[FOR SALE] 360 Ductile Iron 4 Bolt Main Cap Sets – New
Rocket
CT
I have a few sets of new ductile iron 4 bolt main caps available for 360 main small blocks. These are Mopar Performance caps. The sets include all 5 main caps. The center 3 caps are 4 bolt main. These are the same caps that came standard on R3 4 bolt blocks. I have installed these types of caps, 340 main variety, on a 340 before by milling off the ends of the center caps to leave them 2 bolt. See pictures for the 3 modified center caps installed on a 340 stroker engine. These caps are more stout than the stock caps and are an excellent upgrade for any high performance build . A line bore will be needed when installing new caps as well as some machining for the thrust bearing on the #3 cap and #5 cap for the oil seal.
Price is $230 shipped per set in the lower 48 states.
I will save you a set. I have a few sets.
No problem 1Badcolt. I had a set put aside for you.
I have one set left available.
