1. Sander
    Sander New Member
    4
    0
    Sep 24, 2021
    Norway
    Local Time:
    11:44 AM
    Hi!
    Might be a stupid question, but i cant seem to get my 73 360 to fit right with my 75 904. suposedly been driven before, but not in the last 20 year. It’s a 75 duster. Does anyone have some advice here?
    sorry for the bad english, been a long time since my english lessons here in norway!
    thanks in advance
  2. 72Dart6pack
    72Dart6pack Well-Known Member
    4,957
    5699
    Feb 1, 2016
    Michigan
    Local Time:
    5:44 AM
    Same bolt pattern on a 318. Same bolt pattern on a 904 or 727. It should not be a issue
  3. JBurch
    JBurch FABO Gold Member FABO Gold Member
    1,984
    1204
    Oct 17, 2009
    Owego, NY
    Local Time:
    5:44 AM
    What do you mean by "not fit right"? Bolt pattern of transmission to back of block, or converter to flex plate? Converter into transmission?
    Your English is MUCH better than my Norwegian, don't worry about it.
    • Agree Agree x 3
    • Stephen Mulkey
      Stephen Mulkey FABO Gold Member FABO Gold Member
      1,004
      751
      Nov 29, 2016
      California
      Local Time:
      2:44 AM
      Are you having issues with the torque converter? Is it fitted into the front pump correctly? It would cause issues.
      • Agree Agree x 2
      • Sander
        Sander New Member
        4
        0
        Sep 24, 2021
        Norway
        Local Time:
        11:44 AM
        The issue is that there is a gap of 8mm on the passenger side, and 15 mm on the driver side between the transmission and the engine. Tried lifting the engine, lowering the transmission and moving them induvidualy to «wiggle» them into place. I have no more ideas on what to do
      • 72Dart6pack
        4,957
        5699
        Feb 1, 2016
        Michigan
        Local Time:
        5:44 AM
        Photos are the same as what your doing. 360 & 904 Trans.
      • Sander
        Sander New Member
        4
        0
        Sep 24, 2021
        Norway
        Local Time:
        11:44 AM
        I think I se my problem, i dont belive my converter is that as much in to the transmission. I think mine is a bit more «out» if that makes sense
      • 72Dart6pack
        4,957
        5699
        Feb 1, 2016
        Michigan
        Local Time:
        5:44 AM
        Converter needs to be a 12.7 mm back from the Trans surface.
      • TT5.9mag
        TT5.9mag Two atmospheres are better than one
        3,044
        3216
        May 5, 2016
        So cal
        Local Time:
        2:44 AM
        It will make a mess of there is fluid in it but the best way Ive found to seat a stubborn torque converter is to stand the trans up on the tailshaft and rotate the converter. Back, forth, up, down, shimmy and shake. Sometimes they just don’t want to seat in the pump.
      • 70aarcuda
        70aarcuda Master Hoader of SBM FABO Gold Member
        16,640
        5508
        Jan 16, 2005
        las vegas
        Local Time:
        2:44 AM
        Converter must seat into the pump other wise you will ruin the pump as soon as you start it.....
        besides the distance as mention above,,,,,if you turn the converter back n forth you should hear a clak clak noise...that is the snout of the converter hitting the tits on the pump...
        • Agree Agree x 2
        • Tims 66 Cuda
          Tims 66 Cuda Mopar mid life crisis
          463
          210
          May 28, 2018
          Poquoson, Va
          Local Time:
          5:44 AM
          Make sure the flex plate is installed forward looking to the crank. Second make sure the torque converter is seated properly. If it doesnt line up with flats in the pump it wont seat completely. Ask me how I know
          Tim
          • Agree Agree x 1
          • 1966Post
            1966Post Well-Known Member
            358
            186
            Mar 8, 2015
            Wisconsin
            Local Time:
            4:44 AM
            Usually when you spin the convertor to seat it into the transmission it will click in 2 times I don’t think you have it fully into the transmission yet. As others have mentioned
            Otherwise it will bolt up perfect Good luck!
            • Agree Agree x 1
            • 72Dart6pack
              4,957
              5699
              Feb 1, 2016
              Michigan
              Local Time:
              5:44 AM
              How the flex plate should look on the converter
            • Sander
              Sander New Member
              4
              0
              Sep 24, 2021
              Norway
              Local Time:
              11:44 AM
              Thanks for the help! Got it right! Thank you all!
