Dragonbat13
I'm thinking about putting together this engine:
I have these parts:
360 unopened engine out of a 79 truck. Unknown miles.
Some zollner/badger p290 +.020 pistons. Dont know any specs on these other than I think they are flat top with reliefs but I'm not sure. They are at the shop right now.
Scat I beam rods, new factory length.
Speed master airgap intake that everyone loves to hate. I know all about the problems and am prepared to either fix or eat the money I spent and buy better. But let's just say I use that for now.
Comp 20-222-3 cam. 218/224 @.050 .462/.470 lift. 110 lobe sep.
Carter 600 AFB carb.
Factory electronic distributor.
This is what I plan on getting if I build this:
Hughes 1110 springs.
Johnston hydraulic lifters.
Four seconds flat ignition.
New main bolts, possibly a wind age tray.
New oil pump non high volume.
Mechanical fuel pump to keep things simple. Not sure on that. 3/8ths fuel line feeding everything. Might go electric with regulator and return.
Thinnest head gaskets I can find.
The car: 73 dart sport with 323 gears and 225/60 r15 tires on all corners. Tf727. Will spend the coin on a decent custom street convertor. Plan on getting correct governor weights to optimize shift points for cam. Want it to be stab and steer.
My questions are: is it possible to break 300 hp with the compression that I wont have with my combo? I doubt those badger pistons will have a decent deck height and will be in the hole a bit. I'm thinking 8.5 static.
Does this combo sound like it will make a fun driver?
I have these parts:
