aaronk785
What gears and converter?
motorhome could have had an easy or a hard life depending on loads and hills
did you do a compression check or leak down before taking the heads off? if not do it
If bores look good you can either leave well enough alone or do a minimum hone and new rings
new pistons without a bore job has been done to get the compression up
use the KB quench dome pistons especially made for LA open chamber heads
if it has the premium engine with premium valves and real exhaust seats they are hard to find check the engine codes carefully
check out the voodoo Lunati line but get your compression nailed down first
at least use the .028 Mr Gasket head gaskets- but you will still have no quench and have less compression than you think you do without measuring
Use the .028 gasket with the heads shaved .060. Make sure you shave the intake side .057. Should put you close to 9 to 1 comp. HP mopar did a build years ago called budget 360. It was 9 to 1 engine, ported smog heads with 1.88 1.6 valves, summit racing 218in. 228ex. at .050 .441 lift on both and 114 lsa. rpm intake and 750 holley. Put it in a 73 challenger with 1 5/8 headers 3500 stall and 3.55s. Car ran 12.60s in the 1/4 mile. Very impressive and very cheap. I think they figured about 340 HP.
Ok so maybe get a new Cam instead of risking using an old 340 one?
Any particular one spring to mind?
The KB-107 @ zero deck and a .040 gasket will come in at (or right close to a) 9.8-1 ratio. A small cam can cause detonation issues. A thicker head gasket may have to be employed or skip the block decking to zero.or do a minimum hone and new rings
There is no way you can call the 340 cam an emissions cam. Stop it already. Really! Just stop telling lies. Stop whining about what was and the reasons behind it. It was what it was and that’s it.some like the stock 340 cam which is even longer and lower lift- what's with that?- long life for warranty early years and emissions later years
Yes, it's always advisable to mill the intake faces after taking any more than .020, as there are too many tolerance stack up issues that start to negatively affect port and flange alignment past this point. On a whim, I was going to throw out a hand grenade guess (accurate to within 20%) earlier of 345 hp @ 5100 and about 410 lb feet at 3800 rpm. That's close enough to the magazine article results for me to say it here. I don't put a whole lot into what a dyno says though, as real world E.T. will show what a dyno can't. That should be pretty close with the mildly ported 587s with the chambers opened up for the 202 valves, along with the cam and induction from your 340. It's also assuming you got about a 9.2:1 compression ratio with all cylinder pressures within 10% of one another. I think your probably going to have dished pistons below deck, so even with the heads milled .060, .040 is going to be too thick to target that much compression. Which rear axle does it have? I am assuming 8-1/4. For your English countryside roads and four speed, you should really consider stepping up to 3.55 gears in this combination. It would make for a snappy driver with that 360 in that relatively light car.
Are you sure there 2.92 gears?
What size tire?
What’s the goal?
Spirited driver?
A dome piston will make matters worse.
Ok perfect.3.23’s are fine if the tire stays stock size and it can use a small cam just fine. I would t to much larger than the stock size 340 cam.
You realize the 340 oil pan will not work on a 360.
you asked about 340 cam wear
check the lifters
first keep track of their order!
you can butt two together and they should rock
if they are concave they are junk
you can place the bottom of one against something flat and it should rock and you should not see any light under the center
someone mentioned the 268 comp cam- a fine chevy design by UD Harold
and the 262 lunati voodoo
which has about the same lift with 6 degrees shorter duration
Like advancing the comp intake close point by 3 degrees to build cylinder pressure -(which is not a good Idea as it throws of the other 3 events)
It's a kludge for a to much duration cam
there is no place the voodoo would not outperform the comp especially on a lower compression motor
did OP post up his compression?
The problem with the old 340 cam design is the really long ramps and even with the long duration - not much lift
340 closes the intake late lowering dynamic compression
340 closes the exhaust late leading to intake dilution - which is why it is a smog cam in a late engine- like extra EGR
It opens the intake early allowing blow back , it opens the exhaust early which drains the power stroke- especially a big loss in a low compression motor
the 340 spreads out the overlap (makes it less) to 114 to compensate for these longer ramps which makes the opening and closing points even worse
now when I say early or late I mean compared to a faster acting cam- like the voodoo
did you see the head porting article in HotRod posted recently where they use a custom MM series solid profiles
same basic comparison here
Is the 340 internally balanced? The 360 is probably externally balance. Is the flywheel the same or do you need a different one like the flexplates. I have no idea but you should make sure your 340 flywheel is compatible.
The 360 flywheel is balanced for 360s only.
68-71. 340 are internal balanced engines and the 72-73 are external balanced.
Its an odd Ball Aussie Borg Warner Flywheel. Its originality a Hemi 6 re-ballanced in Oz to Mopar Spec for the 360. US 360 Flywheels dont fit.
Converted Surface Ground and Balanced Flywheel [Small Block 360]
So yes, it was a bit naughty of me to run it behind the 340 but I knew it was not for long as the 340 was needing pulled and rebuild anyway.
