[WANTED] 360 cam wanted
Ceedawg
Va
I have a 92 360, last year before magnum but still a roller cam and I don’t have to have a roller but if ones out there.. I’ll be using a carb so I need one with the provision for a pump or buy an extension, many options. Want something like 260-280 duration .450 lift. Street truck. I have a CC 292 but that’s a little big imo. Don’t want to break the bank on this, on a budget.
What ya got
Mopar Magnum HR-276s-SBM 220/220 496/496 Hyduralic Roller Camshaft Dodge Charger | eBay
Lift is a little high, but it's figured on a 1.6 rocker ratio, so it's in your ballpark with LA 1.5 rockers. It's a magnum core though, so pump drive is up to you... Same guy has a bunch of other spec cams too. Search "Dodge magnum roller camshaft" and all his choices come up. Maybe he can grind one on an LA core so you can run your pump eccentric.
Like all regrinds, you'll need longer pushrods because of the reduced base circle. But for the price, and no core, not a bad deal.
