360 .020 Budget long block
RAMM
Ontario, Canada
Rating - 0%
0   0   0
360 .020” Budget build
For sale is a .020” over cast piston, stock crank, stock rods fresh as in new engine. It has “stealth” ported “J” heads that have 2.02/1.6 11/32” valves they flow 239-241 cfm @ .450-.550” with an untouched pushrod pinch opening. I had originally intended this engine for a 2 barrel circle track car but cannot finish the car at this time. The engine will come with a custom ground Hydraulic flat tappet .470”/.470” 241/235 on a 106 cl. I have run this cam before and it is a torque monster that makes peak HP @ 5800 rpm. Stock but fresh ground crank 20/20 with cast Fed|Mogul 405 np pistons. With a good intake and 4 barrel this combo should make anywhere between 400-440 hp with similar torque. Stock shot peened rockers. I would like to sell as a longblock only. $4000 with 2bbl intake, 4412, and spacer or $3500 without any intake or oil pan. Pm for more info.J.Rob
this is a good deal, and people the heads look like the cfm he says they flow, cause thats exactly the work that needs done to get those numbers 'kink work and bowl/short turn'
