[SOLD] 340 Short Block, Lunati cam and X Heads
blewbyoutobad
Missouri City, TX
I have a 1970 340 short block with low miles and aluminum TRW forged 10.5 Cr and .030 overbore. The pistons are a little heavy for a bracket car but fine for the street. The weight is the same as a stock 340 piston, 720 grams. I built this short-block (it was balanced) in 1993 ran it a very short while on the street then sold the car. I got the car back in 2004 and drove it home from the seller. Seller backed it off the trailer in 1993 crushed the headers and parked the car. He was scared of it and drove it very little. No overheat and 65psi oil on highway. Bores look great & no ring ridge. Needs cleaned up honed, new rings and bearings, although the main bearing looks great. I used another 340 I already had for my 69 Swinger restoration. This was not a numbers match car. The X heads are on the 340 in my car right now. I'm not sure where I got them but it was a long time ago when I was swapping and buying engines. They may have come with the 340 I am selling. It came out of a 71 340 Demon I bought from a friends totaled car. I have had the heads since the 70s. They have been port matched, 4 angle valve job and some port work done here in Houston by Westside Performance and Machine. I have a partial flow chart, need to find it but I know the intakes flowed 260 at .500" lift. They also had a resurface (.010) in the 70s. Never any issues with them sealing or bolt alignment. I prefer to sell the package. Price is $2850 for all. I also have a factory windage tray that goes with block and an angled oil filter adapter. The motor from the Demon came from the Wichita Falls area. The cam and lifters is a new regrind and the specs are below.
May separate. Local pickup only. PayPal preferred, Houston Tx area. Thanks FABO
If u separate I'm interested on the X heads ... Im in Laredo TX pick up in person ..
Ok you are welcome to do some disassembly and check bearings and rotate assy. What I dont have is a harmonic balancer bolt to rotate the assy. I also have a guy I know that has been promising to come get it for 3 weeks. This Sat is the last day.
Same person wants it, lets see what he does. Check back Sat. sorry I have $100 of his money and I wont keep it if he doesnt buy.
Thanks
My Dad is willing to buy the whole engine. Please PM if everything falls through. He will come pick it up.
Yes sir one other person has spoken before you. Let me see if the original guy who put a deposit , whom I know comes this weekend. If not then I will contact you.
Thank you
The shortblock is available again. Let me know if you are interested. I have another person in line after you.
so, .. what happen with the heads !? ... been waiting to see what u were going to decide, .. never heard anything from u !! if i remember correctly i was first in line for heads !? ..
The guy that was in line for the shortblock sent a depost and never picked it up. If I sell the heads I have just disabled my car and not enough money to buy the new ones. So I need to change the add for the shortblock only and if it sells then I'll see about selling you the heads. My car is in Autorama for the first time this year at Thanksgiving and I need to make that show. I have not tried to purposely give you the shaft. Things have changed and Im not sure whats going to happen. Sorry for the delay. Not holding parts anymore because I had several interested parties in the shortblock and now they are gone. I will show this add as sold and relist the shortblock.
