340 turns over, got spark, won’t fire and run
Small Block Mopar Engine
  1. 121gigawatts
    121gigawatts Member
    15
    0
    Jun 20, 2018
    Near Chicago
    Local Time:
    8:06 AM
    hey fellas, got a 69 GTS. 1971 340 4 speed. Bought it nearly a year ago. It ran when I initially got it. In August, Took it on the road once to get some gas. LOTS of hesitation when I accelerated, stalled out as soon as I pulled in the garage. Fixed a clutch linkage issue and took it around the block. More hesitation and it stalled in the garage again. It’s sat ever since. It wouldn’t idle when I tried to set the timing back in November. It’s sat over the winter and now it won’t start. Messed with it this weekend, wasn’t getting spark to #1 (lots of carbon). Filed the points cleaned plug and got spark. Ran for a second until the moment I let up on the clutch (I was in neutral). As of now the fucker won’t start. Another thing I should mention, the original TQ is leaking pretty bad on the front passenger corner dripping over the manifold. Sorry for the long post, it’s all a mess. Any incite from you guys would be much appreciated!!
  2. rumblefish360
    rumblefish360 so close yet so far away
    34,091
    6012
    Jun 21, 2005
    New York, on a Island
    Local Time:
    9:06 AM
    If you have spark and fuel, then it’s spark timing, low fuel or bad plugs.
    • Like Like x 1
    • nm9stheham
      nm9stheham Well-Known Member
      10,405
      2675
      Dec 20, 2013
      Waynesboro, VA
      Local Time:
      9:06 AM
      Can you describe how you are testing spark? If it is to pull a plug, hook up the plug wire, and check for spark across the plug gap in open air, that is in no way a good test.
      What did you set the points gap to?
    • 121gigawatts
      121gigawatts Member
      15
      0
      Jun 20, 2018
      Near Chicago
      Local Time:
      8:06 AM
      My old man is helping me. he made a gap from the plug to a screw driver grounded on the engine block. I turned the key and he said we had spark. We haven’t set the points gap.
    • 69FBCuda
      69FBCuda Life in the Fast Lane
      1,302
      524
      Aug 28, 2014
      Florida
      Local Time:
      9:06 AM
      "he original TQ is leaking pretty bad on the front passenger corner dripping over the manifold."
      First thing you need to do is rebuilt that fire hazard!
      • Agree Agree x 5
      • halifaxhops
        halifaxhops It's going to get stupid around here! FABO Gold Member
        49,363
        17305
        Jan 20, 2014
        CENTRURAL, PA
        Local Time:
        9:06 AM
        Set the gap then check them with a dwell meter to make sure they are right. Any chance you put a new condenser in it before this started happening? The new ones suck.
        • Agree Agree x 1
        • 512Stroker
          512Stroker We are all here because we are not all there.
          358
          105
          May 30, 2016
          Freedom, MO
          Local Time:
          8:06 AM
          How old is the fuel?
          Had one here recent that we could not get to run until we replaced a half a tank of one year old fuel.
          The fuel we get now is junk, if smells the least bit funny is gone bad. You can dump as much snake oil in it as you want it won't help.
          Good luck, let us know how you do.
          • Agree Agree x 2
          • Like Like x 1
          • 121gigawatts
            121gigawatts Member
            15
            0
            Jun 20, 2018
            Near Chicago
            Local Time:
            8:06 AM
            Bel
            Last summer we (me and my dad) took it apart and replaced the gaskets hoping that would fix it. I think I’m gonna get a 670 street avenger.
          • 121gigawatts
            121gigawatts Member
            15
            0
            Jun 20, 2018
            Near Chicago
            Local Time:
            8:06 AM
            It’s got a full tank of year old gas.
          • nm9stheham
            10,405
            2675
            Dec 20, 2013
            Waynesboro, VA
            Local Time:
            9:06 AM
            Ooops... that is bad juju.... siphon some of it out and if it looks like reeeealy yellow dog pee, then you ought to get it all out. It'll smell skunky too. And if it has the typical ethanol in the fuel, then that will absorb water, turn into a gummy substance, and clog you carb big time.
            Modern FI engines can often fire on old gas when older carbed engines with weaker spark systems cannot, so your older Dart is gonna need a regular diet of fresh clean fuel. And try to use non-ethanol gas when you get ready let it set for a while, or at least use a fuel stabilizer additive.
            OK, it ought to be able to jump at least 1/4" with a blue spark in open air. If the gap set up for test in open air is really small, then that does not make a good test. It takes only a few thousand volt spark to jump a small gap in open air but that low voltage spark won't have a prayer of jumping the spark plug gap in a compressed fuel-air mixture. (Normal spark voltage from this type of system exceeds 20,000 volts.)
            • Agree Agree x 1
            • TF360
              TF360 Well-Known Member
              1,201
              298
              Apr 25, 2014
              Florida
              Local Time:
              9:06 AM
              Throw some new plugs in and rotor while your there
              • Agree Agree x 1
              • Demonic
                Demonic Well-Known Member
                402
                217
                Mar 21, 2015
                Maryland
                Local Time:
                9:06 AM
                Check the rotor & spark timing, just in case the chain jumped. Usually they just fall off. :lol:
              • Jadaharabi
                Jadaharabi FABO Gold Member FABO Gold Member
                4,598
                4158
                Jan 8, 2016
                Peoria, Illinois
                Local Time:
                8:06 AM
                When you and your dad regasketed the carb did it have brass floats in it?
              • xLURKxDOGx
                xLURKxDOGx "An angel fat, at satan's feast"
                2,682
                609
                Dec 27, 2013
                PHX
                Local Time:
                6:06 AM
                There’s your fix, sounds like a possible flooding issue?
                Jake
              • superchargeddrt
                superchargeddrt FABO Gold Member FABO Gold Member
                2,017
                595
                Aug 24, 2009
                Pittsburgh, Pa.
                Local Time:
                9:06 AM
                First things first,
                You NEED to fix that fuel leak before something bad happens. I remember warning a guy that was trying to start his car at a convenience store that his carb was leaking around the butterfly shaft and that he shouldn't be trying to start it. I just walked into the store when he came running in saying he needed a fire extinguisher. Hated to tell him "I warned you". Get the leak fixed then check for spark.
                • Agree Agree x 2
                • 121gigawatts
                  121gigawatts Member
                  15
                  0
                  Jun 20, 2018
                  Near Chicago
                  Local Time:
                  8:06 AM
                  It did have brass floats but they were in good shape weren’t leaking at all. We definitely double checked the float levels too.
