360 Build suggestions
Small Block Mopar Engine
  1. C2ndLTpigeon
    C2ndLTpigeon Mopar or no Car! FABO Gold Member
    522
    125
    May 18, 2019
    Indio California
    Local Time:
    1:02 AM
    So after spending some money trying to build a 318 and hearing the "you should just build a 360" opinion and I finally fell for it. I managed to pick up a 360 with 727 for a good deal to replace my 318-904 set up. This is a street car that needs some more power than the whiplash 318 im running.
    I'm looking for a good build suggestion. It would be nice to have compression in the 9's I would like to keep costs down so I plan to use stock Iron heads with 1.88 1.60 valves with some port match and bowl clean up. Stock crank and rods are good for reuse.
    Looking for piston options and cam options.
    I have the following components that I plan to reuse with the 360: Headers, Protronix distributor, Performer air gap intake, edelbrock 600 (probably going to need bigger) and I cam running 3.55 gears in the rear.
    Thanks!
  2. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    41,100
    12572
    Jun 21, 2005
    New York, on a Island
    Local Time:
    4:02 AM
    Can you post the Whiplash cam card?
    What is the goal for the car?
  3. C2ndLTpigeon
    522
    125
    May 18, 2019
    Indio California
    Local Time:
    1:02 AM
    Mainly a street car, but I might take it to the 1/8th mile once in a blue moon.
    Here is the specs on the 318 whiplash im running.
    • Disagree Disagree x 1
    • rumblefish360
      41,100
      12572
      Jun 21, 2005
      Local Time:
      4:02 AM
      Ok... are you interested in going with an upgraded converter?
      Is there a particular time slip to chase?
      Is a mechanical cam OK?
    • C2ndLTpigeon
      522
      125
      May 18, 2019
      Indio California
      Local Time:
      1:02 AM
      I could upgrade the converter at a later point.
      No there is no goal time its just for fun and it will be more towards a street car with some oomph
      I would like to use a mechanical flat tappet cam still.
    • rumblefish360
      41,100
      12572
      Jun 21, 2005
      Local Time:
      4:02 AM
      Without a converter change....
      Comp Cams 20-246-4. (270S)
      A SFT “Magnum” series cam.
      1800-5800 rpm
      270/270 (224/224@050) .468/.468 - 110
      With a minor converter upgrade, 2500 stall...
      Comp Cams 20-233-4 (XE268S)
      2-6K 268/274 (230/236@050) - .488/.501 - 110
      In the future, if a better set of heads enter the picture, use the best heads available, & use 1.6 rockers. I’d get the rockers now if you don’t already have a mechanical rocker set.
      • Like Like x 1
      • Thanks! Thanks! x 1
      • C2ndLTpigeon
        522
        125
        May 18, 2019
        Indio California
        Local Time:
        1:02 AM
      • rumblefish360
        41,100
        12572
        Jun 21, 2005
        Local Time:
        4:02 AM
        I’m using those Federal-Mougal slugs in the wife’s 360 now @ zero deck. TF heads up top. Go for the EPS finish. 6E01AB66-9C2D-489B-9EFA-E395D49216B5.jpeg A3382230-C307-4151-A25A-1CE1ECEEA4D3.jpeg DE7781B9-CB68-4CAD-AA87-B5249CD39AC5.jpeg C5CFAFC2-AD02-4602-874D-AFC749F7FB06.jpeg 24AE2EC1-A240-43C3-8843-01854290F59D.jpeg D7D33E81-3A02-48E2-918C-9BD65221C676.jpeg
        • Like Like x 3
        • Jadaharabi
          Jadaharabi FABO Gold Member FABO Gold Member
          8,699
          9784
          Jan 8, 2016
          Peoria, Illinois
          Local Time:
          3:02 AM
          Since it is internally balanced I would use the 904 and converter behind it. Along with the flex plate.
          The 904 takes less power to drive it then the 727. Free horsepower to rear wheels by using the 904.
          • Agree Agree x 3
          • Like Like x 1
          • Ricks70Duster340
            Ricks70Duster340 Child of the King, widower FABO Gold Member
            329
            185
            Feb 8, 2021
            Sisterdale, TX
            Local Time:
            3:02 AM
            You will be fine with the 600CFM carb. Too many psych themselves into bigger is better. For the street, you'll almost always be happier with a smaller carb. Better economy, better low end response. If you look at one of the carb sizing calculators, you'll see just what size is optimal for your setup.
            • Agree Agree x 1
            • Demonracer
              Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
              5,035
              3023
              Jan 31, 2010
              Cleveland, Texas
              Local Time:
              3:02 AM
              I agree with Jadaharabi, build the 904 with a good converter to be a stout transmission & it will serve you well, lighter weight, less HP to drive & less reciprocating mass.
            • Brooks James
              Brooks James Dustoff
              1,029
              565
              Dec 12, 2020
              Fruitland Park Fl
              Local Time:
              4:02 AM
              Get forged pistons and slap a 100hp nitrous kit on it.cheapest horsepower out there. Turn you grocery getter into a tire fryer on command!!
              • Like Like x 1
              • AJ/FormS
                AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                20,986
                8308
                Jan 19, 2014
                South-Central Manitoba,Canada, 900ftelevation
                Local Time:
                3:02 AM
                You want cheap?
