
                        28,359
                        8191
                        Aug 28, 2009
                        Wasting time here
                        Local Time:
                        11:49 AM
                        Nice, congrats! Thanks for update!
                        • Agree Agree x 1
                        • superchargeddrt
                          2,274
                          840
                          Aug 24, 2009
                          Pittsburgh, Pa.
                          Local Time:
                          12:49 PM
                          There ya go! So glad it worked out.