                Install the KB 107s, get the Scr up to 8.8 or better, and the Q to either less than .045 or more than .080, and just slap all your 318 stuff onto the 360 including that 318whiplash cam; 213/226/109+5. This may gross up to an advertised of near to 260/272@ .008, I'm guessing.Add a 2800TC and have some fun.
                Ok that's what I would do on the cheap with parts you already have.
                • Like Like x 1
                • rumblefish360
                  41,100
                  12572
                  Jun 21, 2005
                  Local Time:
                  4:02 AM
                  Using the kit just minimize’s down time. You’ll end up with an extra rotating assembly that is not worth much on a resale side being a stock cast crank and the OE rods which my not or may not be straight. Correcting such parts for use or reselling can be costly. Depending on there condition. IMO, disassemble the engine first to see what is good to go and then proceed from there.
                  The kit could be cheaper.
                  • Like Like x 1
                  • Agree Agree x 1
                  • mygasser
                    mygasser FABO Gold Member FABO Gold Member
                    962
                    620
                    Aug 17, 2010
                    faversham, kent. united kingdom
                    Local Time:
                    3:02 AM
                    agreed, for cheap i once used a 600 holley on a 440 and the throttle response was much better than the borrowed 750 i had on there. i only noticed a performance drop around 5000rpm ish and up where it 'flattened' off the power. on a 360 it'll be fine.
                    neil.
                    • Like Like x 1
                    • Agree Agree x 1
                    • mygasser
                      962
                      620
                      Aug 17, 2010
                      Local Time:
                      3:02 AM
                      and the 904 will bolt right up to the car it came from compared to swapping in a 727.
                    • SLOPAR72
                      SLOPAR72 Well-Known Member
                      2,751
                      2276
                      Jan 5, 2016
                      Richmond, VA.
                      Local Time:
                      4:02 AM
                      Use a SFT and nitrate it.... It will help get you over the Zinc hurdle during break in.... Since this is a street bruiser and you have a goal I would go minimum mid 9's on Static compression. The Solid cam will put you in adjustable rockers so keep an eye out for a clean set of used from this site....
                      904 is a good option as is putting a few bucks towards a decent converter. That's what can turn it into a tyre fryer and of course if you want to up the ante gap the rings during assembly for a good 100 shot of gas...
                      JW
                      • Like Like x 1
                      • yellow rose
                        yellow rose Overnight Sensation FABO Gold Member
                        28,537
                        24967
                        Jun 19, 2015
                        Central Washington
                        Local Time:
                        1:02 AM
                        I would talk to several people before I did a nitride treatment of the cam. IIRC it makes the surface hard but there are some fracture issues under the hard layer.
                        If you are going to do some bearing on it you can cryogenically treat the cam and lifters. Or go to a steel cam and use the appropriate lifters.
                        It’s actually cheaper to do a roller cam when you get there. And it’s infinitely more durable.
                      • volaredon
                        volaredon Well-Known Member
                        666
                        187
                        Feb 28, 2010
                        IL
                        Local Time:
                        3:02 AM
                        Dump the 360
                        Build the 318.
                        Had to, I'm so damn tired of hearing how "bad" of an engine the 318 is. The 318 had been plenty of engine for at least a gazillion owners of them over the years.
                      • autoxcuda
                        autoxcuda Well-Known Member
                        7,183
                        1429
                        Apr 6, 2007
                        Local Time:
                        1:02 AM
                        • Like Like x 2
                        • gzig5
                          gzig5 FABO Gold Member FABO Gold Member
                          1,660
                          1810
                          May 3, 2018
                          Mequon, WI
                          Local Time:
                          3:02 AM
                          I see it says balanced but I don’t see the word internal. It’s a cast crank on that kit. You might want to verify internal or external
                        • Jadaharabi
                          8,699
                          9784
                          Jan 8, 2016
                          Peoria, Illinois
                          Local Time:
                          3:02 AM
                          Under additional information it says internal balanced.
                          • Agree Agree x 2
                          • C2ndLTpigeon
                            522
                            125
                            May 18, 2019
                            Indio California
                            Local Time:
                            1:02 AM
                            Im still trying to decide and am in no hurry, I agree that for a few more bucks a stroker kit could be had. If I went with a stroker I would like to get some aluminum heads but would need to save some pennies first.
                          • autoxcuda
                            7,183
                            1429
                            Apr 6, 2007
                            Local Time:
                            1:02 AM
                            you don’t have to buy aluminum heads. You could run your 360 heads. BUT go get an estimate from a machine shop to rebuild your 360 heads.
                            problem with stock cast iron J/X heads is they have a much larger combustion chamber, ~72cc, than any common aftermarket aluminum head; 63-65cc. So if you are running 9.5:1 compression on CA pump gas, upgrading in the future to an aluminum head puts you at too much compression for the same pistons.
                            That head situation goes for a 360 or stroker. Same issue both of way.
                            • RustyRatRod
                              RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                              73,160
                              48640
                              Jun 7, 2010
                              Georgia
                              Local Time:
                              4:02 AM
                              If you can find one, the MP .528 cam is fantastic. If not, Oregon Cam Grinders has a grind real close.
